Linux [TLP 1.9 Alpha] Testergebnisse
Linux Betriebssystem
Status
mcb
18 März 2009
Alle Informationen zur Alpha gibt es hier: https://thinkpad-forum.de/threads/tlp-1-9-alpha-testergebnisse.244864/#post-2448200
@linrunner
Ich hatte mal Testlust, also hier eine Rückmeldung das die 1.9 gut funktioniert:
root@t14:~# tlp performance && tlp-stat -p -g -r
TLP started using profile performance/AC (auto).
--- TLP 1.9.0-alpha.2_46fe058 --------------------------------------------
+++ Processor
CPU model = AMD Ryzen 5 PRO 7540U w/ Radeon 740M Graphics
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver    = amd-pstate-epp
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor  = powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq  =   400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq  =   400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq  =   400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq  =  4976000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/amd_pstate_lowest_nonlinear_freq  =  1115000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/amd_pstate_max_freq               =  4976000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = balance_performance [EPP]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu1..cpu11: omitted for clarity, use -v to show all
/sys/devices/system/cpu/amd_pstate/status              = active
/sys/devices/system/cpu/cpufreq/boost                  = 1
/sys/module/workqueue/parameters/power_efficient       = N
/proc/sys/kernel/nmi_watchdog                          = 0
+++ Platform Profile
/sys/firmware/acpi/platform_profile                    = performance
/sys/firmware/acpi/platform_profile_choices            = low-power balanced performance
/sys/devices/platform/thinkpad_acpi/dytc_lapmode       = 0
+++ AMD Radeon Graphics
/sys/class/drm/card0/device/driver                                = amdgpu
/sys/class/drm/card0/device/power_dpm_force_performance_level     = auto
/sys/class/drm/card0/card0-eDP-1/amdgpu/panel_power_savings       = 0
+++ Wireless
bluetooth = off (software)
nfc       = none (no device)
wifi      = on
wwan      = none (no device)
wlp2s0(ath11k_pci)            : wifi, connected, power management = on
root@t14:~# tlp power-saver && tlp-stat -p -g -r
TLP started using profile power-saver/SAV (auto).
+++ Processor
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq  =  3201000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = power [EPP]
/sys/devices/system/cpu/cpufreq/boost                  = 0
/sys/firmware/acpi/platform_profile                    = low-power
+++ Wireless
wifi      = on
wlp2s0(ath11k_pci)            : wifi, connected, power management = off
root@t14:~# tlp balanced && tlp-stat -p -g -r
TLP started using profile balanced/BAT (auto).
+++ Processor
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = balance_power [EPP]
/sys/firmware/acpi/platform_profile                    = balanced
+++ Wireless
wifi      = on
root@t14:~# tlp-stat --cdiff
+++ Configured Settings (only differences to defaults):
/etc/tlp.d/00-amd.conf L0005: DISK_DEVICES="nvme0n1 sda sdb"
/etc/tlp.d/00-amd.conf L0007: AMDGPU_ABM_LEVEL_ON_BAT="0"
/etc/tlp.d/00-amd.conf L0008: WIFI_PWR_ON_AC="on"
/etc/tlp.d/00-amd.conf L0009: WIFI_PWR_ON_BAT="off"
/etc/tlp.d/00-amd.conf L0010: SOUND_POWER_SAVE_ON_AC="0"
/etc/tlp.d/00-amd.conf L0012: SOUND_POWER_SAVE_CONTROLLER="N"
/etc/tlp.d/00-amd.conf L0013: RUNTIME_PM_ON_AC="auto"
/etc/tlp.d/00-amd.conf L0014: RESTORE_THRESHOLDS_ON_BAT="1"
/etc/tlp.d/00-amd.conf L0015: DEVICES_TO_ENABLE_ON_STARTUP="wifi"
/etc/tlp.d/00-amd.conf L0019: DEVICES_TO_DISABLE_ON_STARTUP="bluetooth"
/etc/tlp.d/00-amd.conf L0020: START_CHARGE_THRESH_BAT0="60"
/etc/tlp.d/00-amd.conf L0021: STOP_CHARGE_THRESH_BAT0="80"
/etc/tlp.d/00-amd.conf L0022: DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="bluetooth"
/etc/tlp.d/00-amd.conf L0023: CPU_DRIVER_OPMODE_ON_AC="active"
/etc/tlp.d/00-amd.conf L0024: CPU_DRIVER_OPMODE_ON_BAT="active"
/etc/tlp.d/00-amd.conf L0025: DEVICES_TO_DISABLE_ON_LAN_CONNECT="wifi wwan"
/etc/tlp.d/00-amd.conf L0026: DEVICES_TO_ENABLE_ON_LAN_DISCONNECT="wifi"
/etc/tlp.d/00-amd.conf L0027: CPU_BOOST_ON_AC="1"
/etc/tlp.d/00-amd.conf L0028: CPU_BOOST_ON_BAT="0"
Ups ein Bug?
Mein T14 schaltet nicht auf:
CPU_ENERGY_PERF_POLICY_ON_AC="performance"
Oder ist das im Bios blockiert?
Drei Versuche. Jeweils Ausgabe der Einstellungen und stat -p:
root@t14:~# tlp-stat -p --cdiff
--- TLP 1.9.0-alpha.3_6e718ca --------------------------------------------
/etc/tlp.d/00-amd.conf L0004: CPU_ENERGY_PERF_POLICY_ON_AC="performance"
/etc/tlp.d/00-amd.conf L0007: DISK_DEVICES="nvme0n1 sda sdb"
/etc/tlp.d/00-amd.conf L0009: AMDGPU_ABM_LEVEL_ON_BAT="0"
/etc/tlp.d/00-amd.conf L0010: WIFI_PWR_ON_AC="on"
/etc/tlp.d/00-amd.conf L0011: WIFI_PWR_ON_BAT="off"
/etc/tlp.d/00-amd.conf L0012: SOUND_POWER_SAVE_ON_AC="0"
/etc/tlp.d/00-amd.conf L0014: SOUND_POWER_SAVE_CONTROLLER="N"
/etc/tlp.d/00-amd.conf L0015: RUNTIME_PM_ON_AC="auto"
/etc/tlp.d/00-amd.conf L0016: RESTORE_THRESHOLDS_ON_BAT="1"
/etc/tlp.d/00-amd.conf L0020: DEVICES_TO_DISABLE_ON_STARTUP="bluetooth"
/etc/tlp.d/00-amd.conf L0021: START_CHARGE_THRESH_BAT0="60"
/etc/tlp.d/00-amd.conf L0022: STOP_CHARGE_THRESH_BAT0="80"
/etc/tlp.d/00-amd.conf L0023: DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="bluetooth"
/etc/tlp.d/00-amd.conf L0024: CPU_DRIVER_OPMODE_ON_AC="guided"
/etc/tlp.d/00-amd.conf L0025: CPU_DRIVER_OPMODE_ON_BAT="active"
/etc/tlp.d/00-amd.conf L0026: CPU_DRIVER_OPMODE_ON_SAV="active"
/etc/tlp.d/00-amd.conf L0027: DEVICES_TO_DISABLE_ON_LAN_CONNECT="wifi wwan"
/etc/tlp.d/00-amd.conf L0028: DEVICES_TO_ENABLE_ON_LAN_DISCONNECT="wifi"
/etc/tlp.d/00-amd.conf L0029: CPU_BOOST_ON_AC="1"
/etc/tlp.d/00-amd.conf L0030: CPU_BOOST_ON_BAT="1"
/etc/tlp.d/00-amd.conf L0031: CPU_BOOST_ON_SAV="0"
+++ Processor
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor  = schedutil
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = performance schedutil
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq  =  4976000 [kHz]
/sys/devices/system/cpu/amd_pstate/status              = guided
/etc/tlp.d/00-amd.conf L0024: CPU_DRIVER_OPMODE_ON_AC="active"
+++ Processor
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = performance [EPP]
root@t14:~#
root@t14:~# tlp start
/etc/tlp.d/00-amd.conf L0024: CPU_DRIVER_OPMODE_ON_AC="passive"
+++ Processor
/sys/devices/system/cpu/amd_pstate/status              = passive
Oder verstehe ich da was falsch?
@mcb ja, tust Du. EPP gibt es beim amd-pstate im Passive Mode schlicht nicht. Man sieht das, wenn man deine Ausgaben vergleicht. Ich rate von der Umschalterei active <-> passive ausdrücklich ab und möchte auch zu dabei auftretenden Merkwürdigkeiten nichts sagen.
Tut es doch auch in genau
Danke.
Irgendwas versteheich da (noch) nicht.
Edit: Ich habe meinen Fehler gefunden. Works as designed!
Cool es kommt wohl bald die Beta:
marc@t14:~$ apt list --upgradable
tlp-pd/stable,stable 1.9.0~beta.1-1 all [upgradable from: 1.9.0~alpha.3+20251102-1]
tlp-rdw/stable,stable 1.9.0~beta.1-1 all [upgradable from: 1.9.0~alpha.3+20251102-1]
tlp/stable,stable 1.9.0~beta.1-1 all [upgradable from: 1.9.0~alpha.3+20251102-1]
marc@t14:~$
(y)
Frische logs:
Status
