Elby CloneBD 1.1.4.0
- Change: AMD acceleration uses CBR until VBR bitrate issue is resolved
- Fix: crash in new stream consistency check
- Fix: random crash when copying small files uncompressed while rebuilding PMT
- minor fixes and improvements
- Fix: prevent encoders from staying idle if the cpu is used for other tasks
- Fix: early aborts due a wrong signal from the demultiplexer
- Fix: support odd AVC format by some Japanese BD recorders
- Workaround: recover from invalid data in some PGS steams
- Workaround: adjust incorrect AVC aspect ratio information in some sources
- Improved: ensure, temp path exists, when writing playlist files
- Fix: lossless copy on very small clips with many audio/subtitle tracks could cause an exception
- Fix: AVC crash during seeking when PPS changes
- updated languages
Ist auch grade im "Angebot"
http://elby.ch/
