CloneBD 1.1.9.4 beta (elby)
https://www.elby.ch/download/SetupCloneBD1194.exe
Changelog CloneBD Blu-ray Media Converter
1.1.9.4 beta 2018-03-28
- fixed: possible crash when copying stream files w/o video from UHD source
- changed: allow to deselect audio/subtitle streams with partial copies and "keep original menu", when
playlist has subpaths
- fixed: (cosmetic) retain auxiliary stream information for HD audio over sessions
- changed: always show create log file button
- fixed: Ultra HDs with AVC 1080p video
- fixed: nVidia decoder aftefacts on Ultra HD input
- fixed: scale error with 1080p on Ultra HD source
- new: option to autosave log files after every conversion (default: on)
- new: add format BD-R(E) XL for burning (experimental)
- changed: video limiter to protect maximum muxrate in case of high audio bitrates
- many minor fixes and improvements
- updated languages
1.1.9.3 beta 2018-03-22
- fixed: scaling artefact occurred when converting 3D source to MKV top/bottom format
- fixed: descriptor 05 output for HEVC (caused CloneBD to not read its own UHD copies correctly)
- fixed: frame rate for fields encoded NTSC
- fixed: AUD NAL unit now grouped correctly
- fixed: MKV HEVC private header (CodecPrivate)
- fixed: regression: lossless UHD to MKV would not play on all players
- fixed: regression: playlists with subpaths were not handled correctly
- fixed: autoadjust preselected output size, when toggling Dolby Vision removal
- updated languages
1.1.9.2 beta 2018-03-14
- fixed: support for more UHD discs
- fixed: lossless copy of HEVC to Matroska (.mkv)
- fixed: VC-1 playback for some BBC blu-ray titles
- new: option to remove DolbyVision
- fixed: LPCM decoding on some audio Blu-rays
- fixed: DTS-HD decoding on some Japanese Blu-rays
- fixed: transcoding for some blu-ray titles with rapidly changing video bitrate
- improved: hardware video encoding on AMD GPUs
- improved: HEVC software encoding
- improved: AVC video encoding parameters to support more hardware players
- fixed: retain Dolby Vision SEI
- fixed: support format changed in clpi for Dolby Vision
- new: downconvert Ultra HD to Blu-ray with HDR to SDR conversion and removal of UHD extension (partial copies only)
- fixed: misbehaving progress bar on UHD source
- updated languages
1.1.9.1 beta 2018-02-05
- Fix: UHD multiplexing
- Fix: Atmos audio tracks
- Fix: HEVC with HDR meta data
- Improved: better support for XP on Win32 machines
- updated languages
1.1.9.0 2018-01-12
- Fix: added correct UHD lossless profile for partial disc copy (previously caused failures due to improper mux rate)
- Fix: allow removal of source disc while creating an ISO or burning to a disc in another drive.
- Fix: correctly identify outdated v1.00 playlist format
- Fix: aspect ratio of MKV files if SAR is not 1:1
- Fix libx264 8-bit encoding on x86 machines
- Fix typo: CloneBD displayed 4:3 aspect ratio as 4:2
- Fix: progressbar would not operate correctly on complete copies with angle support
- Fix: auto-selection of audio/subtitle languages at playback time on partial copies could be incorrect,
if multiple tracks of the same language are present
- Improved: flush of decoder images, MPEG-2 480p/1080i/576p update
- Fix: MPEG-2 video descriptor
- Fix: software encoding on 32bit Windows was broken
- Change: software encoding Windows XP was disabled, reenabled again
- Note: while CloneBD will work with Windows XP and 32bit Windows in general, it is not a recommended
platform, unless hardware acceleration is used. Especially HEVC encoding is extremely slow.
- updated languages
