X1 Carbon Ultrabook
Status
The first time you look at the panel you'll notice what seems to be an excessively high dot pitch -- that is to say, there's a lot of space between pixels. If you have reasonably fresh eyes you'll easily be able to pick out the subtle dark lines that define the edges of pixels.
hört sich aber nicht so gut an
Gibt's eigentlich Hinweise, dass ein IPS-Panel verbaut ist? Ggf. auch als Option?
Lenovo baut in ihr X1C scheinbar eine neuere und deutlich leistungsfähigere Sandisk SSD ein (x100). Hierzu ein wörtlicher Post aus einem amerikanischen Forum (http://forum.notebookreview.com ):
That is probably good news. The Sandisk SSD in the Asus UX31A is not the x100 but the u100.
The Datasheet for the X100 lists "Up to 76,000 / 43,000 IOPS" for 4K Random R/W. If that's not a complete and utter lie (and that's certainly possible from the company that brought you the crappy u100) the SSD should be pretty good.
The Sandisk u100 has 4K IOPS on the low thousands at best. I guess the "u100" stands for "100% utter crap" and the new "x" model is one that actually does what a SSD is supposed to do. It's just sad that Sandisk didn't have the decency to trash the u100 model and start over instead of selling it to unsuspecting customers.
EDIT: I've also found the Datasheet for the u100. And i really have to give Sandisk credit: the datasheet doesn't sugarcoat anything: "sustained 4k random write: 700 IOPs" (the only thing missing from the datasheet is "HDD performance at SSD prices and capacities!" in bold letters)
So if Lenovo does actually use the X100 instead of the U100 a factor of about 60 in better 4K Random Writes should make the X1C something worth paying for.
@ Ginger: Danke für die Infos! Das klingt doch sehr vielversprechend!
Danke, dann ist die Hoffnung noch nicht verloren, dass Lenovo etwas bessere SSD einbaut!
campusp**** verkauft X1C mit IPS Panels :D Link
Bin mal gespannt, wie viele darauf hereinfallen...
Was anderes:
Gibt es die passenden neuen Netzteile auch zu kaufen?
Habe die neuen mit dem viereckigen Stecker noch nirgends gesehen...
Warum zensierst Du den Namen des Shops und verlinkst ihn dann noch? Irgendwie sinnlos.
Ihr kennt mich ja, ich habe IMMER was auszusetzen. Zum MBA würde mir so einiges einfallen...
Ich sitze gerade mit meinem MBA im Garten und finde es wunderbar :rolleyes:
Aber klar, die eierlegende Wollmilchsau gibt es nicht und wird es nicht geben, beim Apple-Alugehäuse nervt mich, dass man sehr darauf aufpassen muss, dass es nicht zerkratzt. Dafür hat es wiederum in anderen Bereichen Vorteile.
Was das X1C angeht, warten wir mal ab bis jerandra & Co das Teil in den Händen halten und freuen uns auf die ersten Reviews.
Du wirbst doch mit dem Link genauso, als würdest Du den Shop beim richtigen Namen nennen :huh:
Status
