tcone' schrieb:
G4=X60t
G5=X61t=direct bonding=Glasplatte
Ich glaub', ich hab's... ist das so zu verstehen?...
edit:
Ab Lenovo-Werk (Serienausstattung):
edit:
alle X60t haben G4-Digitizer -> wenn sxga+ ist BOE HYDIS -100 verbaut = kein Grisselbild
edit:
alle X61t haben G5-Digitizer -> wenn sxga+ ist BOE HYDIS -101 verbaut = direct bonding = Glasplatte = Grisselbild
edit:
Digitizer+Kabel vom alten Display passt an beide sxga+.
Digitizer vom XGA-Display läuft auch mit sxga+ (wobei die Meinungen etwas auseinander gehen, wie genau damit "gezielt" werden kann).
mit folgenden Displaykabeln kommen dir x60t bzw.x61t ab Werk:
X60t XGA LCD without touch cable assembly without fingerprint reader for G4 Digitizer -> 93P4362
X60t XGA LCD without touch cable assembly with fingerprint reader for G4 Digitizer -> 93P4361
X61t XGA LCD without touch cable assembly without fingerprint reader for G5 Digitizer -> 93P4508
X61t XGA LCD without touch cable assembly with fingerprint reader for G5 Digitizer -> 93P4507
X61t XGA LCD without touch cable assembly with fingerprint reader, with wireless WAN for G5 Digitizer -> 93P4509
X61t XGA LCD without touch cable assembly without fingerprint reader, with wireless WAN for G5 Digitizer ->93P4510
X60t XGA LCD, touch panel, cable assembly without fingerprint reader for G4 Digitizer -> 93P4362
X60t XGA LCD, touch panel, cable assembly with fingerprint reader for G4 Digitizer -> 93P4361
X61t XGA LCD, touch panel, cable assembly without fingerprint reader for G5 Digitizer -> 93P4508
X61t XGA LCD, touch panel, cable assembly with fingerprint reader for G5 Digitizer -> 93P4507
X61t XGA LCD, touch panel, cable assembly with fingerprint reader, with wireless WAN for G5 Digitizer -> 93P4509
X61t XGA LCD, touch panel, cable assembly without fingerprint reader, with wireless WAN for G5 Digitizer -> 93P4510
X60t SXGA+ LCD cable assembly without fingerprint reader for G4 Digitizer -> 93P4362
X60t SXGA+ LCD cable assembly with fingerprint reader for G4 Digitizer -> 93P4361
X61t SXGA+ LCD cable assembly without fingerprint reader for G5 Digitizer -> 93P4508
X61t SXGA+ LCD cable assembly with fingerprint reader for G5 Digitizer -> 93P4507
X61t SXGA+ LCD cable assembly with fingerprint reader, with wireless WAN for G5 Digitizer -> 93P4509
X61t SXGA+ LCD cable assembly without fingerprint reader, with wireless WAN for G5 Digitizer -> 93P4510
Fazit:
edit: Kabel können übernommen werden, wenn ein Display
mit G4 Digitizer in ein X60t gebaut wird.
mit G5 Digitizer in ein X61t gebaut wird.
edit: Ansonsten ist
passend zum Digitizer und der Austattung (FPR, WAN) ein neues Kabel fällig.
edit:
G4 Digitizerkabel sind definitiv zu kurz, um ein G5 Digitizer anzuschliessen -> neues Kabel fällig entspr. der Optionen
edit:
G5 Digitizerkabel am am G4 Digitizerkabel sind evtl. zu lang -> evtl. neues Kabel fällig entspr. der Optionen (diese Aussage ist fraglich)
edit2:
edit2: X61t XGA LCD, touch panel, cable assembly with fingerprint reader, with
edit2: ist definitiv zu KURZ, um ein X60t Display (boe-hydis -100 mit G4) anzuschliessen
edit:
Offen ist die Frage, was der Unterschied bezügl. WAN ist zwischen den Kabeln, da es für die X60t sxga+ mit G4-Digitizer ab Werk kein spezielles Kabel für WAN zu geben scheint, was für eventuelle, noch unbekannte Probleme beim Einbau in X61t sorgen kann. Da jedoch der alte Digitizer übernommen werden kann, ist das ggfs. nur ein theoretisches Problem.
Da es vermutl. egal ist, ob evtl. Optionen (FPR/WAN) angeschlossen sind, kann man beim -101 wohl generell beim X60t zum 93P4509 greifen, während beim -100 im X61t !-eventuell-! zum 93P4361 gegriffen werden könnte... und hier brech' ich ab, da irgendetwas bei den WAN-Antennen X61t/X60t unterschiedl. sein muß
Btw. wer Lust hat, kann das jetzt gern fortschreiben - auch bezügl. Displaybezel-FRUs und evtl. Unterschiede der Digitizer-FRUs
