- 11 Juli 2008
Ebenfalls Danke! Seit dem Update auf 8.0 (32-bit und 64-bit) funktionieren endlich wieder die Java-Applets im Browser. :thumbup:Danke für die Infos!
Habe JRE 7.0 gegen 8.0 getauscht und das einzige (mir bekannte) auf JRE angewiesene Programm läuft klaglos - wenn nicht gar zügiger.
Nmap ("Network Mapper") is a free and open source (license) utility for network discovery and security auditing. Many systems and network administrators also find it useful for tasks such as network inventory, managing service upgrade schedules, and monitoring host or service uptime. Nmap uses raw IP packets in novel ways to determine what hosts are available on the network, what services (application name and version) those hosts are offering, what operating systems (and OS versions) they are running, what type of packet filters/firewalls are in use, and dozens of other characteristics. It was designed to rapidly scan large networks, but works fine against single hosts. Nmap runs on all major computer operating systems, and official binary packages are available for Linux, Windows, and Mac OS X.
Version 1.66 - Changelog
- Added /NoErrorMessage command-line option. If you specify it with a save command-line option, an error message won't be displayed if the save action is failed. Instead, the error code will be returned to the caller.
