Interessante Tools und Programme
VLC media player liegt in der Version 2.2.4 zum Download bereit.
Changelog
LibreCAD steht in der Version 2.1.0 zum Download bereit.
Changelog
MSI Afterburner steht in der Version 4.3.0 Beta 4 zum Bezug bereit.
NVIDIA stellt den Notebook Quadro-Treiber für Windows 10 in der Version 368.39 (WHQL) zum Download bereit.
Quadro Desktop/Quadro Notebook Driver 368.39 (WHQL) - Windows 10 - 64Bit
Quadro Desktop/Quadro Notebook Driver 368.39 (WHQL) - Windows 10 - 32Bit
Release Notes
NVIDIA stellt den Notebook Quadro-Treiber für Windows 7/8/8.1 in der Version 368.39 (WHQL) zum Download bereit.
Quadro Desktop/Quadro Notebook Driver 368.39 (WHQL) - Windows 7/8/8.1 - 64Bit
Quadro Desktop/Quadro Notebook Driver 368.39 (WHQL) - Windows 7/8/8.1 - 32Bit
Release Notes
Wireshark liegt in der Version 2.0.4 zum Download bereit.
Total Commander steht in der Version 9.00 Beta 1 zum Bezug bereit.
Changelog
VeraCrypt steht in der Version 1.18 Beta 6 zum Download bereit.
Changelog
Changes between 1.17 and 1.18-BETA6 (5 May 2016) :
(this build brings EFI support preview in a separate installer)
(it also adds options to hide waiting dialog and also option to skip rescue disk verification)
Windows:
  • First experimental support of EFI system encryption (limitatations: no rescue disk, no hidden os, no boot custom message)
  • Fix boot issues on some machines by increasing required memory by 1 KiB
  • Correctly remove driver file veracrypt.sys during uninstall on Windows 64-bit.
  • Implement passing smart card PIN as command line argument (/tokenpin) when explicitly mounting a volume.
  • When no drive letter specified, choose A: or B: only when no other free drive letter is available.
  • Reduce CPU usage caused by the option to disable use of disconnected network drives.
  • Add new volume ID mechanism to be used to identify disks/partitions instead of their device name.
  • Add option to avoid PIM prompt in pre-boot authentication by storing PIM value unencrypted in MBR.
  • Add option and command line switch to hide waiting dialog when performing operations.
  • Add checkbox in "VeraCrypt Format" wizard GUI to skip Rescue Disk verification during system encryption procedure.
  • Allow files drag-n-drop when VeraCrypt is running as elevated process.
  • Minor GUI and translations fixes.
Linux:
  • Fix mount issue on Fedora 23.
  • Adhere to XDG Desktop Specification by using XDG_CONFIG_HOME to determine location of configuration files.
Mac OSX:
  • Solve compatibility issue with newer versions of OSXFuse.
StartIsBack für Windows 8, 8.1 und 10
StartIsBack für Windows 8, 8.1 und 10 ist für mich der beste Startmenüersatz für Windows. Das Programm liegt vor für (jeweils Link zum direkten Download):
Im Gegensatz zu Classic Shell unterstützt StartIsBack alle Funktionen des bekannten Startmenüs aus Windows 7. So lassen sich z.B. Startmenüeinträge direkt über das Kontextmenü löschen und StartIsBack passt sich auch ohne besondere Skin direkt an die Farbe der Taskleiste an.
attachment.php
Nach Ablauf der Testperiode kostet das Programm einmalig $2,99.
Ich wollte mich nur mal schnell explizit für eure Arbeit (speziell Helios) hier bedanken, habe schon die ein oder andere Perle gefunden. :thumbup:
Danke Dir, Axel. :)
AdwCleaner, ein kostenloses Tool zur Desinfektion von Adware, PUPs, Toolbars und Hijackers, steht in der Version 5.200 zum Download bereit.
Changelog
VeraCrypt steht in der Version 1.18 Beta 8 zum Download bereit.
Telegram - eine kostenlose und sichere Messaging-Anwendung, welche auf allen Geräten gleichzeitig nutzbar ist (Mobiltelefone, Tablets, Computer) - steht in der stabilen Version 0.9.51 für Windows zum Bezug bereit.
Version History
Total Commander steht in der Version 9.00 Beta 2 zum Bezug bereit.
Changelog
Sandboxie steht in der Version 5.12 zum Bezug bereit.
Changelog
Oracle VM Virtualbox steht in der Version 5.0.22 zum Bezug bereit.
Changelog
DAEMON Tools Lite liegt in der Version 10.4.0 (mit SPTD 1.89) für Windows 7/8/8.1/10 zum Download bereit.
Changelog
WSUS Offline Update steht in der Version 10.6.3 zum Download bereit.
Changelog
- Added scan prerequisite update kb3161664 (MS16-073) (Thanks to "Denniss" and "Dalai")
- C++ 2013 Redistributable Runtime Libraries updated to v. 12.0.40649.5 (Thanks to "harry")
- Aria2 download utility updated to v. 1.23.0 (Thanks to "harry")
- DownloadUpdates.cmd script will now also support x64 variant of Sysinternals' Sigcheck tool v. 2.51+ (Thanks to "harry")
- Fix: Querying state of service 'Windows Update' (wuauserv) could fail on foreign systems (Thanks to P. Pellegrini)
- Fix: Errors on running version check fired misleading new version notifications (Thanks to "Telli")
- Fix: Renamed md5deep to hashdeep in Linux script DownloadUpdates.sh (Thanks to B. Marwell)
- Fix: Replaced superseded Visio 2010 Security Update kb3114402 (MS16-004) by kb3114872 (MS16-070)
- Fix: Replaced superseded Visio 2016 Security Update kb3114511 (MS16-004) by kb3115041 (MS16-070)
- Fix: FAQs enhanced and corrected (Thanks to "jonas" and "aker")
VeraCrypt sowie VeraCrypt EFI stehen in den Version 1.18 Beta 9 zum Download bereit.
CrystalDiskInfo steht in der Version 7.0.0 zum Download bereit (ohne Adware OpenCandy).
Changelog
qBittorrent, eine Open-Source Alternative zu uTorrent, steht für Windows sowie Linux in der Version 3.3.5 zum Download bereit.
Changelog
GPU-Z steht in der Version 0.8.9 zum Bezug bereit.
Changelog
CCleaner steht in der Version 5.19.5633 zum Bezug bereit.
Version History
Total Commander steht in der Version 9.00 Beta 3 zum Bezug bereit.
Changelog
Bandizip, ein kostenloses und vielseitiges Packprogramm, steht für Windows in der Version 5.15 zum Download bereit.
Changelog
LibreOffice liegt in der Version 5.1.4 zum Download vor.
Changelog
HashTab steht in der Version 6.0.0.28 zum Bezug bereit und ist kostenlos für den privaten Gebrauch, für Studenten und nicht kommerzielle Unternehmen oder Organisationen.
Intel® Solid State Drive Toolbox steht in der Version 3.3.6 zum Download bereit.
Changelog
Telegram - eine kostenlose und sichere Messaging-Anwendung, welche auf allen Geräten gleichzeitig nutzbar ist (Mobiltelefone, Tablets, Computer) - steht in der stabilen Version 0.9.56 für Windows zum Bezug bereit.
Version History
LibreCAD steht in der Version 2.1.1 zum Download bereit.
Changelog
Visual Studio 2015 Update 3 steht zum Download bereit.
Changelog
Macrium Reflect Free steht in der Version 6.1.1366 zum Download bereit.
Changelog
AdwCleaner, ein kostenloses Tool zur Desinfektion von Adware, PUPs, Toolbars und Hijackers, steht in der Version 5.201 zum Download bereit.
Changelog
ParkControl, ein kostenloses Tool zur Steuerung der CPU-Eigenschaften, steht in der Version 1.0.3.2 zum Download bereit.
Changes to ParkControl v1.0.3.2:
  • Add capacity to install or remove the Bitsum Highest Performance power plan. On uninstall, it is removed if it was created only if Process Lasso is not also present (which also uses BHP).
  • Change code that selects default browser to use when opening hyperlinks.
  • Language updates.
Ich möchte euch auch mal ein kleines Tool vorstellen. Das ganze nennt sich Plumb und ist - meiner Meinung nach - der beste Ersatz für einen Tiling Window Manager unter Windows. Zumindest gibt es nicht allzu viel zu konfigurieren (praktisch, wenn man häufig den Rechner wechselt) und das Tiling-Verhalten sagt mir sehr zu. Alternativen sind nur wenige vorhanden.
Es funktioniert unter Windows 2000 aufwärts und ist sehr einfach und unkompliziert gestaltet. Mir hat es bereits seit einigen Wochen die Arbeit erleichtert und es lief währenddessen durchwegs stabil.
Download: http://palatialsoftware.com/plumb/
Der größte Nachteil ist, dass nur ein Onlineinstaller vorhanden ist (also am besten nach der Installation die Programmdateien sichern, falls man es auf einen Rechner ohne Internet installieren möchte oder man die gleiche Sorge trägt, dass Software nicht ewig im Netz verfügbar ist). Ansonsten ist es tlw. etwas unruhig beim Anordnen der Fenster, was wohl an den Einschränkungen des Windows Explorers liegt.
Wer von Linux kommt und sowas unter Windows bisher immer vermisst hat, der sollte es sich allerdings unbedingt einmal ansehen.
XFLR5
Ein tolles Programm mit Gui zur Auslegung und aerodynamischen Berechnung von Modellflugzeugen, Profilanalyse und Stabilitätsanalyse. Sei es zum Berechnen des Schwerpunktes eines bestehenden Modelles oder zum Konstruieren eines eigenen Flugzeuges. Das Programm rechnet mit XFoil.
Die Software gibt es für Windows, Mac OS und Linux.
