- 20 Apr. 2007
Model and version Model: | Lenovo A5500-F Version: WLAN Lenovo A5500-H *Version: WLAN + 3G (Data only) Lenovo A5500-HV *Version: WLAN + 3G (Voice) |
Dimensions | 217 x 136 x 8.95 (mm) |
Weight | 360g - 644g |
Operating system | Android v4.2 Jelly Bean Android Upgrade Plan Upgrade option: Android 4.4 (KitKat) Available: May, 2014 via Over-the-Air (OTA) |
Display-Type | Capacitive touchscreen Display-Size 8" HD (1280 x 800) IPS Multitouch 10-point multitouch |
Color | Midnight Blue, White, Flamenco Red, Canary Yellow (3G only) |
Ports/slots | Micro-SIM (optional) |
Camera | Rear: 5 MP Fixed-focus Front: 2 MP Fixed-focus |
Sensors | G-Sensor (Accelerometer) / Vibration (+ proximity and light sensors in 3G version) |
Processor | MTK 8382 / 8121 1.3 GHz Quad-Core |
Sound | 2 x Speakers / Dolby® Audio / 3.5 mm Jack (1x speaker for WiFi version) |
Memory | RAM: 1GB ROM: 16GB Expandable up to 32GB |
Battery | Type : 4200 mAh Li-Po, fixed Standby Time : Up to 20 days (WiFi / 2G / 3G) Usage Time : Up to 11 hours (WiFi / 2G / 3G) |
Connectivity | 2G Networks: GSM / EDGE 900/1800/1900 MHz 3G Networks: WCDMA 2100/900 MHz |
Radio | FM Receiver |
Speed | HSPA+ 21 Mbps (DL) / 5.76 Mbps (UL) Data GSM, GPRS, EDGE, WCDMA |
WLAN | WiFi 802.11 b/g/n, WiFi hotspot |
Bluetooth | Bluetooth® 4.0 |
GPS | A - GPS |
Lieferumfang:
- Tab A8
- USB-Kabel
- Netzteil
Zum Aufladen des Akkus:
Lademethode | Display on (Device on) | Display off (Device off or in screen lock mode) |
ac adapter | Supported, but the battery will charge slowly. | Supported |
USB connection between the dc-in connector on the device and a USB connector on a personal computer or other device that comply with the USB 2.0 standards. Users have to use the connection to USB interfaces with USB 2.0 version or higher. | Supported, but will compensate power consumption and the battery will charge more slowly than usual. | Supported, but the battery will charge slowly. |
Infos bei Lenovo
HMM
