(NetworkManager:4809): GLib-WARNING **: GError set over the top of a previous GError or uninitialized memory.
This indicates a bug in someone's code. You must ensure an error is NULL before it's set.
The overwriting error message was: Die Schlüsselwertedatei enthält nicht die Gruppe »connectivity«
NetworkManager[4809]: <info> NetworkManager (version 0.9.8.8) is starting...
NetworkManager[4809]: <info> Read config file /etc/NetworkManager/NetworkManager.conf
NetworkManager[4809]: <info> WEXT support is enabled
NetworkManager[4809]: <info> VPN: loaded org.freedesktop.NetworkManager.pptp
NetworkManager[4809]: <info> VPN: loaded org.freedesktop.NetworkManager.vpnc
NetworkManager[4809]: <info> DNS: loaded plugin dnsmasq
NetworkManager[4809]: SCPlugin-Ifupdown: init!
NetworkManager[4809]: SCPlugin-Ifupdown: update_system_hostname
NetworkManager[4809]: interface-parser: parsing file /etc/network/interfaces
NetworkManager[4809]: interface-parser: finished parsing file /etc/network/interfaces
NetworkManager[4809]: SCPluginIfupdown: management mode: unmanaged
NetworkManager[4809]: SCPlugin-Ifupdown: devices added (path: /sys/devices/pci0000:00/0000:00:1a.7/usb1/1-5/1-5:1.0/net/wwan0, iface: wwan0)
NetworkManager[4809]: SCPlugin-Ifupdown: device added (path: /sys/devices/pci0000:00/0000:00:1a.7/usb1/1-5/1-5:1.0/net/wwan0, iface: wwan0): no ifupdown configuration found.
NetworkManager[4809]: SCPlugin-Ifupdown: devices added (path: /sys/devices/pci0000:00/0000:00:1c.1/0000:03:00.0/net/wlan0, iface: wlan0)
NetworkManager[4809]: SCPlugin-Ifupdown: device added (path: /sys/devices/pci0000:00/0000:00:1c.1/0000:03:00.0/net/wlan0, iface: wlan0): no ifupdown configuration found.
NetworkManager[4809]: SCPlugin-Ifupdown: devices added (path: /sys/devices/pci0000:00/0000:00:1c.5/0000:05:00.0/net/eth0, iface: eth0)
NetworkManager[4809]: SCPlugin-Ifupdown: device added (path: /sys/devices/pci0000:00/0000:00:1c.5/0000:05:00.0/net/eth0, iface: eth0): no ifupdown configuration found.
NetworkManager[4809]: SCPlugin-Ifupdown: devices added (path: /sys/devices/virtual/net/lo, iface: lo)
NetworkManager[4809]: SCPlugin-Ifupdown: device added (path: /sys/devices/virtual/net/lo, iface: lo): no ifupdown configuration found.
NetworkManager[4809]: SCPlugin-Ifupdown: end _init.
NetworkManager[4809]: <info> Loaded plugin ifupdown: (C) 2008 Canonical Ltd. To report bugs please use the NetworkManager mailing list.
NetworkManager[4809]: <info> Loaded plugin keyfile: (c) 2007 - 2010 Red Hat, Inc. To report bugs please use the NetworkManager mailing list.
(NetworkManager:4809): GLib-GObject-CRITICAL **: Object class SCPluginOfono doesn't implement property 'name' from interface 'NMSystemConfigInterface'
(NetworkManager:4809): GLib-GObject-CRITICAL **: Object class SCPluginOfono doesn't implement property 'info' from interface 'NMSystemConfigInterface'
(NetworkManager:4809): GLib-GObject-CRITICAL **: Object class SCPluginOfono doesn't implement property 'hostname' from interface 'NMSystemConfigInterface'
(NetworkManager:4809): GLib-GObject-CRITICAL **: Object class SCPluginOfono doesn't implement property 'capabilities' from interface 'NMSystemConfigInterface'
NetworkManager[4809]: SCPlugin-Ofono: Acquired D-Bus service com.canonical.NMOfono
NetworkManager[4809]: SCPlugin-Ofono: init!
(NetworkManager:4809): GLib-CRITICAL **: g_dir_read_name: assertion 'dir != NULL' failed
NetworkManager[4809]: SCPlugin-Ofono: end _init.
(NetworkManager:4809): GLib-GObject-WARNING **: g_object_get_valist: object class 'SCPluginOfono' has no property named 'name'
NetworkManager[4809]: <info> Loaded plugin (null): (null)
NetworkManager[4809]: Ifupdown: get unmanaged devices count: 0
NetworkManager[4809]: SCPlugin-Ifupdown: (35470896) ... get_connections.
NetworkManager[4809]: SCPlugin-Ifupdown: (35470896) ... get_connections (managed=false): return empty list.
NetworkManager[4809]: keyfile: parsing VPN-Verbindung 1 ...
NetworkManager[4809]: keyfile: read connection 'Uni Köln'
NetworkManager[4809]: keyfile: parsing netzwerk ...
NetworkManager[4809]: keyfile: read connection 'netzwerk'
NetworkManager[4809]: keyfile: parsing Congstar Prepaid Contracts 1 ...
NetworkManager[4809]: keyfile: read connection 'Congstar'
NetworkManager[4809]: keyfile: parsing Uni Duisburg-Essen ...
NetworkManager[4809]: keyfile: read connection 'Uni Duisburg-Essen'
NetworkManager[4809]: SCPlugin-Ofono: (35257632) ... get_connections.
NetworkManager[4809]: SCPlugin-Ofono: (35257632) connections count: 0
NetworkManager[4809]: <info> monitoring kernel firmware directory '/lib/firmware'.
NetworkManager[4809]: <info> rfkill1: found WiFi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.1/0000:03:00.0/ieee80211/phy0/rfkill1) (driver iwlwifi)
NetworkManager[4809]: <info> rfkill3: found WWAN radio killswitch (at /sys/devices/platform/thinkpad_acpi/rfkill/rfkill3) (platform driver thinkpad_acpi)
NetworkManager[4809]: <info> WiFi disabled by radio killswitch; disabled by state file
NetworkManager[4809]: <info> WWAN enabled by radio killswitch; enabled by state file
NetworkManager[4809]: <info> WiMAX enabled by radio killswitch; enabled by state file
NetworkManager[4809]: <info> Networking is enabled by state file
NetworkManager[4809]: <info> (wlan0): using nl80211 for WiFi device control
NetworkManager[4809]: <info> (wlan0): new 802.11 WiFi device (driver: 'iwlwifi' ifindex: 3)
NetworkManager[4809]: <info> (wlan0): exported as /org/freedesktop/NetworkManager/Devices/0
NetworkManager[4809]: <info> (wlan0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
NetworkManager[4809]: <info> (wlan0): bringing up device.
NetworkManager[4809]: <info> (wlan0): deactivating device (reason 'managed') [2]
NetworkManager[4809]: <warn> failed to allocate link cache: (-12) Object not found
NetworkManager[4809]: <info> (eth0): carrier is OFF
NetworkManager[4809]: <info> (eth0): new Ethernet device (driver: 'r8169' ifindex: 2)
NetworkManager[4809]: <info> (eth0): exported as /org/freedesktop/NetworkManager/Devices/1
NetworkManager[4809]: <info> (eth0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
NetworkManager[4809]: <info> (eth0): bringing up device.
NetworkManager[4809]: <info> (eth0): preparing device.
NetworkManager[4809]: <info> (eth0): deactivating device (reason 'managed') [2]
NetworkManager[4809]: <info> Added default wired connection 'Kabelnetzwerkverbindung 1' for /sys/devices/pci0000:00/0000:00:1c.5/0000:05:00.0/net/eth0
NetworkManager[4809]: <warn> /sys/devices/virtual/net/lo: couldn't determine device driver; ignoring...
NetworkManager[4809]: <info> urfkill disappeared from the bus
NetworkManager[4809]: <info> ModemManager available in the bus
NetworkManager[4809]: <warn> (cdc-wdm0): failed to look up interface index
NetworkManager[4809]: <info> (cdc-wdm0): new Broadband device (driver: 'qcserial, qmi_wwan' ifindex: 0)
NetworkManager[4809]: <info> (cdc-wdm0): exported as /org/freedesktop/NetworkManager/Devices/2
NetworkManager[4809]: <info> (cdc-wdm0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
NetworkManager[4809]: <info> (cdc-wdm0): deactivating device (reason 'managed') [2]
NetworkManager[4809]: <info> (cdc-wdm0): device state change: unavailable -> disconnected (reason 'none') [20 30 0]
NetworkManager[4809]: <info> WiFi hardware radio set disabled
NetworkManager[4809]: <info> (cdc-wdm0) modem state changed, 'disabled' --> 'enabling' (reason: user-requested)
NetworkManager[4809]: <info> (cdc-wdm0) modem state changed, 'enabling' --> 'disabled' (reason: unknown)
NetworkManager[4809]: <warn> (cdc-wdm0) failed to enable modem: GDBus.Error:org.freedesktop.libqmi.Error.Protocol.InvalidTransaction: Couldn't set operating mode: QMI protocol error (60): 'InvalidTransaction'
NetworkManager[4809]: <info> Activation (cdc-wdm0) starting connection 'Congstar'
NetworkManager[4809]: <info> (cdc-wdm0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
NetworkManager[4809]: <info> NetworkManager state is now CONNECTING
NetworkManager[4809]: <info> Activation (cdc-wdm0) Stage 1 of 5 (Device Prepare) scheduled...
NetworkManager[4809]: <info> Activation (cdc-wdm0) Stage 1 of 5 (Device Prepare) started...
NetworkManager[4809]: <info> Activation (cdc-wdm0) Stage 1 of 5 (Device Prepare) complete.
NetworkManager[4809]: <warn> (cdc-wdm0) failed to connect modem: Couldn't set operating mode: QMI protocol error (60): 'InvalidTransaction'
NetworkManager[4809]: <info> (cdc-wdm0): device state change: prepare -> failed (reason 'unknown') [40 120 1]
NetworkManager[4809]: <info> NetworkManager state is now DISCONNECTED
NetworkManager[4809]: <warn> Activation (cdc-wdm0) failed for connection 'Congstar'
NetworkManager[4809]: <info> (cdc-wdm0): device state change: failed -> disconnected (reason 'none') [120 30 0]
NetworkManager[4809]: <info> (cdc-wdm0): deactivating device (reason 'none') [0]
NetworkManager[4809]: <info> sleep requested (sleeping: no enabled: yes)
NetworkManager[4809]: <info> sleeping or disabling...
NetworkManager[4809]: <info> (wlan0): device state change: unavailable -> unmanaged (reason 'sleeping') [20 10 37]
NetworkManager[4809]: <info> NetworkManager state is now ASLEEP
NetworkManager[4809]: <info> (eth0): device state change: unavailable -> unmanaged (reason 'sleeping') [20 10 37]
NetworkManager[4809]: <info> (eth0): cleaning up...
NetworkManager[4809]: <info> (eth0): taking down device.
NetworkManager[4809]: <info> (cdc-wdm0): device state change: disconnected -> unmanaged (reason 'sleeping') [30 10 37]
NetworkManager[4809]: <info> (cdc-wdm0): cleaning up...
NetworkManager[4809]: <info> (cdc-wdm0): taking down device.
NetworkManager[4809]: SCPlugin-Ifupdown: devices removed (path: /sys/devices/pci0000:00/0000:00:1a.7/usb1/1-5/1-5:1.0/net/wwan0, iface: wwan0)
NetworkManager[4809]: <info> wake requested (sleeping: yes enabled: yes)
NetworkManager[4809]: <info> waking up and re-enabling...
NetworkManager[4809]: <info> WWAN now enabled by management service
NetworkManager[4809]: <info> Unmanaged Device found; state CONNECTED forced. (see http://bugs.launchpad.net/bugs/191889)
NetworkManager[4809]: <info> NetworkManager state is now CONNECTED_GLOBAL
NetworkManager[4809]: <info> WWAN now disabled by management service
NetworkManager[4809]: <info> (cdc-wdm0): exported as /org/freedesktop/NetworkManager/Devices/3
NetworkManager[4809]: <info> (usb0): carrier is OFF
NetworkManager[4809]: <info> (usb0): new Ethernet device (driver: 'rndis_host' ifindex: 9)
NetworkManager[4809]: <info> (usb0): exported as /org/freedesktop/NetworkManager/Devices/4
NetworkManager[4809]: <info> (usb0): device state change: unmanaged -> unavailable (reason 'managed') [10 20 2]
NetworkManager[4809]: <info> (usb0): bringing up device.
NetworkManager[4809]: <info> (usb0): carrier now ON (device state 20)
NetworkManager[4809]: <info> (usb0): preparing device.
NetworkManager[4809]: <info> (usb0): deactivating device (reason 'managed') [2]
NetworkManager[4809]: <info> Added default wired connection 'Kabelnetzwerkverbindung 2' for /sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1:1.0/net/usb0
NetworkManager[4809]: SCPlugin-Ifupdown: devices added (path: /sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1:1.0/net/usb0, iface: usb0)
NetworkManager[4809]: SCPlugin-Ifupdown: device added (path: /sys/devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1:1.0/net/usb0, iface: usb0): no ifupdown configuration found.
NetworkManager[4809]: <info> (usb0): device state change: unavailable -> disconnected (reason 'none') [20 30 0]
NetworkManager[4809]: <info> Auto-activating connection 'Kabelnetzwerkverbindung 2'.
NetworkManager[4809]: <info> Activation (usb0) starting connection 'Kabelnetzwerkverbindung 2'
NetworkManager[4809]: <info> (usb0): device state change: disconnected -> prepare (reason 'none') [30 40 0]
NetworkManager[4809]: <info> Activation (usb0) Stage 1 of 5 (Device Prepare) scheduled...
NetworkManager[4809]: <info> Activation (usb0) Stage 1 of 5 (Device Prepare) started...
NetworkManager[4809]: <info> Activation (usb0) Stage 2 of 5 (Device Configure) scheduled...
NetworkManager[4809]: <info> Activation (usb0) Stage 1 of 5 (Device Prepare) complete.
NetworkManager[4809]: <info> Activation (usb0) Stage 2 of 5 (Device Configure) starting...
NetworkManager[4809]: <info> (usb0): device state change: prepare -> config (reason 'none') [40 50 0]
NetworkManager[4809]: <info> Activation (usb0) Stage 2 of 5 (Device Configure) successful.
NetworkManager[4809]: <info> Activation (usb0) Stage 3 of 5 (IP Configure Start) scheduled.
NetworkManager[4809]: <info> Activation (usb0) Stage 2 of 5 (Device Configure) complete.
NetworkManager[4809]: <info> Activation (usb0) Stage 3 of 5 (IP Configure Start) started...
NetworkManager[4809]: <info> (usb0): device state change: config -> ip-config (reason 'none') [50 70 0]
NetworkManager[4809]: <info> Activation (usb0) Beginning DHCPv4 transaction (timeout in 45 seconds)
NetworkManager[4809]: <info> dhclient started with pid 5590
NetworkManager[4809]: <info> Activation (usb0) Beginning IP6 addrconf.
NetworkManager[4809]: <info> Activation (usb0) Stage 3 of 5 (IP Configure Start) complete.
Internet Systems Consortium DHCP Client 4.2.4
Copyright 2004-2012 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
NetworkManager[4809]: <info> (usb0): DHCPv4 state changed nbi -> preinit
Listening on LPF/usb0/2a:40:bf:19:b8:2e
Sending on LPF/usb0/2a:40:bf:19:b8:2e
Sending on Socket/fallback
DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 3 (xid=0x2338e30a)
DHCPDISCOVER on usb0 to 255.255.255.255 port 67 interval 4 (xid=0x2338e30a)
DHCPREQUEST of 192.168.42.94 on usb0 to 255.255.255.255 port 67 (xid=0x2338e30a)
DHCPOFFER of 192.168.42.94 from 192.168.42.129
DHCPACK of 192.168.42.94 from 192.168.42.129
bound to 192.168.42.94 -- renewal in 1722 seconds.
NetworkManager[4809]: <info> (usb0): DHCPv4 state changed preinit -> bound
NetworkManager[4809]: <info> address 192.168.42.94
NetworkManager[4809]: <info> prefix 24 (255.255.255.0)
NetworkManager[4809]: <info> gateway 192.168.42.129
NetworkManager[4809]: <info> hostname 'babel-ThinkPad'
NetworkManager[4809]: <info> nameserver '192.168.42.129'
NetworkManager[4809]: <info> Activation (usb0) Stage 5 of 5 (IPv4 Configure Commit) scheduled...
NetworkManager[4809]: <info> Activation (usb0) Stage 5 of 5 (IPv4 Commit) started...
NetworkManager[4809]: <info> (usb0): device state change: ip-config -> secondaries (reason 'none') [70 90 0]
NetworkManager[4809]: <info> Activation (usb0) Stage 5 of 5 (IPv4 Commit) complete.
NetworkManager[4809]: <info> (usb0): device state change: secondaries -> activated (reason 'none') [90 100 0]
NetworkManager[4809]: <info> Policy set 'Kabelnetzwerkverbindung 2' (usb0) as default for IPv4 routing and DNS.
NetworkManager[4809]: <info> DNS: starting dnsmasq...
NetworkManager[4809]: <warn> dnsmasq not available on the bus, can't update servers.
NetworkManager[4809]: <error> [1401391016.780082] [nm-dns-dnsmasq.c:396] update(): dnsmasq owner not found on bus: Could not get owner of name 'org.freedesktop.NetworkManager.dnsmasq': no such name
NetworkManager[4809]: <warn> DNS: plugin dnsmasq update failed
NetworkManager[4809]: <info> Writing DNS information to /sbin/resolvconf
NetworkManager[4809]: <info> Activation (usb0) successful, device activated.
NetworkManager[4809]: <warn> dnsmasq appeared on DBus: :1.106
NetworkManager[4809]: <info> (usb0): IP6 addrconf timed out or failed.
NetworkManager[4809]: <info> Activation (usb0) Stage 4 of 5 (IPv6 Configure Timeout) scheduled...
NetworkManager[4809]: <info> Activation (usb0) Stage 4 of 5 (IPv6 Configure Timeout) started...
NetworkManager[4809]: <info> Activation (usb0) Stage 4 of 5 (IPv6 Configure Timeout) complete.
