Linux [TLP 1.9 Alpha] Testergebnisse
Linux Betriebssystem
Status
mcb
18 März 2009
Alle Informationen zur Alpha gibt es hier: https://thinkpad-forum.de/threads/tlp-1-9-alpha-testergebnisse.244864/#post-2448200
@linrunner
Ich hatte mal Testlust, also hier eine Rückmeldung das die 1.9 gut funktioniert:
root@t14:~# tlp performance && tlp-stat -p -g -r
TLP started using profile performance/AC (auto).
--- TLP 1.9.0-alpha.2_46fe058 --------------------------------------------
+++ Processor
CPU model = AMD Ryzen 5 PRO 7540U w/ Radeon 740M Graphics
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver    = amd-pstate-epp
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor  = powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq  =   400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq  =   400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq  =   400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq  =  4976000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/amd_pstate_lowest_nonlinear_freq  =  1115000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/amd_pstate_max_freq               =  4976000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = balance_performance [EPP]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu1..cpu11: omitted for clarity, use -v to show all
/sys/devices/system/cpu/amd_pstate/status              = active
/sys/devices/system/cpu/cpufreq/boost                  = 1
/sys/module/workqueue/parameters/power_efficient       = N
/proc/sys/kernel/nmi_watchdog                          = 0
+++ Platform Profile
/sys/firmware/acpi/platform_profile                    = performance
/sys/firmware/acpi/platform_profile_choices            = low-power balanced performance
/sys/devices/platform/thinkpad_acpi/dytc_lapmode       = 0
+++ AMD Radeon Graphics
/sys/class/drm/card0/device/driver                                = amdgpu
/sys/class/drm/card0/device/power_dpm_force_performance_level     = auto
/sys/class/drm/card0/card0-eDP-1/amdgpu/panel_power_savings       = 0
+++ Wireless
bluetooth = off (software)
nfc       = none (no device)
wifi      = on
wwan      = none (no device)
wlp2s0(ath11k_pci)            : wifi, connected, power management = on
root@t14:~# tlp power-saver && tlp-stat -p -g -r
TLP started using profile power-saver/SAV (auto).
+++ Processor
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq  =  3201000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = power [EPP]
/sys/devices/system/cpu/cpufreq/boost                  = 0
/sys/firmware/acpi/platform_profile                    = low-power
+++ Wireless
wifi      = on
wlp2s0(ath11k_pci)            : wifi, connected, power management = off
root@t14:~# tlp balanced && tlp-stat -p -g -r
TLP started using profile balanced/BAT (auto).
+++ Processor
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = balance_power [EPP]
/sys/firmware/acpi/platform_profile                    = balanced
+++ Wireless
wifi      = on
root@t14:~# tlp-stat --cdiff
+++ Configured Settings (only differences to defaults):
/etc/tlp.d/00-amd.conf L0005: DISK_DEVICES="nvme0n1 sda sdb"
/etc/tlp.d/00-amd.conf L0007: AMDGPU_ABM_LEVEL_ON_BAT="0"
/etc/tlp.d/00-amd.conf L0008: WIFI_PWR_ON_AC="on"
/etc/tlp.d/00-amd.conf L0009: WIFI_PWR_ON_BAT="off"
/etc/tlp.d/00-amd.conf L0010: SOUND_POWER_SAVE_ON_AC="0"
/etc/tlp.d/00-amd.conf L0012: SOUND_POWER_SAVE_CONTROLLER="N"
/etc/tlp.d/00-amd.conf L0013: RUNTIME_PM_ON_AC="auto"
/etc/tlp.d/00-amd.conf L0014: RESTORE_THRESHOLDS_ON_BAT="1"
/etc/tlp.d/00-amd.conf L0015: DEVICES_TO_ENABLE_ON_STARTUP="wifi"
/etc/tlp.d/00-amd.conf L0019: DEVICES_TO_DISABLE_ON_STARTUP="bluetooth"
/etc/tlp.d/00-amd.conf L0020: START_CHARGE_THRESH_BAT0="60"
/etc/tlp.d/00-amd.conf L0021: STOP_CHARGE_THRESH_BAT0="80"
/etc/tlp.d/00-amd.conf L0022: DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="bluetooth"
/etc/tlp.d/00-amd.conf L0023: CPU_DRIVER_OPMODE_ON_AC="active"
/etc/tlp.d/00-amd.conf L0024: CPU_DRIVER_OPMODE_ON_BAT="active"
/etc/tlp.d/00-amd.conf L0025: DEVICES_TO_DISABLE_ON_LAN_CONNECT="wifi wwan"
/etc/tlp.d/00-amd.conf L0026: DEVICES_TO_ENABLE_ON_LAN_DISCONNECT="wifi"
/etc/tlp.d/00-amd.conf L0027: CPU_BOOST_ON_AC="1"
/etc/tlp.d/00-amd.conf L0028: CPU_BOOST_ON_BAT="0"
(Trixie-Live-System mit den neusten Alpha-Paketen)
Direkt nach dem Start:
Klick auf "Performance":
Klick auf "Balanced":
Klick auf "Power saver":
--> Umschalten in der Taskleiste via GUI funktioniert reibungslos.
Moin. Es gibt frische Testpakete mit einem neuen Tool für die Shell namens tlpctl (abgeleitet von powerprofilesctl):
Funktioniert weitgehend, aber folgende Beobachtung (unter Cinnamon):
Bash:
user@debian:~$ tlpctl get
performance
user@debian:~$ sudo tlp balanced
balanced
Die GUI in der Taskleiste zum Profil auswählen aktualisiert sich / zeigt das richtige Profil an.
Aber:
Bash:
balanced
user@debian:~$ tlpctl set performance
Namespace(command='set', profile=['performance'], func=<function command.<locals>.wrapper at 0x7f47256304a0>)
performance
Die GUI in der Taskleiste zum Profil auswählen aktualisiert sich nicht / zeigt weiterhin das vorherige Profil ("Balanced") an.
Ich hab noch weit wichtigere Dinge auf der Todo-Liste, auch z.B. dein Wifi-aus-nach-dem-Hochfahren Problem ;)
Oh ja, das wäre cool.
Kurz durchgespielt:
tlpctl und die Gnome buttons laufen absolut syncron!
Debian GNU/Linux 13 (trixie) x86_64 / Gnome 48.4
Hi, ich wollte es auch mal ausprobieren:
Mein System:
+++ System Info
System = LENOVO ThinkPad P14s Gen 6 AMD 21RVCTO1WW
BIOS = R2XET30W (1.10 ) LENOVO
EC Firmware = 1.7
OS Release = CachyOS
Kernel = 6.17.5-2-cachyos #1 SMP PREEMPT_DYNAMIC Sat, 25 Oct 2025 07:38:44 +0000 x86_64
/proc/cmdline = quiet nowatchdog splash rw rootflags=subvol=/@ cryptdevice=UUID=1c262729-00e0-4453-b489-45391f4be8ac:luks-1c262729-00e0-4453-b489-45391f4be8ac root=/dev/mapper/luks-1c262729-00e0-4453-b489-45391f4be8ac
Init system = systemd 258
Boot mode = UEFI
Suspend mode = [s2idle]
DE: KDE Plasma 6.5.0
WM: KWin (Wayland)
nach reboot:
nach klick auf 'balanced'
nach klick auf 'power-save'
nach klick auf 'performance'
Am Desktop prüfen ob beim Wechsel vom Netzteil zum Akkubetrieb und zurück das Profil entsprechend wechselt, d.h. Netzteil = performance, Akku = balanced
Funktioniert!
Zur Feier des Dienstags gibt es frische Pakete 😎
Was sich geändert hat:
  • tlpctl wurde um einige Befehle erleichtert, die p-p-d beherrscht, tlp-pd aber nicht (braucht eh keiner)
  • tlpctl hat eine Manpage und Shell Completions (Bash, ZSH, Fish) bekommen
  • Jede Menge Kleinkram, z.B. Meldungstexte verbessert, auch im Syslog. Einzelheiten siehe Commit Historie.
Um eure offenen Problemmeldungen hab ich mich gekümmert:
Fall B ich starte an der Dock -> Lan ist aktiv -> ich stöpsel ab -> WLan ist aus (Gnome) TLP meint Wifi ist an.
Ich muß es dann in den Gnome Settings anschalten, danach funktioniert es wie in Fall A.
Die Diskrepanz zwischen GNOME (genauer: NetworkManager) und TLP (fragt rfkill) kann jetzt nicht mehr auftreten. Warum dein WiFi beim Start aus ist, weiss ich nicht. Einschalten per DEVICES_TO_ENABLE_ON_STARTUP="wifi" sollte jetzt zumindest klappen.
user@debian:~$ tlpctl get performance user@debian:~$ sudo tlp balanced TLP started using profile balanced/BAT (auto). user@debian:~$ tlpctl get balancedDie GUI in der Taskleiste zum Profil auswählen aktualisiert sich / zeigt das richtige Profil an.
Aber:
user@debian:~$ tlpctl get balanced user@debian:~$ tlpctl set performance Namespace(command='set', profile=['performance'], func=<function command.<locals>.wrapper at 0x7f47256304a0>) user@debian:~$ tlpctl get performanceDie GUI in der Taskleiste zum Profil auswählen aktualisiert sich nicht / zeigt weiterhin das vorherige Profil ("Balanced") an.
Dein Problem, dass tlpctl die Synchronisation TLP <-> Desktop unter Cinnamon stört, habe ich gefixt.
Was ich euch bitte anzuschauen/auszuprobieren:
  • Test des Profilwechsels per Klick/tlpctl - Ausgaben nur wenn euch etwas auffällt, es kommt ja noch der Beta-Test ...
  • Die neue Manpage tlpctl (1), die Updates von tlp (8), tlp-stat (8) und, falls ihr viel Zeit habt, gerne auch changelog und tlp.conf auf Typos und andere Fehler prüfen. Das sehe ich selbst einfach nicht mehr ... 🤪 Falls ihr was findet, nehme ich gerne auch einen Pull Request.
  • tlpctl launch könnt ihr gerne mal ausprobieren, Infos siehe Manpage
  • Die Shell Completions von tlpctl - bitte nur mit eurer "Daily Shell", mit der ihr euch auskennt, sonst kommen zuviele Fragen ...
Vielen Dank im voraus!
Hab TLP nochmal aus dem AUR gezogen, der Name ist noch der gleiche, aber installiert ist das aktualisierte Alpha Paket.
tlp-pd blieb unverändert. tlpctl hab ich allerdings weder in den üblichen Repos noch im AUR gefunden. War das etwa ausschließlich für Debian vorgesehen?
Bitte den Hinweis auf meiner Downloadseite beachten: Du musst das inoffizelle Paket tlp-git aus dem AUR jedesmal neu bauen, damit es den neusten Stand von GitHub zieht. Das gehört so. Yay fragt doch sowieso danach. Das offizlelle Paket tlp bekommt 1.9.0 erst nach dem Release.
@jive willkommen im Forum!:)
Die Complementierung funktioniert sehr schön!
Vielen Dank für die ganze Mühe!
Ich habe Fall B durchgespielt. TLP meint nun ich hätte keinen WLan device (auch nach dem Abstöpseln). Log so gut es geht:
Ich versuche es jetzt mal mit folgenden Settings:
tlp-stat --cdiff
--- TLP 1.9.0-alpha.3_86edd81 --------------------------------------------
/etc/tlp.d/00-amd.conf L0007: DISK_DEVICES="nvme0n1 sda sdb"
/etc/tlp.d/00-amd.conf L0009: AMDGPU_ABM_LEVEL_ON_BAT="0"
/etc/tlp.d/00-amd.conf L0010: WIFI_PWR_ON_AC="on"
/etc/tlp.d/00-amd.conf L0011: WIFI_PWR_ON_BAT="off"
/etc/tlp.d/00-amd.conf L0012: SOUND_POWER_SAVE_ON_AC="0"
/etc/tlp.d/00-amd.conf L0014: SOUND_POWER_SAVE_CONTROLLER="N"
/etc/tlp.d/00-amd.conf L0015: RUNTIME_PM_ON_AC="auto"
/etc/tlp.d/00-amd.conf L0016: RESTORE_THRESHOLDS_ON_BAT="1"
/etc/tlp.d/00-amd.conf L0021: DEVICES_TO_DISABLE_ON_STARTUP="bluetooth"
/etc/tlp.d/00-amd.conf L0022: START_CHARGE_THRESH_BAT0="60"
/etc/tlp.d/00-amd.conf L0023: STOP_CHARGE_THRESH_BAT0="80"
/etc/tlp.d/00-amd.conf L0024: DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="bluetooth"
/etc/tlp.d/00-amd.conf L0025: CPU_DRIVER_OPMODE_ON_AC="active"
/etc/tlp.d/00-amd.conf L0026: CPU_DRIVER_OPMODE_ON_BAT="active"
/etc/tlp.d/00-amd.conf L0028: DEVICES_TO_DISABLE_ON_LAN_CONNECT="wifi wwan"
/etc/tlp.d/00-amd.conf L0029: DEVICES_TO_ENABLE_ON_LAN_DISCONNECT="wifi"
/etc/tlp.d/00-amd.conf L0030: CPU_BOOST_ON_AC="1"
/etc/tlp.d/00-amd.conf L0031: CPU_BOOST_ON_BAT="1"
/etc/tlp.d/00-amd.conf L0032: CPU_BOOST_ON_SAV="0"
/etc/tlp.d/00-amd.conf L0033: TLP_DEBUG="lock nm rf run"
Gnome scheint die Karte komplett auszuknipsen.
Der Rest läuft.
Das klingt spannend:
 launch              Run a command using a specific power profile (hold)
Hatte noch keine Idee.
Gerne doch, das WiFi läuft gerade:
marc@t14:~$ nmcli radio
WIFI-HW  WIFI     WWAN-HW  WWAN
enabled  enabled  missing  enabled
marc@t14:~$ nmcli radio wifi
enabled
marc@t14:~$ /usr/sbin/rfkill
ID TYPE      DEVICE                   SOFT      HARD
 0 bluetooth tpacpi_bluetooth_sw   blocked unblocked
 1 wlan      phy0                unblocked unblocked
marc@t14:~$ wifi
wifi      = on
@mcb deine Daten in Post #65 sind nicht konsistent. Du zeigst eine Config, die Du nach dem Boot geändert hast. Sagst Du ja auch. Zudem ist unklar, was zwischen Post #65 und #67 mit dem WiFi passierte.
Daher bitte nochmal alles zusammenpassend für Fall B = Dock mit LAN-Kabel (die Config von oben bitte nicht verändern):
1. Kaltstart
2. Ausgaben nach dem Anmelden
nmcli radio
nmcli radio wifi
/usr/sbin/rfkill
wifi
sudo tlp-stat --cdiff --trace-nm # Schalter extra für dich eingebaut ;-)
1. Kaltstart
marc@t14:~/tlp/log$ nmcli radio
enabled  disabled  missing  enabled
marc@t14:~/tlp/log$ nmcli radio wifi
disabled
marc@t14:~/tlp/log$ /usr/sbin/rfkill
marc@t14:~/tlp/log$ wifi
wifi      = none (no device)
marc@t14:~/tlp/log$ sudo tlp-stat --cdiff --trace-nm >fall_b_mit_neuer_config.txt
marc@t14:~/tlp/log$
Dann das Dock abgezogen:
disabled
marc@t14:~/tlp/log$
Nachfolgend:
WiFi unter Gnome angeschaltet:
enabled
wifi      = on
marc@t14:~/tlp/log$
Noch ein Log:
Hoffe das hilft weiter.
Moin, ich habe die neuen Pakete drauf und es läuft soweit gut, wie es aussieht.
Danke @linrunner für für all deine Mühen und Kudos für die tolle App...
Mein ThinkPad: X280/16GB
MX-Linux-23.6--KDE
OS Release = Debian GNU/Linux 12 (bookworm)
Kernel = 6.1.0-40-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.153-1 (2025-09-20)
KDE-Plasma-Version: 5.27.5
Grafik-Plattform: X11
Wechsel vom Netzteil zum Akkubetrieb , d.h. Netzteil = performance, Akku = balanced klappt auch ohne Problem, super.
Was halt schade für mich ist, dass TLP UI nicht mehr geht....aber dafür kannst du natürlich nichts. Das war für mich Maus-Schubser schon praktisch, aber ich denke, da wird noch dran gearbeitet, hoffe ich.
Unter Debian 12 mit Gnome zeigt das Applet hier auch den richtigen Mode an.
disabled
Da hatte ich leider einen neuen Fehler eingebaut. Ist in den eben hochgeladenen Paketen gefixt. Bitte nochmal Fall B mit Kabel:
1. Kaltstart
Bash:
sudo tlp-stat --cdiff --trace-nm # --trace-nm gibt jetzt auch die NM/rfkill Infos mit aus
3. Nach dem Abdocken
Bash:
tlp-stat -r -v # -v gibt jetzt auch die NM/rfkill Infos mit aus
Danke für's Testen. Damit ist KDE Plasma 5.x auch erfolgreich getestet. (y)
Ist leider nicht meine Baustelle.
(y)tlpctl launch xxx tut unter Debian 13!
Error: command 'xxx' not found
[Errno 2] No such file or directory: 'xxx'
:ROFLMAO:😉
Gut zu wissen. (y)
1. Kaltstart
Es sieht gut aus!
marc@t14:~/tlp/log$ sudo tlp-stat --cdiff --trace-nm >kaltstart.txt
[sudo] password for marc:
marc@t14:~/tlp/log$ tlp-stat -r -v >k_abdocken.txt
wifi      = on
marc@t14:~/tlp/log$
Lieber im Betatest dann. Vom Chromebook würde mir jetzt die Ausgabe im Profile power-saver reichen.
Hier alle drei für das T480:
performance:
balanced:
power-saver:
Habe das schonmal irgendwo ähnlich an einer anderen Stelle geschrieben, bei einem anderen Alpha-/Beta-Test glaube ich: An der Stelle wo TLPPCI aufgerufen wird gibt es bei "balanced" und "power-saver" eine kurze Bedenkpause von ner knappen Sekunde, bevor der Rest der Ausgaben erscheint (bezogen auf das T480).
Auch mit aktuellem KDE Plasma 6.5.1 Debian Sid auf T14 Gen1 AMD funktioniert alles wie es soll. Aber kriegst das Gerät ja eh morgen beim TP-Treffen Hannover in die Finger ;)
KDE-Plasma-Version: 6.5.1
KDE-Frameworks-Version: 6.18.0
Qt-Version: 6.9.2
Grafik-Plattform: Wayland
#  tlp-stat -s
--- TLP 1.9.0-alpha.3_662e8d0 --------------------------------------------
+++ System Info
System         = LENOVO ThinkPad T14 Gen 1 20UD0013GE
BIOS           = R1BET82W(1.51 ) LENOVO
EC Firmware    = 1.51
OS Release     = Debian GNU/Linux forky/sid
Kernel         = 6.17.6-1-siduction-amd64 #1 SMP PREEMPT_DYNAMIC siduction 6.17-6 (2025-10-29) x86_64
/proc/cmdline  = BOOT_IMAGE=/boot/vmlinuz-6.17.6-1-siduction-amd64 root=UUID=c1cdacf7-a143-439c-82d7-75a3d5193cac ro quiet systemd.show_status=auto kvm.enable_virt_at_load=0
Boot mode      = UEFI
Suspend mode   = s2idle [deep]
SELinux status = disabled
+++ TLP Status
tlp            = enabled, last run: 21:22:34, 284 sec(s) ago
tlp-rdw        = enabled
tlp-pd         = enabled, running
Power profile  = power-saver/SAV
Power source   = battery
Hast Du jetzt also nochmal entdeckt. Mein X1 dieser Generation hat es auch. Die Verzögerung entsteht in lspci. Ich vermute, es müssen fürs Datenauslesen Devices erst aufgeweckt werden. Kein Bug.
Status
