[ 0.000000] BIOS-e820: 00000000793c6000 - 00000000793d1000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000793d1000 - 00000000793d4000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000793d8000 - 00000000793dc000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000793df000 - 0000000079406000 (ACPI NVS)
[ 0.000000] BIOS-e820: 0000000079406000 - 0000000079408000 (ACPI data)
[ 0.000000] BIOS-e820: 000000007960f000 - 000000007969f000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007969f000 - 00000000796ff000 (ACPI data)
[ 0.000000] modified: 00000000793c6000 - 00000000793d1000 (ACPI NVS)
[ 0.000000] modified: 00000000793d1000 - 00000000793d4000 (ACPI data)
[ 0.000000] modified: 00000000793d8000 - 00000000793dc000 (ACPI NVS)
[ 0.000000] modified: 00000000793df000 - 0000000079406000 (ACPI NVS)
[ 0.000000] modified: 0000000079406000 - 0000000079408000 (ACPI data)
[ 0.000000] modified: 000000007960f000 - 000000007969f000 (ACPI NVS)
[ 0.000000] modified: 000000007969f000 - 00000000796ff000 (ACPI data)
[ 0.000000] ACPI: RSDP 00000000000f6680 00024 (v02 LENOVO)
[ 0.000000] ACPI: XSDT 000000007965a077 0009C (v01 LENOVO TP-6H 00001140 LTP 00000000)
[ 0.000000] ACPI: FACP 000000007965a200 000F4 (v04 LENOVO TP-6H 00001140 LNVO 00000001)
[ 0.000000] ACPI: DSDT 000000007965a5db 0D5F7 (v01 LENOVO TP-6H 00001140 MSFT 03000000)
[ 0.000000] ACPI: FACS 000000007968e000 00040
[ 0.000000] ACPI: SSDT 000000007965a3b4 00227 (v01 LENOVO TP-6H 00001140 MSFT 03000000)
[ 0.000000] ACPI: ECDT 0000000079667bd2 00052 (v01 LENOVO TP-6H 00001140 LNVO 00000001)
[ 0.000000] ACPI: APIC 0000000079667c24 00078 (v01 LENOVO TP-6H 00001140 LNVO 00000001)
[ 0.000000] ACPI: MCFG 0000000079667c9c 0003C (v01 LENOVO TP-6H 00001140 LNVO 00000001)
[ 0.000000] ACPI: HPET 0000000079667cd8 00038 (v01 LENOVO TP-6H 00001140 LNVO 00000001)
[ 0.000000] ACPI: SLIC 0000000079667dc2 00176 (v01 LENOVO TP-6H 00001140 LTP 00000000)
[ 0.000000] ACPI: BOOT 0000000079667f38 00028 (v01 LENOVO TP-6H 00001140 LTP 00000001)
[ 0.000000] ACPI: ASF! 0000000079667f60 000A0 (v16 LENOVO TP-6H 00001140 PTL 00000001)
[ 0.000000] ACPI: SSDT 000000007968c4a2 00972 (v01 LENOVO TP-6H 00001140 INTL 20050513)
[ 0.000000] ACPI: TCPA 0000000079407000 00032 (v00 00000000 00000000)
[ 0.000000] ACPI: DMAR 0000000079406000 00120 (v01 ? 00000001 00000000)
[ 0.000000] ACPI: SSDT 00000000793d3000 00655 (v01 PmRef CpuPm 00003000 INTL 20050624)
[ 0.000000] ACPI: SSDT 00000000793d2000 00274 (v01 PmRef Cpu0Tst 00003000 INTL 20050624)
[ 0.000000] ACPI: SSDT 00000000793d1000 00242 (v01 PmRef ApTst 00003000 INTL 20050624)
[ 0.000000] ACPI: DMI detected: Lenovo ThinkPad T400
[ 0.000000] ACPI: Added _OSI(Linux)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.015224] ACPI: Core revision 20090903
[ 0.321000] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.321000] ACPI: bus type pci registered
[ 0.331225] ACPI: EC: EC description table is found, configuring boot EC
[ 0.338193] ACPI: BIOS _OSI(Linux) query honored via DMI
[ 0.361077] ACPI: Interpreter enabled
[ 0.361080] ACPI: (supports S0 S3 S4 S5)
[ 0.361103] ACPI: Using IOAPIC for interrupt routing
[ 0.393415] ACPI: EC: GPE = 0x11, I/O: command/status = 0x66, data = 0x62
[ 0.393461] ACPI: Power Resource [PUBS] (on)
[ 0.400416] ACPI: ACPI Dock Station Driver: 2 docks/bays found
[ 0.400738] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.403873] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.404013] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP0._PRT]
[ 0.404072] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP1._PRT]
[ 0.404134] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.EXP3._PRT]
[ 0.404200] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.410196] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.410362] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.410527] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.410690] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.410853] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.411015] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.411179] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.411341] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 10 *11)
[ 0.420265] ACPI: WMI: Mapper loaded
[ 0.420267] PCI: Using ACPI for IRQ routing
[ 0.431579] pnp: PnP ACPI init
[ 0.431589] ACPI: bus type pnp registered
[ 0.493712] pnp: PnP ACPI: found 10 devices
[ 0.493714] ACPI: ACPI bus type pnp unregistered
[ 0.514227] ACPI: AC Adapter [AC] (on-line)
[ 0.514485] ACPI: Lid Switch [LID]
[ 0.514529] ACPI: Sleep Button [SLPB]
[ 0.514580] ACPI: Power Button [PWRF]
[ 0.515292] ACPI: SSDT 00000000793d6c20 002C8 (v01 PmRef Cpu0Ist 00003000 INTL 20050624)
[ 0.515880] ACPI: SSDT 00000000793d4020 0087A (v01 PmRef Cpu0Cst 00003001 INTL 20050624)
[ 0.519128] ACPI: SSDT 00000000793d5ca0 001CF (v01 PmRef ApIst 00003000 INTL 20050624)
[ 0.519538] ACPI: SSDT 00000000793d5f20 0008D (v01 PmRef ApCst 00003000 INTL 20050624)
[ 0.573281] ACPI: Thermal Zone [THM0] (34 C)
[ 0.574680] ACPI: Thermal Zone [THM1] (35 C)
[ 0.577699] pata_acpi 0000:00:03.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[ 0.577726] pata_acpi 0000:00:03.2: setting latency timer to 64
[ 0.577737] pata_acpi 0000:00:03.2: PCI INT C disabled
[ 0.578291] ehci_hcd 0000:00:1a.7: power state changed by ACPI to D0
[ 0.607275] ACPI: Battery Slot [BAT0] (battery present)
[ 0.607413] ehci_hcd 0000:00:1d.7: power state changed by ACPI to D0
[ 0.630440] uhci_hcd 0000:00:1a.0: power state changed by ACPI to D0
[ 0.631030] uhci_hcd 0000:00:1a.2: power state changed by ACPI to D0
[ 0.631404] uhci_hcd 0000:00:1d.0: power state changed by ACPI to D0
[ 0.643866] acpi device:15: hash matches
[ 1.211058] ata1.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 1.211063] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 1.211068] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 1.263333] ata1.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 1.263337] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 1.263342] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 1.635722] ata2.00: ACPI cmd e3/00:10:00:00:00:a0 (IDLE) succeeded
[ 1.636591] ata2.00: ACPI cmd e3/00:03:00:00:00:a0 (IDLE) succeeded
[ 1.636595] ata2.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 1.647371] ata2.00: ACPI cmd e3/00:10:00:00:00:a0 (IDLE) succeeded
[ 1.648216] ata2.00: ACPI cmd e3/00:03:00:00:00:a0 (IDLE) succeeded
[ 1.648220] ata2.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 25.486889] thinkpad_acpi: ThinkPad ACPI Extras v0.24
[ 25.486892] thinkpad_acpi: [url]http://ibm-acpi.sf.net/[/url]
[ 25.486894] thinkpad_acpi: ThinkPad BIOS 6HET29WW (1.14 ), EC 6HHT14WW-1.02
[ 25.486895] thinkpad_acpi: Lenovo ThinkPad T400s, model 2815W3F
[ 25.488036] thinkpad_acpi: radio switch found; radios are enabled
[ 25.488213] thinkpad_acpi: This ThinkPad has standard ACPI backlight brightness control, supported by the ACPI video driver
[ 25.488215] thinkpad_acpi: Disabling thinkpad-acpi brightness events by default...
[ 25.494101] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
[ 25.495281] Registered led device: tpacpi::thinklight
[ 25.495309] Registered led device: tpacpi::power
[ 25.495323] Registered led device: tpacpi::standby
[ 25.495345] Registered led device: tpacpi::thinkvantage
[ 25.497493] thinkpad_acpi: Standard ACPI backlight interface available, not loading native one.
[ 25.497559] thinkpad_acpi: Console audio control enabled, mode: monitor (read only)
[ 25.500314] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input5
[ 25.525752] iwlagn: Intel(R) Wireless WiFi Link AGN driver for Linux, 1.3.27k
[ 25.525754] iwlagn: Copyright(c) 2003-2009 Intel Corporation
[ 25.525817] iwlagn 0000:03:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 25.525825] iwlagn 0000:03:00.0: setting latency timer to 64
[ 25.525857] iwlagn 0000:03:00.0: Detected Intel Wireless WiFi Link 5300AGN REV=0x24
[ 25.549298] i915 0000:00:02.0: power state changed by ACPI to D0
[ 25.565643] iwlagn 0000:03:00.0: Tunable channels: 13 802.11bg, 24 802.11a channels
[ 25.565748] iwlagn 0000:03:00.0: irq 30 for MSI/MSI-X
[ 25.582563] phy0: Selected rate control algorithm 'iwl-agn-rs'
[ 26.221870] acpi device:01: registered as cooling_device2
[ 26.222502] ACPI: Video Device [VID] (multi-head: yes rom: no post: no)
