Linux [Think Pad T14 Gen3, Debian Trixie/sid] Nach suspend wacht der Laptop nicht mehr auf.
Linux Betriebssystem
chris101
Rather New Member
17 Okt. 2024
"dmesg -l warn" liefert folgenden Outpout:
[    0.255140] mtrr: your CPUs had inconsistent fixed MTRR settings
[    0.255141] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.298347] ACPI: \_SB_.PCI0.GP11: Overriding _PRW sleep state (S4) by S0 from power resources
[    0.300172] ACPI: \_SB_.PCI0.GP12: Overriding _PRW sleep state (S4) by S0 from power resources
[    0.304571] ACPI: \_SB_.PCI0.GP19.NHI0: Overriding _PRW sleep state (S3) by S0 from power resources
[    0.305210] ACPI: \_SB_.PCI0.GP19.NHI1: Overriding _PRW sleep state (S3) by S0 from power resources
[    1.460999] blacklist: Duplicate blacklisted hash bin:80b4d96931bf0d02fd91a61e19d14f1da452e66db2408ca8604d411f92659f0a
[    1.461002] blacklist: Duplicate blacklisted hash bin:f52f83a3fa9cfbd6920f722824dbe4034534d25b8507246b3b957dac6e1bce7a
[    1.461005] blacklist: Duplicate blacklisted hash bin:c5d9d8a186e2c82d09afaa2a6f7f2e73870d3e64f72c4e08ef67796a840f0fbd
[    1.461007] blacklist: Duplicate blacklisted hash bin:1aec84b84b6c65a51220a9be7181965230210d62d6d33c48999c6b295a2b0a06
[    1.461009] blacklist: Duplicate blacklisted hash bin:c3a99a460da464a057c3586d83cef5f4ae08b7103979ed8932742df0ed530c66
[    1.461011] blacklist: Duplicate blacklisted hash bin:58fb941aef95a25943b3fb5f2510a0df3fe44c58c95e0ab80487297568ab9771
[    1.461013] blacklist: Duplicate blacklisted hash bin:5391c3a2fb112102a6aa1edc25ae77e19f5d6f09cd09eeb2509922bfcd5992ea
[    1.461016] blacklist: Duplicate blacklisted hash bin:d626157e1d6a718bc124ab8da27cbb65072ca03a7b6b257dbdcbbd60f65ef3d1
[    1.461018] blacklist: Duplicate blacklisted hash bin:d063ec28f67eba53f1642dbf7dff33c6a32add869f6013fe162e2c32f1cbe56d
[    1.461020] blacklist: Duplicate blacklisted hash bin:29c6eb52b43c3aa18b2cd8ed6ea8607cef3cfae1bafe1165755cf2e614844a44
[    1.461022] blacklist: Duplicate blacklisted hash bin:90fbe70e69d633408d3e170c6832dbb2d209e0272527dfb63d49d29572a6f44c
[    1.461024] blacklist: Duplicate blacklisted hash bin:106faceacfecfd4e303b74f480a08098e2d0802b936f8ec774ce21f31686689c
[    1.461027] blacklist: Duplicate blacklisted hash bin:174e3a0b5b43c6a607bbd3404f05341e3dcf396267ce94f8b50e2e23a9da920c
[    1.461029] blacklist: Duplicate blacklisted hash bin:2b99cf26422e92fe365fbf4bc30d27086c9ee14b7a6fff44fb2f6b9001699939
[    1.461031] blacklist: Duplicate blacklisted hash bin:2e70916786a6f773511fa7181fab0f1d70b557c6322ea923b2a8d3b92b51af7d
[    1.461034] blacklist: Duplicate blacklisted hash bin:3fce9b9fdf3ef09d5452b0f95ee481c2b7f06d743a737971558e70136ace3e73
[    1.461036] blacklist: Duplicate blacklisted hash bin:47cc086127e2069a86e03a6bef2cd410f8c55a6d6bdb362168c31b2ce32a5adf
[    1.461038] blacklist: Duplicate blacklisted hash bin:71f2906fd222497e54a34662ab2497fcc81020770ff51368e9e3d9bfcbfd6375
[    1.461041] blacklist: Duplicate blacklisted hash bin:82db3bceb4f60843ce9d97c3d187cd9b5941cd3de8100e586f2bda5637575f67
[    1.461043] blacklist: Duplicate blacklisted hash bin:8ad64859f195b5f58dafaa940b6a6167acd67a886e8f469364177221c55945b9
[    1.461046] blacklist: Duplicate blacklisted hash bin:8d8ea289cfe70a1c07ab7365cb28ee51edd33cf2506de888fbadd60ebf80481c
[    1.461048] blacklist: Duplicate blacklisted hash bin:aeebae3151271273ed95aa2e671139ed31a98567303a332298f83709a9d55aa1
[    1.461050] blacklist: Duplicate blacklisted hash bin:c409bdac4775add8db92aa22b5b718fb8c94a1462c1fe9a416b95d8a3388c2fc
[    1.461053] blacklist: Duplicate blacklisted hash bin:c617c1a8b1ee2a811c28b5a81b4c83d7c98b5b0c27281d610207ebe692c2967f
[    1.461055] blacklist: Duplicate blacklisted hash bin:c90f336617b8e7f983975413c997f10b73eb267fd8a10cb9e3bdbfc667abdb8b
[    1.461058] blacklist: Duplicate blacklisted hash bin:64575bd912789a2e14ad56f6341f52af6bf80cf94400785975e9f04e2d64d745
[    1.461060] blacklist: Duplicate blacklisted hash bin:45c7c8ae750acfbb48fc37527d6412dd644daed8913ccd8a24c94d856967df8e
[    1.461308] blacklist: Duplicate blacklisted hash bin:47ff1b63b140b6fc04ed79131331e651da5b2e2f170f5daef4153dc2fbc532b1
[    1.461311] blacklist: Duplicate blacklisted hash bin:5391c3a2fb112102a6aa1edc25ae77e19f5d6f09cd09eeb2509922bfcd5992ea
[    1.461363] blacklist: Duplicate blacklisted hash bin:80b4d96931bf0d02fd91a61e19d14f1da452e66db2408ca8604d411f92659f0a
[    1.461407] blacklist: Duplicate blacklisted hash bin:992d359aa7a5f789d268b94c11b9485a6b1ce64362b0edb4441ccc187c39647b
[    1.461468] blacklist: Duplicate blacklisted hash bin:c452ab846073df5ace25cca64d6b7a09d906308a1a65eb5240e3c4ebcaa9cc0c
[    1.461505] blacklist: Duplicate blacklisted hash bin:e051b788ecbaeda53046c70e6af6058f95222c046157b8c4c1b9c2cfc65f46e5
[    1.977680] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[    3.748180] r8152 10-1.1:1.0: Direct firmware load for rtl_nic/rtl8153b-2.fw failed with error -2
[    3.748184] r8152 10-1.1:1.0: unable to load firmware patch rtl_nic/rtl8153b-2.fw (-2)
[    5.422736] sd 0:0:0:0: [sda] No Caching mode page found
[    5.422739] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    7.404999] systemd-sysv-generator[471]: SysV service '/etc/init.d/speech-dispatcher' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    7.886512] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Wenn der Laptop in den Suspend Mode geht, blinkt die Power leuchte sanft auf - jedoch kann das Betriebssystem nur durch einen Kaltstart neu gestartet werden.
Nach einer Forensuche wird rasch klar, dass dieses Problem unter zahlreichen Latop Varianten und Betriebssystem unter Linux aufgetreten ist und auftritt.
Hat vielleicht jemand eine Idee wie das Problem angegangen werden könnte ?
Ich versuchte bereits WWAN im BIOS auszuschalten, was bei meinem BIOS jedoch nicht vorhanden ist. Regelmässig wird auch der ath11k treiber verdächtigt.
Hooks Vorschläge gibt es hier:
Vielen Dank!
Lasst euch nicht aufs Glatteis führen. Mit "Third Party Software" meint Lenovo höchstwahrscheinlich nur ein Betriebssystem, dss nicht von MS stammt. Es werden dann andere Einstellungen gewählt.
Das BIOS installiert doch keine Software (wenn man mal von Computrace absieht).
EDITH sagt, "Third Party Software" meint, dass von der Microsoft "3rd Party UEFI CA" signierte Bootloader erlaubt werden. Wenn aber Secure Boot eh schon aus ist, braucht man das nicht.
Was das alles mit Suspend/Resume zu tun hat, bleibt rätselhaft.
