Linux [Think Pad T14 Gen3, Debian Trixie/sid] Nach suspend wacht der Laptop nicht mehr auf.
Linux Betriebssystem
chris101
Rather New Member
17 Okt. 2024
"dmesg -l warn" liefert folgenden Outpout:
[    0.255140] mtrr: your CPUs had inconsistent fixed MTRR settings
[    0.255141] mtrr: your CPUs had inconsistent variable MTRR settings
[    0.298347] ACPI: \_SB_.PCI0.GP11: Overriding _PRW sleep state (S4) by S0 from power resources
[    0.300172] ACPI: \_SB_.PCI0.GP12: Overriding _PRW sleep state (S4) by S0 from power resources
[    0.304571] ACPI: \_SB_.PCI0.GP19.NHI0: Overriding _PRW sleep state (S3) by S0 from power resources
[    0.305210] ACPI: \_SB_.PCI0.GP19.NHI1: Overriding _PRW sleep state (S3) by S0 from power resources
[    1.460999] blacklist: Duplicate blacklisted hash bin:80b4d96931bf0d02fd91a61e19d14f1da452e66db2408ca8604d411f92659f0a
[    1.461002] blacklist: Duplicate blacklisted hash bin:f52f83a3fa9cfbd6920f722824dbe4034534d25b8507246b3b957dac6e1bce7a
[    1.461005] blacklist: Duplicate blacklisted hash bin:c5d9d8a186e2c82d09afaa2a6f7f2e73870d3e64f72c4e08ef67796a840f0fbd
[    1.461007] blacklist: Duplicate blacklisted hash bin:1aec84b84b6c65a51220a9be7181965230210d62d6d33c48999c6b295a2b0a06
[    1.461009] blacklist: Duplicate blacklisted hash bin:c3a99a460da464a057c3586d83cef5f4ae08b7103979ed8932742df0ed530c66
[    1.461011] blacklist: Duplicate blacklisted hash bin:58fb941aef95a25943b3fb5f2510a0df3fe44c58c95e0ab80487297568ab9771
[    1.461013] blacklist: Duplicate blacklisted hash bin:5391c3a2fb112102a6aa1edc25ae77e19f5d6f09cd09eeb2509922bfcd5992ea
[    1.461016] blacklist: Duplicate blacklisted hash bin:d626157e1d6a718bc124ab8da27cbb65072ca03a7b6b257dbdcbbd60f65ef3d1
[    1.461018] blacklist: Duplicate blacklisted hash bin:d063ec28f67eba53f1642dbf7dff33c6a32add869f6013fe162e2c32f1cbe56d
[    1.461020] blacklist: Duplicate blacklisted hash bin:29c6eb52b43c3aa18b2cd8ed6ea8607cef3cfae1bafe1165755cf2e614844a44
[    1.461022] blacklist: Duplicate blacklisted hash bin:90fbe70e69d633408d3e170c6832dbb2d209e0272527dfb63d49d29572a6f44c
[    1.461024] blacklist: Duplicate blacklisted hash bin:106faceacfecfd4e303b74f480a08098e2d0802b936f8ec774ce21f31686689c
[    1.461027] blacklist: Duplicate blacklisted hash bin:174e3a0b5b43c6a607bbd3404f05341e3dcf396267ce94f8b50e2e23a9da920c
[    1.461029] blacklist: Duplicate blacklisted hash bin:2b99cf26422e92fe365fbf4bc30d27086c9ee14b7a6fff44fb2f6b9001699939
[    1.461031] blacklist: Duplicate blacklisted hash bin:2e70916786a6f773511fa7181fab0f1d70b557c6322ea923b2a8d3b92b51af7d
[    1.461034] blacklist: Duplicate blacklisted hash bin:3fce9b9fdf3ef09d5452b0f95ee481c2b7f06d743a737971558e70136ace3e73
[    1.461036] blacklist: Duplicate blacklisted hash bin:47cc086127e2069a86e03a6bef2cd410f8c55a6d6bdb362168c31b2ce32a5adf
[    1.461038] blacklist: Duplicate blacklisted hash bin:71f2906fd222497e54a34662ab2497fcc81020770ff51368e9e3d9bfcbfd6375
[    1.461041] blacklist: Duplicate blacklisted hash bin:82db3bceb4f60843ce9d97c3d187cd9b5941cd3de8100e586f2bda5637575f67
[    1.461043] blacklist: Duplicate blacklisted hash bin:8ad64859f195b5f58dafaa940b6a6167acd67a886e8f469364177221c55945b9
[    1.461046] blacklist: Duplicate blacklisted hash bin:8d8ea289cfe70a1c07ab7365cb28ee51edd33cf2506de888fbadd60ebf80481c
[    1.461048] blacklist: Duplicate blacklisted hash bin:aeebae3151271273ed95aa2e671139ed31a98567303a332298f83709a9d55aa1
[    1.461050] blacklist: Duplicate blacklisted hash bin:c409bdac4775add8db92aa22b5b718fb8c94a1462c1fe9a416b95d8a3388c2fc
[    1.461053] blacklist: Duplicate blacklisted hash bin:c617c1a8b1ee2a811c28b5a81b4c83d7c98b5b0c27281d610207ebe692c2967f
[    1.461055] blacklist: Duplicate blacklisted hash bin:c90f336617b8e7f983975413c997f10b73eb267fd8a10cb9e3bdbfc667abdb8b
[    1.461058] blacklist: Duplicate blacklisted hash bin:64575bd912789a2e14ad56f6341f52af6bf80cf94400785975e9f04e2d64d745
[    1.461060] blacklist: Duplicate blacklisted hash bin:45c7c8ae750acfbb48fc37527d6412dd644daed8913ccd8a24c94d856967df8e
[    1.461308] blacklist: Duplicate blacklisted hash bin:47ff1b63b140b6fc04ed79131331e651da5b2e2f170f5daef4153dc2fbc532b1
[    1.461311] blacklist: Duplicate blacklisted hash bin:5391c3a2fb112102a6aa1edc25ae77e19f5d6f09cd09eeb2509922bfcd5992ea
[    1.461363] blacklist: Duplicate blacklisted hash bin:80b4d96931bf0d02fd91a61e19d14f1da452e66db2408ca8604d411f92659f0a
[    1.461407] blacklist: Duplicate blacklisted hash bin:992d359aa7a5f789d268b94c11b9485a6b1ce64362b0edb4441ccc187c39647b
[    1.461468] blacklist: Duplicate blacklisted hash bin:c452ab846073df5ace25cca64d6b7a09d906308a1a65eb5240e3c4ebcaa9cc0c
[    1.461505] blacklist: Duplicate blacklisted hash bin:e051b788ecbaeda53046c70e6af6058f95222c046157b8c4c1b9c2cfc65f46e5
[    1.977680] device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
[    3.748180] r8152 10-1.1:1.0: Direct firmware load for rtl_nic/rtl8153b-2.fw failed with error -2
[    3.748184] r8152 10-1.1:1.0: unable to load firmware patch rtl_nic/rtl8153b-2.fw (-2)
[    5.422736] sd 0:0:0:0: [sda] No Caching mode page found
[    5.422739] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    7.404999] systemd-sysv-generator[471]: SysV service '/etc/init.d/speech-dispatcher' lacks a native systemd unit file. ~ Automatically generating a unit file for compatibility. Please update package to include a native systemd unit file, in order to make it safe, robust and future-proof. ! This compatibility logic is deprecated, expect removal soon. !
[    7.886512] Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Wenn der Laptop in den Suspend Mode geht, blinkt die Power leuchte sanft auf - jedoch kann das Betriebssystem nur durch einen Kaltstart neu gestartet werden.
Nach einer Forensuche wird rasch klar, dass dieses Problem unter zahlreichen Latop Varianten und Betriebssystem unter Linux aufgetreten ist und auftritt.
Hat vielleicht jemand eine Idee wie das Problem angegangen werden könnte ?
Ich versuchte bereits WWAN im BIOS auszuschalten, was bei meinem BIOS jedoch nicht vorhanden ist. Regelmässig wird auch der ath11k treiber verdächtigt.
Hooks Vorschläge gibt es hier:
Vielen Dank!
- Hast du deine Partitionen verschlüsselt ?
- Nutzt du LVM für deine Platten?
- Funktioniert der Suspend Modus mit einer Live-Distro?
- Hast du USB Geräte angeschlossen, die du evtl. zum Testen abnehmen könntest?
- Hast du mal mit einer anderen Desktop Envoirment getestet anstatt GNOME? (Bspw mate-desktop)
Wären so die ersten Fragen/Dinge die mir noch dazu einfallen würden
Wäre einen Versuch wert.
Das Problem besteht auch bei Anwendung der aktuellsten Live Ubuntu Version - also wohl entweder schon seit längerem Kernel oder Debian bedingte Problematik.
Hi
- Nein, nicht verschlüsselt.
- Ja, aber das Problem besteht schon seit ich den Laptop gekauft hatte (nur hat es mich damals nicht so gestört da ich ihn seltener verwendet habe) ohne das LVM verwendet wurde.
- Mit Ubuntu Live zumindest nicht. Sollte wohl noch Fedora testen falls möglich.
- Nein, keine zusätzlichen USB Geräte.
- Nein, nur GNOME.
Dein dmesg Auszug hat denke ich nichts mit deinem Problem zu tun. Wenn du da z.B. nach "blacklist duplicate linux amd problem" googelst kommen da diverse Foren Einträge. Da gehts um irgendwas mit UEFI und keys wärend dem Bootvorgang, nicht um Suspend.
Wobei, wenn der Lüfter läuft klingt es ja eher nach Suspend Level S3, also nach Supend to RAM.
Vielleicht wäre es auch eine Möglichkeit den Suspend Leven auf S4 und damit auf Hibernation zu wechseln.
Eine Anleitung dazu wäre ja im ArchWiki gegeben.
Aber man merkt, dass die Hoffnung noch nicht aufgegeben ist, wir hätten noch viele Dinge zu testen, bevor es an ein Bug-Reporting oder ähnliches geht..
Bei den meisten Distris ist mit "Suspend" supsend to RAM gemeint. Hibernation ist meist per Default gar nicht mehr verfügbar, weil häufig per Default gar kein Swap mehr eingerichtet wird.
Das ist schon möglich, aber da er LVM verwendet wäre es also kein Thema den swap sogar über eine Partition nachträglich einzurichten, ansonsten einfach über ein swap file.
Letztlich geht es ja nur darum den Fehler einzugrenzen.
Man müsste dann natürlich noch wie erwähnt das suspend Level ändern.
Leute, hört doch mal auf mit dem Blödsinn. Der TE hat im Startpost die langsam blinkende Deckel LED beschrieben. Das ist Suspend to RAM und braucht kein Swap. Punktum.
Ich finde unter Linux den Sprachgebrauch Suspend vs. Hibernate am eingängigsten, schliesslich heisst es auch auf der Kommadozeile (systemctl) und am Desktop so.
Wie gesagt: Die aktuellste Live Version von Ubuntu - Lenovo zertifiziert - (läuft auf USB bootable) führt zum gleichen Resultat (kein Aufwachen aus Suspend).
Nach Lesen weiterer Foreneinträge - die zwar teilweise leicht differenzierende Problematiken beschrieben - stellt sich die Frage, ob die Problematik auch unter Windows besteht und letztlich ein von Lenovo nicht behobener Firmware Defekt ist. Das werde ich noch ausprobieren.
EDIT: Auch die aktuellste Fedora Live Version (welche teilweise von Lenovo Staff als Referenz für Linux Software angeführt wird) führt zum gleichen Resultat.
Von Suspend Problemen unter Linux bei AMD Geräten hab ich schon öfters gelesen. Ich habe selbst kein AMD Gerät. Aber allgemeines Googeln nach Suspend + problem + linux + AMD bringt einige Suchergebnisse.
This system was tested with 20.04 LTS, running the 5.14.0-1047-oem kernel.
Dafür gibts kein fertiges Livesystem, leider.
Querverweis auf anderen Thread des TE:
EDITH hat eben gefunden: Du bist nicht allein mit Suspend-Problemen, auch extrem erfahrene Linux User leiden darunter: https://kofler.info/ubuntu-24-10/
Ja du hast recht. Windows User beschweren sich aber auch:
Hier gibts die alten Ubuntu images:
Nicht mit OEM-Kernel.
Dein Thinkpad benutzt weder S3 (Suspend to RAM, deep) noch S4 (Suspend to disk, Hibernate) sondern S0ix (Race to idle, s2idle) für den Suspend. Zeigt dir tlp-stat -s auch an:
+++ System Info
Suspend mode   = [s2idle]
War bei mir ein Lenovo Legion 5 und kein Thinkpad, aber eventuell hilft es.
Ich hatte bei meinem mit Debian 12 das Problem das er nicht mehr aufwachte. Ein installieren des Paketes "acpid" oder "acpi-support", bin mir nicht mehr sicher welches es war, hatte bei mir funktioniert.
Ich erinnere mich auch noch daran das dass Aufwachen immer etwas gedauert hat, so 5-10 Sekunden.
UPDATE: Nach Kontakt mit Lenovo (vgl. https://forums.lenovo.com/t5/Other-...6aad9ef5e3cdf094abd16859e4f620&page=1#6461197) hat sich vorerst gezeigt, dass die Deaktivierung von "Secure Boot" und die Aktivierung von "Third Party Software" im BIOS das Problem scheinbar gelöst hat.
Third Party leuchtet halbwegs ein. Auch wenn es schade ist, dass anscheinend proprietäre Software benötigt wird um aus dem offenen Betriebssystem aufzuwachen.. (???)
Über die Option von Secure Boot bin ich überrascht, aber dann habe ich wohl das ganze Thema Supend nicht verstanden und wie es funktioniert..
Den Zusammenhang zu Secure Boot leuchtet mir auch nicht ein, außer dass es scheinbar so tief low level ist, dass es die Suspend Funktion beeinflusst.
Um welche Drittsnbieter Software handelt es sich denn genau?
Ich persönlich kann nur auf die proprietäre Firmware schließen oder den sata Controller what ever.
Ist so oder so seltsam, dass das Gerät anscheinend Ubuntu zertifiziert ist..
