Hier ein guter Artikel zum neuen TrackPad:
http://www.thinkscopes.com/thinkpad-buttonless-trackpoint/
lead_org schrieb:
The New ThinkPad released in year 2013 will have buttonless trackpoint integrated into the trackpad, which enables the new ThinkPad to have a larger surface area for the TrackPad. Some people (including me) worries that this new design will ruin their favourite TrackPoint and dilute the ThinkPad brand. Personally i think the new TrackPoint will take some getting use to, as this design will be different and won’t be the same as the old TrackPoint. From my experiences with the buttonless TrackPad design on the X1 Carbon, the new TrackPoint button integration into the TrackPad will cause some confusion at first, especially the middle button (which i use as a scroll button). Since i have not tested the new TrackPoint buttons i will resolve my final comments till when i get the chance to test the new ThinkPad with this new TrackPoint/TrackPad.
Lenovo choose the new design for several reasons (my guesses):
Larger TrackPad Surface (which in the old ThinkPad was its achilles heel).
Better Aesethetics
Gives Lenovo better competitive edge for people whom wants a large TrackPad.
Previous generations of Dell Latitude also had TrackPoint type pointing device, but in the recent models the Trackpoint type pointing device got dropped in favour of having a larger TrackPad surface. Lenovo obviously could not drop the TrackPoint in its ThinkPad, therefore the new TrackPad/Trackpoint design allows Lenovo to have the best of both worlds.
Er hat recht: Es gibt viele User, die TouchPads bevorzugen. Und die Frage "Was haben Office User denn von TouchPads": Das ist doch nicht euer ernst. Denkt ihr, jeder Office User mit ThinkPad nutzt den TrackPoint? Es gibt viele Menschen, die ein ThinkPad haben, und dennoch das TouchPad nutzen, einfach, weil sie es gewohnt sind, gerade eher wenig technik-affine Menschen. Das trifft auch aud Office User in Firmen zu, viele sind von ihren privaten Notebooks das TouchPad gewohnt. Dieser Nutzstamm ist riesig, und wenn man mal ehrlich ist, war das TouchPad schon lange in vielen Reviews bei ThinkPad ein großer Kritikpunkt. Ein ThinkPad sollte beide Kategorien gut beherrschen: Ein gutes TouchPad und einen (hoffentlich weiterhin, das muss ich dann noch sehen) hervorragenden TrackPoint.
Gerade diese neuen TrackPoint Tasten ermöglichen es Lenovo, den TrackPoint zu behalten, da man nun ein ungehindert großes TouchPad hat und den TrackPoint trotzdem behält.
Also für mich wäre selbst die Akkulösung als CRU ein no-go, da ich meine TPs ausschließlich im Zwei-Akku-Modus mit externem Akkuladegerät betreibe. Und da kann und will ich nicht jedesmal schrauben, wenn mir der Saft ausgeht.
Stichwort: Slice Akku.
Das wäre eine Lösung, die Lenovo reltiv einfach anbieten könnte.
Man kann beim fest integrierten Akku zB auf Li-Polymer umsteigen (wie beim T430u) und hat dann eine wesentlich bessere Haltbarkeit als bei Li-Ion - das ist aber auch nicht die Regel. Viele der Geräte haben fest integrierte, verklebte, Li-Ion-Akkus die bei intensiver Nutzung auch nach zwei/drei Jahren den Geist aufgeben.
Bei ThinkPads mit verbautem Akku waren es bis jetzt IMMER Li-Polymer Akkus (X1/X1 Carbon, T430u, Edge E420s/S430), da gibt es ja keinen Grund, warum Lenovo das ändern sollte. Und verklebt waren und sind die bei ThinkPads auch nicht, dieses Verbrechen begeht nur Apple. Li-Polymer Akkus haben noch einen weiteren Vorteil: Rapid-Charge.
Viel schlimmer, als das der Akku unter eine Klappe sitzt, wäre, wenn der RAM festgelötet wäre oder die SSD/HDD propritär (wie beim X1 Carbon oder beim Retina Macbook). Das hat Lenovo beim T431s ja zum Glück wieder geändert.
Dann unterscheiden sich bald Thinkpads nurnoch vom Namen von Ideapads, bis das irgendwann auch noch fällt.
Eher nicht: Lenovos neueste Firmenumstrukturierung zielt ja darauf ab, die Marke "Think" mehr in den Fokus und in das High-End Geschäft zu bringen. Dagegen wird aber der Name "IdeaPad" abgeschafft.
Siehe:
http://www.golem.de/news/auftragshe...instellung-von-ideapad-planen-1301-96869.html
