--- TLP 0.3.9 --------------------------------------------
+++ Configured Settings: /etc/default/tlp
TLP_ENABLE=1
DISK_IDLE_SECS_ON_AC=0
DISK_IDLE_SECS_ON_BAT=0
MAX_LOST_WORK_SECS_ON_AC=15
MAX_LOST_WORK_SECS_ON_BAT=60
SCHED_POWERSAVE_ON_AC=0
SCHED_POWERSAVE_ON_BAT=1
NMI_WATCHDOG=0
DISK_DEVICES="sda sdb"
DISK_APM_LEVEL_ON_AC="254 254"
DISK_APM_LEVEL_ON_BAT="254 254"
SATA_LINKPWR_ON_AC=max_performance
SATA_LINKPWR_ON_BAT=min_power
PCIE_ASPM_ON_AC=performance
PCIE_ASPM_ON_BAT=powersave
RADEON_POWER_PROFILE_ON_AC=high
RADEON_POWER_PROFILE_ON_BAT=low
WIFI_PWR_ON_AC=1
WIFI_PWR_ON_BAT=5
WOL_DISABLE=Y
SOUND_POWER_SAVE=1
SOUND_POWER_SAVE_CONTROLLER=Y
BAY_POWEROFF_ON_BAT=0
BAY_DEVICE="sr0"
RUNTIME_PM_ON_AC=on
RUNTIME_PM_ON_BAT=auto
RUNTIME_PM_ALL=0
USB_AUTOSUSPEND=1
RESTORE_DEVICE_STATE_ON_STARTUP=0
DEVICES_TO_DISABLE_ON_STARTUP="bluetooth wwan"
+++ System Info
System = LENOVO ThinkPad X201 Tablet 311396G
BIOS = 6QET68WW (1.38 )
Release = Ubuntu 12.04.2 LTS
Kernel = 3.5.0-37-generic x86_64
/proc/cmdline = BOOT_IMAGE=/boot/vmlinuz-3.5.0-37-generic root=UUID=595a93f9-38c0-446d-9d3f-5f6b636f6264 ro quiet splash vt.handoff=7
+++ System Status
TLP power save = enabled
power source = battery
+++ Processor
CPU Model = Intel(R) Core(TM) i7 CPU L 640 @ 2.13GHz
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor = ondemand
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq = 1199000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 2134000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies = 2134000 2133000 1999000 1866000 1733000 1599000 1466000 1333000 1199000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor = ondemand
/sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq = 1199000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq = 2134000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_available_frequencies = 2134000 2133000 1999000 1866000 1733000 1599000 1466000 1333000 1199000 [kHz]
/sys/devices/system/cpu/cpu2/cpufreq/scaling_governor = ondemand
/sys/devices/system/cpu/cpu2/cpufreq/scaling_min_freq = 1199000 [kHz]
/sys/devices/system/cpu/cpu2/cpufreq/scaling_max_freq = 2134000 [kHz]
/sys/devices/system/cpu/cpu2/cpufreq/scaling_available_frequencies = 2134000 2133000 1999000 1866000 1733000 1599000 1466000 1333000 1199000 [kHz]
/sys/devices/system/cpu/cpu3/cpufreq/scaling_governor = ondemand
/sys/devices/system/cpu/cpu3/cpufreq/scaling_min_freq = 1199000 [kHz]
/sys/devices/system/cpu/cpu3/cpufreq/scaling_max_freq = 2134000 [kHz]
/sys/devices/system/cpu/cpu3/cpufreq/scaling_available_frequencies = 2134000 2133000 1999000 1866000 1733000 1599000 1466000 1333000 1199000 [kHz]
/sys/devices/system/cpu/cpufreq/boost = (not available)
/proc/sys/kernel/nmi_watchdog = 0
+++ Undervolting
PHC kernel not available.
+++ Temperatures
/proc/acpi/ibm/thermal = 52 0 0 0 0 0 0 0 [°C]
/proc/acpi/ibm/fan = 3940 [/min]
+++ File System
/proc/sys/vm/laptop_mode = 0
/proc/sys/vm/dirty_writeback_centisecs = 6000
/proc/sys/vm/dirty_expire_centisecs = 6000
/proc/sys/vm/dirty_ratio = 60
/proc/sys/vm/dirty_background_ratio = 40
/proc/sys/fs/xfs/age_buffer_centisecs = (not available)
/proc/sys/fs/xfs/xfssyncd_centisecs = (not available)
/proc/sys/fs/xfs/xfsbufd_centisecs = (not available)
+++ Storage Devices
/dev/sda:
Model = Samsung SSD 840 PRO Series
Firmware = DXM05B0Q
APM Level = none/disabled
Status = active/idle
TRIM = supported
scheduler = deadline
SMART info:
5 Reallocated_Sector_Ct = 0
9 Power_On_Hours = 194 [h]
177 Wear_Leveling_Count = 99 [%]
179 Used_Rsvd_Blk_Cnt_Tot = 0
190 Airflow_Temperature_Cel = 39 [°C]
241 Total_LBAs_Written = 0.213 [TB]
+++ SATA Aggressive Link Power Management
/sys/class/scsi_host/host0/link_power_management_policy = min_power
/sys/class/scsi_host/host1/link_power_management_policy = min_power
/sys/class/scsi_host/host2/link_power_management_policy = min_power
/sys/class/scsi_host/host3/link_power_management_policy = min_power
/sys/class/scsi_host/host4/link_power_management_policy = min_power
/sys/class/scsi_host/host5/link_power_management_policy = min_power
+++ PCIe Active State Power Management
/sys/module/pcie_aspm/parameters/policy = default (using bios preferences)
+++ Intel Graphics
/sys/module/i915/parameters/powersave = 1 (enabled)
/sys/module/i915/parameters/i915_enable_rc6 = -1 (use per-chip default)
/sys/module/i915/parameters/i915_enable_fbc = -1 (use per-chip default)
/sys/module/i915/parameters/lvds_downclock = 0 (disabled)
/sys/module/i915/parameters/semaphores = -1 (use per-chip default)
+++ Wireless
bluetooth = off (software)
wifi = on
wwan = on
wlan0(iwlwifi): power management = on
+++ Audio
/sys/module/snd_hda_intel/parameters/power_save = 1
/sys/module/snd_hda_intel/parameters/power_save_controller = Y
+++ ThinkPad Extended Battery Functions
tp-smapi = active
tpacpi-bat = inactive (kernel module 'acpi_call' not installed)
+++ ThinkPad Battery Status (Main)
/sys/devices/platform/smapi/BAT0/manufacturer = SANYO
/sys/devices/platform/smapi/BAT0/model = 42T4658
/sys/devices/platform/smapi/BAT0/manufacture_date = 2011-03-09
/sys/devices/platform/smapi/BAT0/first_use_date = 2011-05-27
/sys/devices/platform/smapi/BAT0/cycle_count = 274
/sys/devices/platform/smapi/BAT0/design_capacity = 66240 [mWh]
/sys/devices/platform/smapi/BAT0/last_full_capacity = 40450 [mWh]
/sys/devices/platform/smapi/BAT0/remaining_capacity = 27600 [mWh]
/sys/devices/platform/smapi/BAT0/remaining_percent = 68 [%]
/sys/devices/platform/smapi/BAT0/remaining_running_time_now = 63 [min]
/sys/devices/platform/smapi/BAT0/remaining_charging_time = not_charging [min]
/sys/devices/platform/smapi/BAT0/power_now = -20479 [mW]
/sys/devices/platform/smapi/BAT0/power_avg = -13173 [mW]
/sys/devices/platform/smapi/BAT0/start_charge_thresh = 96 [%]
/sys/devices/platform/smapi/BAT0/stop_charge_thresh = 100 [%]
/sys/devices/platform/smapi/BAT0/force_discharge = 0
+++ Runtime Power Management
/sys/bus/pci/devices/0000:00:00.0/power/control = auto (0x060000 Host bridge)
/sys/bus/pci/devices/0000:00:02.0/power/control = on (0x030000 VGA compatible controller)
/sys/bus/pci/devices/0000:00:16.0/power/control = on (0x078000 Communication controller)
/sys/bus/pci/devices/0000:00:16.3/power/control = on (0x070002 Serial controller)
/sys/bus/pci/devices/0000:00:19.0/power/control = auto (0x020000 Ethernet controller)
/sys/bus/pci/devices/0000:00:1a.0/power/control = on (0x0c0320 USB controller)
/sys/bus/pci/devices/0000:00:1b.0/power/control = auto (0x040300 Audio device)
/sys/bus/pci/devices/0000:00:1c.0/power/control = on (0x060400 PCI bridge)
/sys/bus/pci/devices/0000:00:1c.3/power/control = on (0x060400 PCI bridge)
/sys/bus/pci/devices/0000:00:1c.4/power/control = on (0x060400 PCI bridge)
/sys/bus/pci/devices/0000:00:1d.0/power/control = on (0x0c0320 USB controller)
/sys/bus/pci/devices/0000:00:1e.0/power/control = on (0x060401 PCI bridge)
/sys/bus/pci/devices/0000:00:1f.0/power/control = on (0x060100 ISA bridge)
/sys/bus/pci/devices/0000:00:1f.2/power/control = on (0x010601 SATA controller)
/sys/bus/pci/devices/0000:00:1f.3/power/control = on (0x0c0500 SMBus)
/sys/bus/pci/devices/0000:00:1f.6/power/control = on (0x118000 Signal processing controller)
/sys/bus/pci/devices/0000:02:00.0/power/control = auto (0x028000 Network controller)
/sys/bus/pci/devices/0000:ff:00.0/power/control = auto (0x060000 Host bridge)
/sys/bus/pci/devices/0000:ff:00.1/power/control = auto (0x060000 Host bridge)
/sys/bus/pci/devices/0000:ff:02.0/power/control = auto (0x060000 Host bridge)
/sys/bus/pci/devices/0000:ff:02.1/power/control = auto (0x060000 Host bridge)
/sys/bus/pci/devices/0000:ff:02.2/power/control = auto (0x060000 Host bridge)
/sys/bus/pci/devices/0000:ff:02.3/power/control = auto (0x060000 Host bridge)
+++ USB
tlp usb autosuspend = enabled
tlp usb blacklist = (not configured)
Bus 001 Device 002 ID 8087:0020 control = auto, autosuspend_delay_ms = 2000 -- Intel Corp. Integrated Rate Matching Hub (hub)
Bus 002 Device 002 ID 8087:0020 control = auto, autosuspend_delay_ms = 2000 -- Intel Corp. Integrated Rate Matching Hub (hub)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 2.0 root hub (hub)
Bus 002 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 2.0 root hub (hub)
Bus 001 Device 004 ID 147e:2016 control = auto, autosuspend_delay_ms = 2000 -- Upek Biometric Touchchip/Touchstrip Fingerprint Sensor (no driver)
Bus 001 Device 005 ID 17ef:4816 control = auto, autosuspend_delay_ms = 2000 -- Lenovo (uvcvideo)
Bus 002 Device 003 ID 05c6:9205 control = auto, autosuspend_delay_ms = 2000 -- Qualcomm, Inc. (qmi_wwan, qcserial)
max@max-x201t:~$ clear
max@max-x201t:~$ rf
rfcomm rfkill
max@max-x201t:~$ rfkill list
0: tpacpi_bluetooth_sw: Bluetooth
Soft blocked: yes
Hard blocked: no
1: tpacpi_wwan_sw: Wireless WAN
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
max@max-x201t:~$ sudo tlp-stat
TLP_ENABLE=1
NMI_WATCHDOG=0
WIFI_PWR_ON_AC=1
WIFI_PWR_ON_BAT=5
WOL_DISABLE=Y
SOUND_POWER_SAVE=1
BAY_DEVICE="sr0"
RUNTIME_PM_ON_AC=on
RUNTIME_PM_ALL=0
USB_AUTOSUSPEND=1
+++ System Info
+++ System Status
+++ Processor
+++ Undervolting
+++ Temperatures
/proc/acpi/ibm/thermal = 51 0 0 0 0 0 0 0 [°C]
/proc/acpi/ibm/fan = 1954 [/min]
+++ File System
+++ Storage Devices
/dev/sda:
Firmware = DXM05B0Q
TRIM = supported
SMART info:
+++ Intel Graphics
+++ Wireless
wifi = on
wwan = on
+++ Audio
tp-smapi = active
/sys/devices/platform/smapi/BAT0/remaining_capacity = 25320 [mWh]
/sys/devices/platform/smapi/BAT0/remaining_percent = 63 [%]
/sys/devices/platform/smapi/BAT0/remaining_running_time_now = 137 [min]
/sys/devices/platform/smapi/BAT0/power_now = -9839 [mW]
/sys/devices/platform/smapi/BAT0/power_avg = -12154 [mW]
+++ USB
