Linux [TLP 1.9 Alpha] Testergebnisse
Linux Betriebssystem
Status
mcb
18 März 2009
Alle Informationen zur Alpha gibt es hier: https://thinkpad-forum.de/threads/tlp-1-9-alpha-testergebnisse.244864/#post-2448200
@linrunner
Ich hatte mal Testlust, also hier eine Rückmeldung das die 1.9 gut funktioniert:
root@t14:~# tlp performance && tlp-stat -p -g -r
TLP started using profile performance/AC (auto).
--- TLP 1.9.0-alpha.2_46fe058 --------------------------------------------
+++ Processor
CPU model = AMD Ryzen 5 PRO 7540U w/ Radeon 740M Graphics
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver    = amd-pstate-epp
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor  = powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = performance powersave
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq  =   400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq  =   400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq  =   400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq  =  4976000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/amd_pstate_lowest_nonlinear_freq  =  1115000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/amd_pstate_max_freq               =  4976000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = balance_performance [EPP]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_available_preferences = default performance balance_performance balance_power power
/sys/devices/system/cpu/cpu1..cpu11: omitted for clarity, use -v to show all
/sys/devices/system/cpu/amd_pstate/status              = active
/sys/devices/system/cpu/cpufreq/boost                  = 1
/sys/module/workqueue/parameters/power_efficient       = N
/proc/sys/kernel/nmi_watchdog                          = 0
+++ Platform Profile
/sys/firmware/acpi/platform_profile                    = performance
/sys/firmware/acpi/platform_profile_choices            = low-power balanced performance
/sys/devices/platform/thinkpad_acpi/dytc_lapmode       = 0
+++ AMD Radeon Graphics
/sys/class/drm/card0/device/driver                                = amdgpu
/sys/class/drm/card0/device/power_dpm_force_performance_level     = auto
/sys/class/drm/card0/card0-eDP-1/amdgpu/panel_power_savings       = 0
+++ Wireless
bluetooth = off (software)
nfc       = none (no device)
wifi      = on
wwan      = none (no device)
wlp2s0(ath11k_pci)            : wifi, connected, power management = on
root@t14:~# tlp power-saver && tlp-stat -p -g -r
TLP started using profile power-saver/SAV (auto).
+++ Processor
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq  =  3201000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = power [EPP]
/sys/devices/system/cpu/cpufreq/boost                  = 0
/sys/firmware/acpi/platform_profile                    = low-power
+++ Wireless
wifi      = on
wlp2s0(ath11k_pci)            : wifi, connected, power management = off
root@t14:~# tlp balanced && tlp-stat -p -g -r
TLP started using profile balanced/BAT (auto).
+++ Processor
/sys/devices/system/cpu/cpu0/cpufreq/energy_performance_preference = balance_power [EPP]
/sys/firmware/acpi/platform_profile                    = balanced
+++ Wireless
wifi      = on
root@t14:~# tlp-stat --cdiff
+++ Configured Settings (only differences to defaults):
/etc/tlp.d/00-amd.conf L0005: DISK_DEVICES="nvme0n1 sda sdb"
/etc/tlp.d/00-amd.conf L0007: AMDGPU_ABM_LEVEL_ON_BAT="0"
/etc/tlp.d/00-amd.conf L0008: WIFI_PWR_ON_AC="on"
/etc/tlp.d/00-amd.conf L0009: WIFI_PWR_ON_BAT="off"
/etc/tlp.d/00-amd.conf L0010: SOUND_POWER_SAVE_ON_AC="0"
/etc/tlp.d/00-amd.conf L0012: SOUND_POWER_SAVE_CONTROLLER="N"
/etc/tlp.d/00-amd.conf L0013: RUNTIME_PM_ON_AC="auto"
/etc/tlp.d/00-amd.conf L0014: RESTORE_THRESHOLDS_ON_BAT="1"
/etc/tlp.d/00-amd.conf L0015: DEVICES_TO_ENABLE_ON_STARTUP="wifi"
/etc/tlp.d/00-amd.conf L0019: DEVICES_TO_DISABLE_ON_STARTUP="bluetooth"
/etc/tlp.d/00-amd.conf L0020: START_CHARGE_THRESH_BAT0="60"
/etc/tlp.d/00-amd.conf L0021: STOP_CHARGE_THRESH_BAT0="80"
/etc/tlp.d/00-amd.conf L0022: DEVICES_TO_DISABLE_ON_BAT_NOT_IN_USE="bluetooth"
/etc/tlp.d/00-amd.conf L0023: CPU_DRIVER_OPMODE_ON_AC="active"
/etc/tlp.d/00-amd.conf L0024: CPU_DRIVER_OPMODE_ON_BAT="active"
/etc/tlp.d/00-amd.conf L0025: DEVICES_TO_DISABLE_ON_LAN_CONNECT="wifi wwan"
/etc/tlp.d/00-amd.conf L0026: DEVICES_TO_ENABLE_ON_LAN_DISCONNECT="wifi"
/etc/tlp.d/00-amd.conf L0027: CPU_BOOST_ON_AC="1"
/etc/tlp.d/00-amd.conf L0028: CPU_BOOST_ON_BAT="0"
Spannend. Um vergleichbar zu bleiben, habe ich die Aufrufe von @mcb einmal übernommen.
X395:
+++ Processor
CPU model = AMD Ryzen 5 PRO 3500U w/ Radeon Vega Mobile Gfx
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver    = acpi-cpufreq
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor  = ondemand
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = ondemand performance schedutil
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq  =  1400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq  =  2100000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies = 2100000 1700000 1400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_min_freq  =  1400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq  =  2100000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/bios_limit        =  2100000 [kHz]
/sys/devices/system/cpu/cpu1..cpu7: omitted for clarity, use -v to show all
/sys/firmware/acpi/platform_profile                    = (not available)
/sys/firmware/acpi/platform_profile_choices            = (not available)
/sys/devices/platform/thinkpad_acpi/dytc_lapmode       = (not available)
+++ Wireless
bluetooth = on
wifi      = on
wwan      = on
hci0(btusb)                   : bluetooth, not connected
wlp1s0(iwlwifi)               : wifi, connected, power management = off
wwan0()                       : wwan, not connected
+++ Processor
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor  = conservative
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_governors = conservative ondemand performance schedutil
/sys/class/drm/card0/card0-eDP-1/amdgpu/panel_power_savings       = 1
+++ Wireless
bluetooth = on
wifi      = on
wwan      = on
wlp1s0(iwlwifi)               : wifi, connected, power management = on
+++ Processor
+++ Wireless
bluetooth = on
wifi      = on
wwan      = on
~# tlp-stat --cdiff
/etc/tlp.conf L0119: CPU_SCALING_GOVERNOR_ON_AC="ondemand"
/etc/tlp.conf L0121: CPU_SCALING_GOVERNOR_ON_BAT="conservative"
/etc/tlp.conf L0171: CPU_BOOST_ON_AC="1"
/etc/tlp.conf L0172: CPU_BOOST_ON_BAT="0"
Wenn eines meiner Oldies T60 mit ATI, R60, X61, X200, T500 ran sollen, gib einfach kurz Bescheid.
UPDATE 15.10.2025: tlp-pd ergänzt
bevor der offizielle Beta-Test beginnt, dürft ihr gerne jederzeit die laufende Entwicklung (main Branch == Alpha Version) ausprobieren und die unten beschriebenen Ausgaben zeigen.
Habt keine Angst vor einer Alpha-Version, der main Branch wird von mir vor dem Push nach GitHub bereits ausführlich getestet und ich verwende ihn auf allen meinen ThinkPads produktiv.
Was hat sich geändert seit 1.8.0?
Die wesentlichste Neuerung ist die Vorbereitung für Power Profiles, sprich: die Einführung eines dritten Konfigurationsprofils für maximale Energieeinsparungen. Folgende Profile sind nun verfügbar:
  • performance: Parameter, die auf _AC enden, werden verwendet, wenn das Netzteil angeschlossen ist oder wenn der neue Befehl tlp performance ausgeführt wird.
  • balanced: Parameter, die auf _BAT enden, werden verwendet, wenn das Gerät im Akkubetrieb läuft oder wenn der neue Befehl tlp balanced ausgeführt wird.
  • power-saver: Parameter, die auf _SAV enden, werden verwendet, wenn der neue Befehl tlp power-saver ausgeführt wird. Wenn für eine Funktion kein _SAV-Parameter verfügbar ist, wird stattdessen der _BAT-Parameter verwendet.
Wichtig: eure bisherige Konfiguration könnt ihr beibehalten und nach Wunsch mit _SAV Parametern ergänzen.
TLP Power Profiles Daemon (tlp-pd)
Die ergänzten und umbenannten Profile haben natürlich einen tieferen Sinn: TLP wird mit Release 1.9 um den TLP Profiles Daemon (tlp-pd) ergänzt. Dieser stellt die D-Bus-Schnittstelle bereit, über die gängige Desktop-Umgebungen einen Schalter zur Wahl der oben genannten Profile anzeigen (oder wie sie auch immer in der Übersetzung heißen). Zusammen mit TLP als Backend ersetzt tlp-pd also den power-profiles-daemon.
TL;DR: Ab sofort kann das gewünschte Profil per Mausklick gewählt werden, statt per Kommandozeile (mit sudo). Die automatische Umschaltung beim Wechsel der Stromquelle bleibt jedoch erhalten (und spiegelt sich im Desktop-Schalter wieder)
Unterstützte Desktops sind, soweit ich recherchiert habe:
  • GNOME
  • KDE
  • Cinnamon (erst ab 6.4!)
  • LXQt
Man könnte sagen, TLP bekommt eine GUI, ohne dass ich eine programmiert hätte. Die Desktops können das nämlich schon ;).
Alle weiteren Neuerungen siehe Changelog.
Alpha Pakete (Arch, Debian, Ubuntu)
Siehe Download Seite.
Bei Debian/Ubuntu könnt (solltet) ihr eure vorhandene Konfiguration übernehmen, in dem ihr während der Paketinstallation beim Prompt "Configuration file /etc/tlp.conf" mit 'N' (für "keep your currently-installed version") antwortet.
Testschritte / Benötigte Angaben
  1. Nach der Installation Rechner bitte neu starten.
  2. Am Desktop nacheinander die drei Profile anklicken und jedesmal die Ausgabe von sudo tlp-stat zeigen
  3. Am Desktop prüfen ob beim Wechsel vom Netzteil zum Akkubetrieb und zurück das Profil entsprechend wechselt, d.h. Netzteil = performance, Akku = balanced
  4. Nur falls ihr tlp-pd nicht installieren möchtet/könnt oder es mit eurem Desktop nicht funktioniert:
    bitte manuell per tlp performance/balanced/power-saver umschalten und danach jeweils sudo tlp-stat zeigen
  5. Zusätzlich muss ich wissen, welchen Desktop/Version ihr am Start habt
Aufgrund der Längenbegrenzung des Forumseditors Ausgaben bitte per Paste-Service - vorzugsweise https://gist.github.com/
Fehlerberichte
Wenn etwas nicht wie erwartet funktionieren sollte oder Fragen sind → bitte hier im Thread melden.
Abgrenzung: alles was mit TLP Version < 1.9 zu tun hat, gehört hier nicht rein, sondern in den regulären Support-Thread.
Infos
@mcb könnest Du bitte ganz oben in deinem ersten Post per Link auf Post #4 verweisen? Die Forensoftware kann Zusammenführung anscheinend nur chronologisch. Danke.
@mcb, @Ravensberger : Danke fürs Testen und eure Ausgaben. Wenn ihr fallweise nur Teile der tlp-stat-Ausgabe postet,
bitte immer den Schalter -s hinzufügen, damit alle Angaben zum System dabei sind.
Das WLan ist nach eimem Kaltstart an der Dock immer aus, wenn ich das Thinkpad abziehe. War das schon immer so (unter 1.8 dasselbe). Minnor Problem.
Ich unterstelle ein LAN-Kabel am Dock. Wie ist der genaue Ablauf?
  1. WiFi ist aus nach dem Kaltstart?
  2. Ist das ThinkPad zugeklappt oder offen beim Abdocken?
  3. Ist das ThinkPad vielleicht im Suspend beim Abdocken?
Ich meine mich zu erinnern, dass Debian manchmal mit 1. ein Problem hat, d.h. WiFi nicht aus ist.
Ich hatte selbst ein Problem mit 3. - NetworkManager macht da komische Sachen - und habe in 1.8 einen Workaround dafür eingebaut.
Ja Wifi ist immer an beim booten (bis Gnome).
- suspend & standby sind komplett aus und ja an der Dock ist ein Netzwerkkabel ;-)
Fall A ich starte das TP ohne Dock -> WLan ist an und wird deaktiviert wenn ich die Dock anstecke (TP läuft)
Fall B ich starte an der Dock -> Lan ist aktiv -> ich stöpsel ab -> WLan ist aus (Gnome) TLP meint Wifi ist an.
Ich muß es dann in den Gnome Settings anschalten, danach funktioniert es wie in Fall A.
Fall A läuft ohne Probleme also wie ich mir das vorstelle. Für Fall B kann ich aber keine Einstellungen mehr finden.
Danke
@mcb: dann können wir Fall B mal mit Trace durchspielen und zusätzlich schauen was der NM so treibt.
Konfiguration:
Bash:
TLP_DEBUG="lock nm rf run"
Nach dem Abdocken zeige:
Bash:
journalctl -p debug -t tlp -t NetworkManager -b 0
Super!
pts/2
root@t14:~# TLP_DEBUG="lock nm rf run"
root@t14:~# journalctl -p debug -t tlp -t NetworkManager -b 0
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.3471] NetworkManager (version 1.52.1) is >
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.3471] Read config: /etc/NetworkManager/Ne>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.3534] manager[0x56221de3a4e0]: monitoring>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.3535] monitoring ifupdown state file '/ru>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4417] hostname: hostname: using hostnamed
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4417] hostname: static hostname changed f>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4421] dns-mgr: init: dns=default,systemd->
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4428] manager[0x56221de3a4e0]: rfkill: Wi>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4429] manager[0x56221de3a4e0]: rfkill: WW>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4473] Loaded device plugin: NMBluezManage>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4482] Loaded device plugin: NMWifiFactory>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4488] Loaded device plugin: NMAtmManager >
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4509] Loaded device plugin: NMTeamFactory>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4513] Loaded device plugin: NMWwanFactory>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4514] manager: rfkill: Wi-Fi enabled by r>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4515] manager: rfkill: WWAN enabled by ra>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4515] manager: Networking is enabled by s>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4524] settings: Loaded settings plugin: i>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4524] settings: Loaded settings plugin: k>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4524] ifupdown: management mode: unmanaged
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4524] ifupdown:       interface-parser: p>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4524] ifupdown:       interface-parser: s>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4525] ifupdown: interfaces file /etc/netw>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4525] ifupdown:       interface-parser: f>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4557] dhcp: init: Using DHCP client 'inte>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4558] manager: (lo): new Loopback device >
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4565] device (lo): state change: unmanage>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4568] device (lo): state change: unavaila>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4571] device (lo): Activation: starting c>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4577] manager: (enp1s0f0): new Ethernet d>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.4579] device (enp1s0f0): state change: un>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.6020] bus-manager: acquired D-Bus service>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.6032] device (lo): state change: disconne>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.6033] device (lo): state change: prepare >
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.6034] device (lo): state change: config ->
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.6037] modem-manager: oFono is not availab>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.6038] device (lo): state change: ip-confi>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.6045] modem-manager: ModemManager availab>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.6050] device (lo): state change: ip-check>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.6051] device (lo): state change: secondar>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.6054] device (lo): Activation: successful>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.8735] device (wlan0): driver supports Acc>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.8740] manager: (wlan0): new 802.11 Wi-Fi >
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.8748] rfkill1: found Wi-Fi radio killswit>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.8750] manager: rfkill: Wi-Fi now disabled>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.8847] device (wlan0): interface index 3 r>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.8929] device (wlp2s0): state change: unma>
Sep 24 11:19:45 t14 NetworkManager[1838]: <info>  [1758705585.8934] device (wlp2s0): set-hw-addr: set M>
Sep 24 11:19:48 t14 NetworkManager[1838]: <info>  [1758705588.9623] manager: (eth0): new Ethernet devic>
Sep 24 11:19:49 t14 NetworkManager[1838]: <info>  [1758705589.0605] device (eth0): interface index 4 re>
Sep 24 11:19:49 t14 NetworkManager[1838]: <info>  [1758705589.0703] device (enx0050b6b7b983): state cha>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.7728] device (enx0050b6b7b983): carrier: >
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.7738] device (enx0050b6b7b983): state cha>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.7743] policy: auto-activating connection >
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.7745] device (enx0050b6b7b983): Activatio>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.7746] device (enx0050b6b7b983): state cha>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.7747] manager: NetworkManager state is no>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.7747] device (enx0050b6b7b983): state cha>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.7750] device (enx0050b6b7b983): state cha>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.7754] dhcp4 (enx0050b6b7b983): activation>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.7860] dhcp4 (enx0050b6b7b983): state chan>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.9082] dhcp4 (enx0050b6b7b983): state chan>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.9094] policy: set 'Wired connection 1' (e>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.9635] device (enx0050b6b7b983): state cha>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.9657] device (enx0050b6b7b983): state cha>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.9658] device (enx0050b6b7b983): state cha>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.9660] manager: NetworkManager state is no>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.9661] device (enx0050b6b7b983): Activatio>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.9663] manager: NetworkManager state is no>
Sep 24 11:19:51 t14 NetworkManager[1838]: <info>  [1758705591.9665] manager: startup complete
Sep 24 11:19:52 t14 NetworkManager[1838]: <info>  [1758705592.8872] dhcp6 (enx0050b6b7b983): activation>
Sep 24 11:19:52 t14 NetworkManager[1838]: <info>  [1758705592.8884] policy: set 'Wired connection 1' (e>
Sep 24 11:19:52 t14 NetworkManager[1838]: <info>  [1758705592.9015] dhcp6 (enx0050b6b7b983): state chan>
Sep 24 11:19:53 t14 NetworkManager[1838]: <info>  [1758705593.1481] manager: rfkill: Wi-Fi now enabled >
Sep 24 11:19:53 t14 NetworkManager[1838]: <info>  [1758705593.7487] agent-manager: agent[d7d73501a31ccd>
Sep 24 11:19:54 t14 tlp[3173]: Applying power save settings...done.
Sep 24 11:19:54 t14 tlp[3173]: Setting battery charge thresholds...done.
Sep 24 11:19:54 t14 tlp[3173]: Disabling radios: bluetooth.
Sep 24 11:19:54 t14 tlp[3173]: Enabling radios: wifi.
Sep 24 11:20:04 t14 NetworkManager[1838]: <info>  [1758705604.6830] agent-manager: agent[e77b4c2e7a8b34>
Sep 24 11:21:24 t14 NetworkManager[1838]: <info>  [1758705684.2845] device (enx0050b6b7b983): state cha>
Sep 24 11:21:24 t14 NetworkManager[1838]: <info>  [1758705684.2846] dhcp4 (enx0050b6b7b983): canceled D>
Sep 24 11:21:24 t14 NetworkManager[1838]: <info>  [1758705684.2846] dhcp4 (enx0050b6b7b983): activation>
Sep 24 11:21:24 t14 NetworkManager[1838]: <info>  [1758705684.2846] dhcp4 (enx0050b6b7b983): state chan>
Sep 24 11:21:24 t14 NetworkManager[1838]: <info>  [1758705684.2847] dhcp6 (enx0050b6b7b983): canceled D>
Sep 24 11:21:24 t14 NetworkManager[1838]: <info>  [1758705684.2847] dhcp6 (enx0050b6b7b983): activation>
Sep 24 11:21:24 t14 NetworkManager[1838]: <info>  [1758705684.2847] dhcp6 (enx0050b6b7b983): state chan>
Sep 24 11:21:24 t14 NetworkManager[1838]: <info>  [1758705684.2852] manager: NetworkManager state is no>
root@t14:~#
Das TLP_DEBUG="..." muss in deine Konfigurationsdatei! Danach den ganzen Ablauf nochmal und bitte den journalctl Output als Textdatei bereitstellen, das Forum schneidet die Zeilen ab. :(
  • Like
Reaktionen: mcb
Ach so.
marc@t14:~$ r
[sudo] password for marc:
Last login: Wed Sep 24 11:20:45 CEST 2025 on pts/0
/etc/tlp.d/00-amd.conf L0029: TLP_DEBUG="lock nm rf run"
root@t14:~# rm log.txt
root@t14:~# cd /home/marc/tmp/
root@t14:/home/marc/tmp# journalctl -p debug -t tlp -t NetworkManager -b 0 >log.txt
T14 Gen1 Intel:
ubu@T14:~$ sudo tlp performance && sudo tlp-stat -p -g -r
--- TLP 1.9.0-alpha.2_603329c --------------------------------------------
+++ Processor
CPU model = Intel(R) Core(TM) i5-10310U CPU @ 1.70GHz
/sys/devices/system/cpu/cpu0/cpufreq/scaling_driver = intel_pstate
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 4400000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_max_freq = 4400000 [kHz]
/sys/devices/system/cpu/intel_pstate/status = active
/sys/devices/system/cpu/intel_pstate/min_perf_pct = 9 [%]
/sys/devices/system/cpu/intel_pstate/max_perf_pct = 100 [%]
/sys/devices/system/cpu/intel_pstate/no_turbo = 0
/sys/devices/system/cpu/intel_pstate/hwp_dynamic_boost = 1
/sys/devices/system/cpu/intel_pstate/turbo_pct = 67 [%]
/sys/devices/system/cpu/intel_pstate/num_pstates = 41
/sys/module/workqueue/parameters/power_efficient = Y
+++ Intel Graphics
/sys/class/drm/card1/device/driver = i915
/sys/class/drm/card1/power/rc6_enable = 1 (enabled)
/sys/kernel/debug/dri/1/i915_fbc_status = FBC disabled: pixel format not supported
/sys/kernel/debug/dri/1/i915_edp_psr_status = PSR mode: disabled
/sys/class/drm/card1/gt_min_freq_mhz = 300 [MHz]
/sys/class/drm/card1/gt_max_freq_mhz = 1150 [MHz]
/sys/class/drm/card1/gt_boost_freq_mhz = 1150 [MHz]
/sys/class/drm/card1/gt_RPn_freq_mhz = 300 [MHz] (GPU min)
/sys/class/drm/card1/gt_RP0_freq_mhz = 1150 [MHz] (GPU max)
+++ Wireless
bluetooth = on
wifi = on
wlp0s20f3(iwlwifi) : wifi, connected, power management = off
ubu@T14:~$ sudo tlp power-saver
ubu@T14:~$ sudo tlp-stat -p -g -r
+++ Processor
/sys/devices/system/cpu/intel_pstate/turbo_pct = 88 [%]
+++ Intel Graphics
+++ Wireless
bluetooth = on
wifi = on
wlp0s20f3(iwlwifi) : wifi, connected, power management = on
@mcb: da überholt sich etwas beim Hochfahren. Zuerst wird durch Aktivieren des LAN Interface, WiFi ausgeschaltet:
Sep 24 11:34:11 t14 tlp[2532]: +++ tlp_rdw_nm(enx0050b6b7b983).up: repeats=
Sep 24 11:34:11 t14 tlp[2532]: tlp_rdw_nm(enx0050b6b7b983).up: type=ethernet [nmcli]
Sep 24 11:34:11 t14 tlp[2532]: device_switch(wifi, off, rdw_nm_wifi, 2)
Sep 24 11:34:11 t14 tlp[2532]: get_devc(wifi) = /sys/class/rfkill/rfkill1/state
Sep 24 11:34:11 t14 tlp[2532]: get_devs(wifi) = 1
Sep 24 11:34:11 t14 tlp[2532]: set_run_flag.touch: rdw_nm_wifi_timed_lock_1758706453; rc=0
Sep 24 11:34:11 t14 tlp[2532]: set_timed_lock(rdw_nm_wifi, 2): rdw_nm_wifi_timed_lock_1758706453; rc=0
Sep 24 11:34:11 t14 NetworkManager[1865]: <info> [1758706451.7450] manager: rfkill: Wi-Fi hardware radio set disabled
Sep 24 11:34:11 t14 NetworkManager[1865]: <info> [1758706451.7452] device (wlp2s0): state change: disconnected -> unavailable (reason 'none', managed-type: 'full')
Sep 24 11:34:11 t14 NetworkManager[1865]: <info> [1758706451.7468] audit: op="radio-control" arg="wireless-enabled:off" pid=2562 uid=0 result="success"
Sep 24 11:34:11 t14 NetworkManager[1865]: <info> [1758706451.7470] device (p2p-dev-wlp2s0): state change: disconnected -> unavailable (reason 'supplicant-failed', managed-type: 'full')
Sep 24 11:34:11 t14 NetworkManager[1865]: <info> [1758706451.7476] manager: rfkill: Wi-Fi now disabled by radio killswitch
Sep 24 11:34:11 t14 tlp[2532]: invoke_nmcli(wifi, off).radio: rc=0
Sep 24 11:34:11 t14 tlp[2532]: get_devs(wifi) = 0
Sep 24 11:34:11 t14 tlp[2532]: device_switch(wifi, off).ok: rc=0
Direkt im Anschluss ist NM fertig mit Hochfahren und macht WiFi wieder an (warum auch immer)
Sep 24 11:34:12 t14 NetworkManager[1865]: <info> [1758706452.4096] manager: startup complete
Sep 24 11:34:12 t14 NetworkManager[1865]: <info> [1758706452.8175] dhcp6 (enx0050b6b7b983): activation: beginning transaction (timeout in 45 seconds)
Sep 24 11:34:12 t14 NetworkManager[1865]: <info> [1758706452.8186] policy: set 'Wired connection 1' (enx0050b6b7b983) as default for IPv6 routing and DNS
Sep 24 11:34:12 t14 NetworkManager[1865]: <info> [1758706452.8350] dhcp6 (enx0050b6b7b983): state changed new lease
Sep 24 11:34:12 t14 tlp[2660]: check_run_flag(rdw_kill): rc=1
Sep 24 11:34:13 t14 NetworkManager[1865]: <info> [1758706453.6677] manager: rfkill: Wi-Fi now enabled by radio killswitch
Eine WiFi-Verbindung stellt NM aber nicht her. Auch nicht in der Folge, wenn tlp.service angeworfen wird (der läuft absichtlich sehr spät) und WiFi nochmal anmachen will, denn Du hastDEVICES_TO_ENABLE_ON_STARTUP="wifi" konfiguriert. Er merkt aber, das es schon an ist:
Sep 24 11:34:14 t14 tlp[3309]: +++ init start (1.9.0-alpha.2_46fe058) ++++++++++++++++++++++++++++++++++++++++
Sep 24 11:34:14 t14 tlp[3309]: SHELL=/usr/bin/dash; umask=0022
Sep 24 11:34:15 t14 tlp[3309]: power_source=ac(0)
Sep 24 11:34:15 t14 tlp[3309]: power_profile=performance(0)
Sep 24 11:34:15 t14 tlp[3309]: lock_tlp().success
Sep 24 11:34:15 t14 tlp[3309]: Applying power save settings...done.
Sep 24 11:34:15 t14 tlp[3309]: Setting battery charge thresholds...done.
Sep 24 11:34:15 t14 tlp[3309]: set_radio_device_states(start): enable=wifi disable=bluetooth
Sep 24 11:34:15 t14 tlp[3309]: device_switch(bluetooth, off, , )
Sep 24 11:34:15 t14 tlp[3309]: get_devc(bluetooth) = /sys/class/rfkill/rfkill0/state
Sep 24 11:34:15 t14 tlp[3309]: get_devs(bluetooth) = 1
Sep 24 11:34:15 t14 tlp[3309]: device_switch(bluetooth, off).rfkill
Sep 24 11:34:15 t14 tlp[3309]: get_devs(bluetooth) = 0
Sep 24 11:34:15 t14 tlp[3309]: device_switch(bluetooth, off).ok: rc=0
Sep 24 11:34:15 t14 tlp[3309]: Disabling radios: bluetooth.
Sep 24 11:34:15 t14 tlp[3309]: device_switch(wifi, on, , )
Sep 24 11:34:15 t14 tlp[3309]: get_devc(wifi) = /sys/class/rfkill/rfkill1/state
Sep 24 11:34:15 t14 tlp[3309]: get_devs(wifi) = 1
Sep 24 11:34:15 t14 tlp[3309]: device_switch(wifi, on).desired_state
Scheint irgendwie an NM zu liegen.
@mcb Ich werde das natürlich nochmal bebrüten, habe aber gerade weder zündende Ideen noch Zeit.
  • Like
Reaktionen: mcb
Bitteschön:
Die meisten settings greifen noch nicht auf pover-saver?
CPU_BOOST_ON_
wären vielleicht noch ganz nützlich. Aber ist ja noch Alpha. ;-)
Nun kommt endlich das Bonbon des kommenden Releases :) zu euch Testern:
TLP wird durch den TLP Profiles Daemon (tlp-pd) ergänzt. Dieser stellt die D-Bus-Schnittstelle bereit, über die gängige Desktop-Umgebungen (soweit ich recherchiert habe: GNOME, KDE, Cinnamon, LXQt) einen Energieprofil-Schalter mit drei Optionen anzeigen können:
  • performance
  • balanced
  • power-saver
(oder wie auch immer das in der Übersetzung heißt.)
Zusammen mit TLP als Backend ersetzt tlp-pd den power-profiles-daemon.
Statt nur Kommandozeile, darf also künftig geklickt werden, um das Profil zu wechseln. Man könnte sagen, TLP bekommt eine GUI, ohne dass ich eine programmiert hätte. Die Desktops können das schon ;).
Wohlgemerkt: tlp-pd ist eine optionale Komponente, die ihr nicht installieren müsst.
Pakete für Debian/Ubuntu gibt's wie immer hier.
Arch folgt hoffentlich am Donnerstag, wenn ich den Maintainer von tlp-git (AUR) treffe.
Ich bin sehr gespannt auf euer Feedback.
@mcb zusätzliche _SAV Einstellungen kommen noch.
Bei Cinnamon 5.6.8 unter Debian 12 musste ich erst das Applet Power Profiles installieren. Zudem Rechner einmal neu gestartet, nach der Installation der drei neuen Alpha-Pakete.
Es wird dauerhaft angezeigt, dass das aktuelle Profil "Balanced" sei. Kann "Performance" und "Power Saver" anklicken, wodurch sich auch das Verhalten ändert, aber die GUI bleibt quasi dabei zu behaupten, es sei "Balanced" ausgewählt, was den Nebeneffekt hat, dass ich "Balanced" nur via sudo tlp balanced aktivieren kann.
Hab zwischendurch auch von AC zu BAT gewechselt, um zu schauen, ob das einen Effekt auf die GUI hat: leider nein.
Beigefügt zwei Screenshots die das Verhalten (hoffentlich) zeigen.
Screenshot 1 soll zeigen, dass die anderen Profile, z. B. "Power Saver", anklickbar sind.
Screenshot 2 soll zeigen, dass die GUI "Balanced" ausgibt, obwohl "Performance" ausgewählt wurde.
Status
