Review des X200 bei Notebookreview.com v.a. unten der Abschnitt "Battery Life".
The ThinkPad X200 comes with three different battery options: 4-cell, 6-cell or 9-cell. The bigger the battery the longer the battery life and of course the heavier the weight. We have the 9-cell cylindrical battery which causes the system weight to jump to about 3.6 lbs instead of the 2.95 lb weight you get with the 4-cell. It turns out that the 9-cell may well be worth carrying the extra weight, especially if you're a mobility freak that hates having to hunt down the next power outlet. Lenovo gives a quoted battery life of 9.2 hours with the 9-cell battery, and for what may be the first time ever our system outperformed the manufacturers quoted time. With the screen set to the 4th level of brightness, wireless on and the system idling for about 8 hours and being used to surf the web for about an hour the battery finally gave up at 9 hours and 53 minutes.This was no torture test on the battery, but during heavy usage with screen brightness all the way up you'll still pretty safely hit 5 hours of battery life. This reviewer took the X200 to a coffee shop to do some work for about four hours and only drained the battery down to 55% of the battery life while constantly surfing, typing, opening and installing programs. It's nice to not have to be glancing around wondering when you'll be able to pounce and claim that guys table who is camped out next to the coffee shops only power outlet.
Im Forum gab es daraufhin auch einige, die auf ähnliche Weise die 10 Stunden geknackt haben, angeblich sogar fast an 11 Stunden kamen (ich finde den Thread gerade nicht mehr).
Das war aber alles wohlgemerkt mit dem "normalen" X200 - keine Stromspar-CPU, kein LED-Display, keine SSD.
Keine Frage - wie es auch dran steht - das war jetzt kein repräsentativer Test und unter "richtiger" stetiger Nutzung (wobei Surfen und/oder bissel Office vom Idle-Betrieb ja auch nicht allzu weit entfernt sind) wird das natürlich auch nochmal anders aussehen, aber die Werte sind trotzdem durchaus beeindruckend.
Davon abgesehen hat das X200s mit Stromspar-CPU, (optionalem) LED-Display und (optionaler) SSD ja durchaus noch einiges Potenzial und ist ohnehin mehr auf Akkulaufzeit als auf Leistung getrimmt, wobei man hier ja eigentlich (so sehe ich das zumindest) schon noch ein bissel mehr erwarten darf - denn genau das wäre ein Grund, das X200s eben dem "normalen" X200 vorzuziehen.
Außerdem geben Hersteller und Händler ja meistens gerne Optimal- (wenn nicht Labor-) Werte an, die hier im Review mit dem 9-Zeller bei 9,2 Stunden liegen, und keine Durchschnittswerte.
Also entweder da stimmt wirklich was in der Beschreibung nicht oder aber es wurde zuvor mehr als dick aufgetragen...
Gruß, Jonny
