- 22 Juni 2007
EDITH: Bitte ab sofort den ausführlichen Wiki-Artikel benutzen.
ps. dieser Forums-Editor ist echt die Pest ... :thumbdown:
Es funktioniert!: http://paste.ubuntuusers.de/397244/hier[/url] gibt's die A5HA für deine HD.![]()
gksudo gedit /etc/default/hdapsd
Ups :whistling:hier[/url] gibt's die A5HA für deine HD.![]()
WARNING: Could not find hdaps input device (No such file or directory). You may be using an incompatible version of the hdaps module. Falling back to reading the position from sysfs (uses more power).
Use '-y' to silence this warning.
Mon Jan 11 14:37:20 2010: Could not open /sys/devices/platform/hdaps/sampling_rate: No such file or directory.
Do you have the hdaps module loaded?
ausführe, dann lieferte er mir zuerst das "falsche", nämlich (aus wiki kopiert):modinfo hdaps
Habe mich an den Lösungsvorschlag gehalten und erhalte nun:filename: /lib/modules/KERNEL-VERSION/drivers/hwmon/hdaps.ko ...
filename: /lib/modules/2.6.31-17-generic/updates/hdaps.ko
Gruß Maxinsmod: error inserting '/lib/modules/2.6.31-17-generic/updates/hdaps.ko': -1 File exists
ERROR: Module hdaps is in use
[ 75.689328] wlan0: authenticated
[ 75.689334] wlan0: associate with AP 00:18:39:22:60:74
[ 75.692184] wlan0: RX AssocResp from 00:18:39:22:60:74 (capab=0x471 status=0 aid=2)
[ 75.692190] wlan0: associated
[ 75.694151] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 86.308078] wlan0: no IPv6 routers present
[ 579.934340] CE: hpet increasing min_delta_ns to 15000 nsec
[ 772.751821] CE: hpet increasing min_delta_ns to 22500 nsec
[ 980.937951] input: Virtual ThinkFinger Keyboard as /devices/virtual/input/input12
[ 1051.367325] input: Virtual ThinkFinger Keyboard as /devices/virtual/input/input13
sudo m-a a-i tp-smapi
