Das steht bei so ziemlich jeder Hardware mit drauf.
Das stimmt natürlich - es war auch eher ironisch gemeint
Follow along with the video below to see how to install our site as a web app on your home screen.
Anmerkung: This feature may not be available in some browsers.
Da steht nicht, dass es keins geben wird, nur, dass es das Problem nicht löst, oder?
I think the answer was definitive, as it came from Jonathan Gray, who is an OpenBSD developer ("jsg@").
Unfortunately, most hardware support development requires both a) an interested developer and b) direct access to the hardware by the developer. It's not known to me if any of the developers have the hardware, or have an interest. If you had two of these video cards, and were willing to donate one of them, you might find an interested developer.
Or, you might consider porting the FreeBSD code to OpenBSD. That's the most common way that people become OpenBSD developers and join the project -- they have an unmet need, and an interest, and start learning OpenBSD internals and devising solutions themselves.
drm: initializing kernel modesetting (RS200 0x1002:0x4337 0x1014:0x053A).
error: [drm:pid0:radeon_agp_init] *ERROR* Unable to acquire AGP: 22
drm: Forcing AGP to PCI mode
radeondrm0: VRAM: 16M 0x000000003F000000 - 0x000000003FFFFFFF (16M used)
radeondrm0: GTT: 512M 0x0000000040000000 - 0x000000005FFFFFFF
drm: PCI GART of 512M enabled (table at 0x0000000001EC7000).
error: [drm:pid0:r100_ring_test] *ERROR* radeon: ring test failed (scratch(0x15E4)=0xCAFEDEAD)
error: [drm:pid0:r100_cp_init] *ERROR* radeon: cp isn't working (-22).
error: [drm:pid0:r100_startup] *ERROR* failed initializing CP (-22).
error: [drm:pid0:r100_init] *ERROR* Disabling GPU acceleration
error: [drm:pid0:r100_cp_fini] *ERROR* Wait for CP idle timeout, shutting down CP.
drm: radeon: cp finalized
drm: Panel ID String: 1024x768
drm: Panel Size 1024x768
radeondrm0: 1024x768
wsdisplay0 at radeondrm0 mux 1: console (std, vt100 emulation), using wskbd0
wsdisplay0: screen 1-5 added (std, vt100 emulation)
# $OpenBSD: ttys,v 1.2 2008/01/09 17:39:42 miod Exp $
# name getty type status comments
console "/usr/libexec/getty std.9600" vt220 off secure
ttyC0 "/usr/libexec/getty std.9600" vt220 [B][COLOR=#ff0000]off[/COLOR][/B] secure
ttyC1 "/usr/libexec/getty std.9600" vt220 on secure
ttyC2 "/usr/libexec/getty std.9600" vt220 on secure
ttyC3 "/usr/libexec/getty std.9600" vt220 on secure
ttyC4 "/usr/libexec/getty std.9600" vt220 off secure
ttyC5 "/usr/libexec/getty std.9600" vt220 on secure
ttyC6 "/usr/libexec/getty std.9600" vt220 off secure
ttyC7 "/usr/libexec/getty std.9600" vt220 off secure
ttyC8 "/usr/libexec/getty std.9600" vt220 off secure
ttyC9 "/usr/libexec/getty std.9600" vt220 off secure
ttyCa "/usr/libexec/getty std.9600" vt220 off secure
ttyCb "/usr/libexec/getty std.9600" vt220 off secure
tty00 "/usr/libexec/getty std.9600" unknown off
# kill -HUP 1
# Xorg -configure
