electricfling
- 9 Sep. 2014
Oder einfach bei ubook/edustore/campuspoint/etc kaufen
Wie mache ich das wenn ich kein Student bin
Follow along with the video below to see how to install our site as a web app on your home screen.
Anmerkung: This feature may not be available in some browsers.
Pro T480swas spricht für das X1 und was für das T480s? Oder gegen das ein oder andere.
Einem Studenten 50€ in die Hand drücken und profitieren
T480s | X1 Carbon G6 | |
Dimension | 331mm x 226.8 mm x 18.45mm | 323.5 x 217.1 x 15.95 mm |
Weight | <2.90lbs / 1.32kg | 2.49lbs / 1.13kg |
Screen Size & Resolution | 14”: FHD IPS, FHD IPS Touch, WQHD IPS | 14”: FHD IPS, FHD IPS Touch, WQHD IPS, HDR WQHD IPS |
CPU | KBL: i5 vPro; KBL R: i5/i7, i5/i7 vPro | KBL: i5 vPro; KBL R: i5/i7, i5/i7 vPro |
Graphics | Intel HD 620, GeForce MX150 w/ 2GB GDDR5 (nicht in EMEA) | Intel UHD 620 |
Memory | DDR4 (2133Mhz): Up to 24GB (4,8,16GB DIMM + 4/8GB down) | LPDDR3: 2133Mhz 8GB / 16GB |
Storage | Up to 1TB PCIe SSD | Up to 1TB PCIe SSD |
Camera | HD w/ThinkShutter, HD + IR | HD w/ThinkShutter, HD + IR |
Battery (Size / Life) | 57Whr / Up to 13.5hrs (Single Battery) | 57Whr / Up to 15hrs |
Rapid Charge – 80% | Yes (w\ 65W AC) | Yes (w\ 65W AC) |
Keyboard | Backlight w\ White LEDs | White LEDs & Backlight |
Pen | No | N/A |
Docking | Thunderbolt 3, USB3.0, Side Mechanical (CS18) | Thunderbolt 3, USB3.0, Side Mechanical (CS18) |
Ethernet | Trapdoor RJ45 | Via “New” Ethernet Docking Dongle |
I/O Ports | 2x USB 3.0, 1x Thunderbolt 3, 1x USB C, SD Card | 2x USB3.0, 2x Thunderbolt 3, Audio, microSD Card |
Video Ports / Audio | HDMI, Thunderbolt 3, Audio Dolby Premium | HDMI, Thunderbolt 3, Dolby Premium Audio |
Wireless Communication | WLAN, LTE CAT9 Async & EU CAT6, NFC | WLAN / LTE A/ NFC |
Biometric / Security | Touch FPR, SCR, IR Camera, ThinkShutter, dTPM 2.0 | Touch FPR, IR Camera, ThinkShutter, dTPM 2.0 |
https://www3.lenovo.com/de/de/laptops/thinkpad/t-series/ThinkPad-T480s/p/22TP2TT480S
Wie ich im X280 Thread schon schrieb: Das T480s gibt es nun auch in Deutschland
Nein, das X1 Carbon gibt es nicht mit Smartkarten-KeserHat das X1 einen SmartCardReader? (Brauche ich nur privat, daher nicht Pflicht)
Die QHD-Bildschirme sind gerade beim T480s allerdings deutlich hochwertiger als das FHD-Panel, gerade was Helligkeit und Farbraumabdeckung angeht.HDR Is nett aber für mich nicht unbedingt Pflicht auch die WQHD Auflösung ist nicht unbedingt notwendig (auf 14“ irgendwie nur bedingt nutzbar, wobei Outlook und Excel profitieren schon ... )
Dann fällt beim X1C zumindest das WQHD mit seinem glänzenden Panel aus.Zu meinen Arbeitsanforderungen: ich bin viel unterwegs vor allem mit dem Flugzeug und brauche unterwegs ein leichtes Gerät, mit einem. Monitor wo ich was seh drauf.
Die Studiangebote in der Schweiz sprechen zumindest von 3-Jährigem VOS.
Genau, und dann auch eventuell ein anderes Produkt in Betracht ziehen.Wartet einfach noch etwas ab...(paar Wochen nur)
Genau, und dann auch eventuell ein anderes Produkt in Betracht ziehen.Das X1C wäre schon eine feine Sache, jedoch habe ich Bedenken bzgl. der entstehenden Wärme. Das war ja beim Vorgänger genau das Problem und
führte zu Reduzierung der CPU-Geschwindigkeit. Wenn jetzt die neuen KBL-R-Cpu's vier Kerne statt 2 Kerne besitzen, wird doch auch die Wärmeentwicklung höher werden oder ?
vorort garantiert dir nur reaktion innerhalb 24 std. sonst nichts bei einem mainbordschaden einer neueren serie wartest du wenn du glück hast 3 wochen mit pech 3 monate.für mich ist VOS für einen Arbeitscomputer Pflicht. Ich schicke nicht mein Arbeitsgerät ein und hoffe, dass ich es "bald" wieder bekomme.
Es kann (wobei, wahrscheinlich eher darf ) dir noch keiner sagen, wie Lenovo die Kühlung beim neuen X1C gelöst hat. Aber generell: ja, die CPUs können mehr Energie verbrauchen und somit auch wärmer werden. Schau dir mal die Testberichte zum Dell XPS 9360 an - das gibt es in zwei Versionen, einmal mit Kaby Lake-Dualcores und dann im gleichen Gehäuse mit Kaby Lake-Quadcore (manchmal auch als 9360R bezeichnet). Das zeigt relativ anschaulich, wie sich die KBL-R CPUs verhalten.Das X1C wäre schon eine feine Sache, jedoch habe ich Bedenken bzgl. der entstehenden Wärme. Das war ja beim Vorgänger genau das Problem und
Danke dir für die Info. Nur wenn ich dann eigentlich das gleiche wie im Vorjahr erhalte, dann kann ich auf das T490s warten. Ob es etwas bringt, ist die andere Frage.Es kann (wobei, wahrscheinlich eher darf ) dir noch keiner sagen, wie Lenovo die Kühlung beim neuen X1C gelöst hat. Aber generell: ja, die CPUs können mehr Energie verbrauchen und somit auch wärmer werden. Schau dir mal die Testberichte zum Dell XPS 9360 an - das gibt es in zwei Versionen, einmal mit Kaby Lake-Dualcores und dann im gleichen Gehäuse mit Kaby Lake-Quadcore (manchmal auch als 9360R bezeichnet). Das zeigt relativ anschaulich, wie sich die KBL-R CPUs verhalten.
Das ist sicher nicht der Fall. Das X1 Carbon wird mit den Quad Core-CPUs sicherlich ein ganzes Stück attraktiver, wenn man ab und zu richtig viel Leistung braucht - aber für dauerhafte Arbeit unter Volllast war die X1-Serie noch nie ausgelegt. Wenn das das Hauptnutzungsgebiet ist, würde ich mit den neuen CPUs einfach noch eher in Richtung T-Serie gehen.Nur wenn ich dann eigentlich das gleiche wie im Vorjahr erhalte, dann kann ich auf das T490s warten.
