Debian Jessie auf T22
exc64user
23 Okt. 2015
Hallo
Meine Frage ist ob es jemand schon geschafft hat, Debian 8 Jessie erfolgreich zu installieren und dabei die Auflösung Display bei 1024x768 läuft.
Bei mir geht nur 800x600. Habe in der Xorg Logdatei einige probs gefunden weis nur nicht warum er nicht die Aufläsung macht.
) SAVAGE(0): I2C bus "I2C bus" initialized.
[    25.306] (II) SAVAGE(0): I2C device "I2C bus:ddc2" registered at address 0xA0.
[    25.309] (--) SAVAGE(0): Detected current MCLK value of 83.045 MHz
[    25.309] (--) SAVAGE(0): 1024x768 TFT LCD panel detected and active
[    25.309] (--) SAVAGE(0): - Limiting video mode to 1024x768
[    25.345] (--) SAVAGE(0): Found 13 modes at this depth:
[    25.345]     [10e] 320 x 200, 70Hz
[    25.345]     [111] 640 x 480, 60Hz, 72Hz, 75Hz, 85Hz, 100Hz
[    25.345]     [114] 800 x 600, 60Hz, 72Hz, 75Hz, 85Hz, 100Hz
[    25.345]     [117] 1024 x 768, 60Hz, 70Hz, 75Hz, 85Hz, 43Hz, 100Hz
[    25.346]     [11a] 1280 x 1024, 60Hz, 75Hz, 85Hz, 43Hz
[    25.346]     [11d] 640 x 400, 70Hz
[    25.346]     [122] 1600 x 1200, 48Hz, 60Hz, 75Hz, 85Hz
[    25.346]     [133] 320 x 240, 72Hz
[    25.346]     [13c] 1400 x 1050, 60Hz, 75Hz
[    25.346]     [143] 400 x 300, 72Hz
[    25.346]     [153] 512 x 384, 70Hz
[    25.346]     [173] 720 x 480, 75Hz
[    25.346]     [178] 720 x 576, 75Hz
[    25.346] (II) SAVAGE(0): <default monitor>: Using hsync range of 31.50-47.30 kHz
[    25.346] (II) SAVAGE(0): <default monitor>: Using vrefresh range of 56.00-59.87 Hz
[    25.346] (II) SAVAGE(0): <default monitor>: Using maximum pixel clock of 56.00 MHz
[    25.346] (II) SAVAGE(0): Estimated virtual size for aspect ratio 1.3333 is 1024x768
[    25.347] (II) SAVAGE(0): Clock range:  10.00 to 250.00 MHz
[    25.347] (--) SAVAGE(0): No suitable BIOS mode found for 640x350 85Hz.
[    25.347] (II) SAVAGE(0): Not using default mode "640x350" (no mode of this name)
[    25.347] (--) SAVAGE(0): No suitable BIOS mode found for 320x175 85Hz.
[    25.347] (II) SAVAGE(0): Not using default mode "320x175" (no mode of this name)
[    25.347] (--) SAVAGE(0): Chose mode 11d at 70Hz.
[    25.347] (II) SAVAGE(0): Not using default mode "640x400" (vrefresh out of range)
[    25.347] (--) SAVAGE(0): Chose mode 10e at 70Hz.
[    25.347] (II) SAVAGE(0): Not using default mode "320x200" (vrefresh out of range)
[    25.347] (--) SAVAGE(0): No suitable BIOS mode found for 720x400 85Hz.
[    25.347] (II) SAVAGE(0): Not using default mode "720x400" (no mode of this name)
[    25.347] (--) SAVAGE(0): No suitable BIOS mode found for 360x200 85Hz.
[    25.347] (II) SAVAGE(0): Not using default mode "360x200" (no mode of this name)
[    25.347] (--) SAVAGE(0): Chose mode 111 at 60Hz.
[    25.347] (--) SAVAGE(0): Chose mode 133 at 72Hz.
[    25.347] (--) SAVAGE(0): Chose mode 111 at 72Hz.
[    25.347] (II) SAVAGE(0): Not using default mode "640x480" (vrefresh out of range)
[    25.347] (II) SAVAGE(0): Not using default mode "320x240" (vrefresh out of range)
[    25.347] (--) SAVAGE(0): Chose mode 111 at 75Hz.
[    25.348] (--) SAVAGE(0): Chose mode 133 at 72Hz.
[    25.348] (II) SAVAGE(0): Not using default mode "320x240" (vrefresh out of range)
[    25.348] (--) SAVAGE(0): Chose mode 111 at 85Hz.
[    25.348] (II) SAVAGE(0): Not using default mode "640x480" (vrefresh out of range)
[    25.348] (--) SAVAGE(0): Chose mode 114 at 60Hz.
[    25.348] (--) SAVAGE(0): Chose mode 143 at 72Hz.
[    25.348] (--) SAVAGE(0): Chose mode 114 at 72Hz.
[    25.348] (II) SAVAGE(0): Not using default mode "800x600" (hsync out of range)
[    25.348] (II) SAVAGE(0): Not using default mode "400x300" (hsync out of range)
[    25.348] (--) SAVAGE(0): Chose mode 114 at 75Hz.
[    25.348] (II) SAVAGE(0): Not using default mode "800x600" (vrefresh out of range)
[    25.348] (II) SAVAGE(0): Not using default mode "400x300" (vrefresh out of range)
[    25.348] (--) SAVAGE(0): Chose mode 114 at 85Hz.
[    25.348] (--) SAVAGE(0): Chose mode 117 at 85Hz.
[    25.348] (II) SAVAGE(0): Not using default mode "1024x768i" (vrefresh out of range)
[    25.348] (--) SAVAGE(0): Chose mode 153 at 70Hz.
[    25.348] (II) SAVAGE(0): Not using default mode "512x384i" (vrefresh out of range)
[    25.349] (--) SAVAGE(0): Chose mode 117 at 60Hz.
[    25.349] (II) SAVAGE(0): Not using default mode "1024x768" (hsync out of range)
[    25.349] (--) SAVAGE(0): Chose mode 153 at 70Hz.
[    25.349] (II) SAVAGE(0): Not using default mode "512x384" (hsync out of range)
[    25.349] (--) SAVAGE(0): Chose mode 117 at 70Hz.
[    25.349] (--) SAVAGE(0): Chose mode 117 at 75Hz.
[    25.349] (--) SAVAGE(0): Chose mode 117 at 85Hz.
[    25.349] (II) SAVAGE(0): Not using default mode "1152x864" (width too large for virtual size)
[    25.349] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 75Hz.
[    25.349] (II) SAVAGE(0): Not using default mode "576x432" (no mode of this name)
[    25.349] (II) SAVAGE(0): Not using default mode "1280x960" (width too large for virtual size)
[    25.349] (--) SAVAGE(0): Chose mode 111 at 60Hz.
[    25.349] (II) SAVAGE(0): Not using default mode "640x480" (hsync out of range)
[    25.349] (--) SAVAGE(0): Chose mode 111 at 85Hz.
[    25.349] (II) SAVAGE(0): Not using default mode "1280x1024" (width too large for virtual size)
[    25.349] (--) SAVAGE(0): No suitable BIOS mode found for 640x512 60Hz.
[    25.349] (II) SAVAGE(0): Not using default mode "640x512" (no mode of this name)
[    25.349] (--) SAVAGE(0): No suitable BIOS mode found for 640x512 75Hz.
[    25.350] (II) SAVAGE(0): Not using default mode "640x512" (no mode of this name)
[    25.350] (II) SAVAGE(0): Not using default mode "1280x1024" (width too large for virtual size)
[    25.350] (--) SAVAGE(0): No suitable BIOS mode found for 640x512 85Hz.
[    25.350] (II) SAVAGE(0): Not using default mode "1600x1200" (width too large for virtual size)
[    25.350] (--) SAVAGE(0): Chose mode 114 at 60Hz.
[    25.350] (II) SAVAGE(0): Not using default mode "800x600" (hsync out of range)
[    25.350] (--) SAVAGE(0): Chose mode 114 at 72Hz.
[    25.350] (--) SAVAGE(0): Chose mode 114 at 75Hz.
[    25.350] (--) SAVAGE(0): Chose mode 114 at 85Hz.
[    25.350] (II) SAVAGE(0): Not using default mode "1792x1344" (width too large for virtual size)
[    25.350] (--) SAVAGE(0): No suitable BIOS mode found for 896x672 60Hz.
[    25.350] (II) SAVAGE(0): Not using default mode "896x672" (no mode of this name)
[    25.350] (--) SAVAGE(0): No suitable BIOS mode found for 896x672 75Hz.
[    25.350] (II) SAVAGE(0): Not using default mode "1856x1392" (width too large for virtual size)
[    25.350] (--) SAVAGE(0): No suitable BIOS mode found for 928x696 60Hz.
[    25.350] (II) SAVAGE(0): Not using default mode "928x696" (no mode of this name)
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 928x696 75Hz.
[    25.351] (II) SAVAGE(0): Not using default mode "928x696" (no mode of this name)
[    25.351] (II) SAVAGE(0): Not using default mode "1920x1440" (width too large for virtual size)
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 960x720 60Hz.
[    25.351] (II) SAVAGE(0): Not using default mode "960x720" (no mode of this name)
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 960x720 75Hz.
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 832x624 74Hz.
[    25.351] (II) SAVAGE(0): Not using default mode "832x624" (no mode of this name)
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 416x312 74Hz.
[    25.351] (II) SAVAGE(0): Not using default mode "416x312" (no mode of this name)
[    25.351] (II) SAVAGE(0): Not using default mode "1152x864" (width too large for virtual size)
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 60Hz.
[    25.351] (II) SAVAGE(0): Not using default mode "576x432" (no mode of this name)
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 70Hz.
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 74Hz.
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 85Hz.
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 100Hz.
[    25.352] (II) SAVAGE(0): Not using default mode "1360x768" (width too large for virtual size)
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 680x384 59Hz.
[    25.352] (II) SAVAGE(0): Not using default mode "680x384" (no mode of this name)
[    25.352] (II) SAVAGE(0): Not using default mode "1400x1050" (width too large for virtual size)
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 700x525 59Hz.
[    25.352] (II) SAVAGE(0): Not using default mode "700x525" (no mode of this name)
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 700x525 70Hz.
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 700x525 74Hz.
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 700x525 85Hz.
[    25.352] (II) SAVAGE(0): Not using default mode "1440x900" (width too large for virtual size)
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 720x450 59Hz.
[    25.352] (II) SAVAGE(0): Not using default mode "720x450" (no mode of this name)
[    25.352] (II) SAVAGE(0): Not using default mode "1600x1024" (width too large for virtual size)
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 800x512 60Hz.
[    25.352] (II) SAVAGE(0): Not using default mode "800x512" (no mode of this name)
[    25.352] (II) SAVAGE(0): Not using default mode "1680x1050" (width too large for virtual size)
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 59Hz.
[    25.352] (II) SAVAGE(0): Not using default mode "840x525" (no mode of this name)
[    25.353] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 60Hz.
[    25.353] (II) SAVAGE(0): Not using default mode "840x525" (no mode of this name)
[    25.353] (II) SAVAGE(0): Not using default mode "1680x1050" (width too large for virtual size)
[    25.353] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 69Hz.
[    25.353] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 74Hz.
[    25.353] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 85Hz.
[    25.353] (II) SAVAGE(0): Not using default mode "1920x1080" (width too large for virtual size)
[    25.353] (--) SAVAGE(0): No suitable BIOS mode found for 960x540 59Hz.
[    25.353] (II) SAVAGE(0): Not using default mode "960x540" (no mode of this name)
[    25.353] (II) SAVAGE(0): Not using default mode "1920x1200" (width too large for virtual size)
[    25.353] (--) SAVAGE(0): No suitable BIOS mode found for 960x600 59Hz.
[    25.353] (II) SAVAGE(0): Not using default mode "960x600" (no mode of this name)
[    25.353] (II) SAVAGE(0): Not using default mode "1920x1440" (width too large for virtual size)
[    25.353] (--) SAVAGE(0): No suitable BIOS mode found for 960x720 85Hz.
[    25.353] (II) SAVAGE(0): Not using default mode "960x720" (no mode of this name)
[    25.353] (II) SAVAGE(0): Not using default mode "2048x1536" (width too large for virtual size)
[    25.353] (--) SAVAGE(0): Chose mode 117 at 60Hz.
[    25.353] (II) SAVAGE(0): Not using default mode "1024x768" (hsync out of range)
[    25.353] (--) SAVAGE(0): Chose mode 117 at 75Hz.
[    25.353] (--) SAVAGE(0): Chose mode 117 at 85Hz.
[    25.354] (--) SAVAGE(0): Chose mode 117 at 100Hz.
[    25.354] (II) SAVAGE(0): Not using driver mode "1024x768" (hsync out of range)
[    25.354] (--) SAVAGE(0): Chose mode 114 at 60Hz.
[    25.354] (--) SAVAGE(0): Chose mode 111 at 60Hz.
[    25.354] (--) SAVAGE(0): Chose mode 143 at 72Hz.
[    25.354] (--) SAVAGE(0): Chose mode 133 at 72Hz.
[    25.354] (WW) SAVAGE(0): Shrinking virtual size estimate from 1024x768 to 800x600
[    25.354] (--) SAVAGE(0): Virtual size is 800x600 (pitch 800)
Wieso testest du nicht einfach mal Arch aus? Die haben die alten DRI-Treiber alle in ihren Paketen mit drin
Eine interessante Möglichkeit, ich wäre neugierig auf das Ergebnis. Aber wie gesagt läuft das nicht mit aktuellen X-Servern zusammen. Letztlich schöpfen ja alle aus denselben Quellen.
also scheint das ja jemand noch getestet zu haben
Ob das dann wirklich jemand getestet hat, steht in den Sternen. Da wird zwar alter Kram, so gut es geht, mitgezogen, aber nicht mehr weiterentwickelt. Leider. Durch im Laufe der Zeit zunehmend mangelnde Softwareunterstützung wird viel Hardwareschrott produziert, damit der Motor der endlosen Konsumspirale nicht ins Stocken gerät. Ich habe z.B. noch einen Scanner, für den nur und ausschließlich Treiber für Win98 zur bereitgestellt wurden.
Naja, als Hardwareschrott würde ich das nicht direkt bezeichnen. Du würdest mit so alten Schätzchen vermutlich auch nicht mehr produktiv arbeiten, denen geht ja bei bisschen aufwendigeren Webseiten schon recht schnell die Puste aus. Aber es gibt ja auch noch andere Verwendungzwecke dafür. Ich habe z.B. einen alten Laptop (P3 600Mhz, 320MB RAM) als "Server" mit einem aktuellen Debian 8 laufen. Der dient mir als SSH- und Owncloudserver. Da brauche ich kein X und für die Aufgaben ist mir die Hardware allemal performant und sparsam genug.
Sondern? In meinem Beispiel habe ich die Wahl, den Scanner zu entsorgen oder einen Rechner mit einer Win98-Installation vorzuhalten. Mit einer Savage-Graphik bist Du mit einer ähnlichen Frage konfrontiert.
Verschätze Dich nicht. Du kannst vielleicht wegen des begrenzten Arbeitsspeichers nicht 100 Tabs gleichzeitig offen haben oder irgendwelche Videos in hoher Auflösung angucken, aber für einen Nicht-Multimediajunkie reicht das allemal (unnötigen Mist blocken ist immer gut, auch die Pest Javascript, so weit es geht).
Ohne X, nur als Fileserver, würdest Du auch mit einem 486er glücklich werden. Dafür braucht's ja kaum CPU-Power.
Auf den T22 soll aber ein brauchbares X, und dafür muß man heute leider auf etwas angestaubtes ("veraltetes") Zeugs zurückgreifen. Das wenigste, was neu ist, ist automatisch besser oder abwärts kompatibel. Neue Software bedingt (relativ) neue Hardware und umgekehrt.
Damit läuft bei dir ein Owncloud? Das kann doch nicht mehr als schleichen sein, oder?
Naja, ist aber schon ein schnelles schleichen :thumbsup: Ne im Ernst, so viel langsamer als andere Owncloudlösungen die ich bis jetzt besuchen durfte ist meine Lösung gar nicht mal. Ich denke mein DSL ist da viel eher der Flaschenhals, aber für ein bisschen Dateiaustausch für alles was nicht per Mail weggeht oder auch von mehreren Leuten eingesehen/geändert werden soll ist das völlig ausreichend.
seit den letzten Tagen habe ich verschiedene Varianten von Optionen in der Device-Section in der xorg.conf getestet und bin nun zu einem zumindest halbwegs brauchbaren Ergebniss gekommen.
# Xorg.conf Datei für einen IBM Thinkpad T22 auf Debian 8.3 Jessie
Section "Device"
     Identifier         "S3 Inc.86C270-294 Savage/IX-MV"
     Driver             "savage"
     BusID              "PCI:1:0:0"
     Option             "HWCursor" "True"
    #Option             "DmaType" "PCI"
     Option             "BusType" "PCI"
     Option             "NoDDC"
    #Option             "ModeValidation" "NoMaxPClkCheck"
     Option             "AccelMethod" "exa"
    #Option             "Accel" "True"
    #Option             "ShadowFB" "True"
    #Option             "DisableCOB" "false"
    #Option             "NoPciBurst" "Enable"
    #Option             "FramebufferWC"
EndSection
mit diesen Einstellungen habe ich die besten Ergebnisse erhalten. Somit ist das Arbeiten unter xfce naja sagen wir mal befriedigend bis erträglich.
Mit lxde hatte ich das Gefühl das es ein tick schneller geht kann mich aber auch irren ist halt rein subjektiv.
Avi -xvid oder mkv Filme gehen recht gut und ruckelfrei. Libreoffice ist schon ein wenig zu fett da macht sich das fehlende dri schon negativ bemerkbar.
Da sollte man auf schlankere Office Varianten ausweichen.
Kde und Gnome kann man sich abschminken das benötigt in jedem fall dri. Leider ist Mesa 7.11.2 die letzte wo dri mit savage noch möglich war.
Diese Version von mesa war noch bei Debian 7 Wheezy und opensuse 12.2 dabei.
Mein persönliches Fazit: eine schlanke grafische Oberfläche wie LXDE oder XFCE kombiniert mit leistungsfähigen textbasierten Programmen ( wovon es unter Linux sehr viele gibt)
Leider ist Mesa 7.11.2 die letzte wo dri mit savage noch möglich war. Diese Version von mesa war noch bei Debian 7 Wheezy und opensuse 12.2 dabei.
Was spricht denn eigentlich dagegen, beispielsweise Wheezy mit anständiger Graphikbeschleunigung einzusetzen?
Aber danke für die Info. Vielleicht hebe ich meine Squeeze-Kiste doch bei Gelegenheit mal auf Wheezy hoch. Sofern ich mich nicht irre, bleibt man damit auch noch vor dem Systemd-Geschlunze verschont ...
Gegen Squeeze spricht, dass jeglicher Support seit 29.02.2016 ausgelaufen ist. Auch der nur auf eine stark eingeschränkte Anzahl an Paketen angebotene Long-Term-Support. Squeeze noch zu nutzen (zumindest im Netz) ist eine ähnlich gute Idee wie XP noch zu nutzen.
Gegen Wheezy spricht, dass der Standard-Support im April (25.04.2016) ausläuft. Ab dann gibt es auch nur noch stark eingeschränkten Long-Term-Support, der nur einen Bruchteil der Pakete versorgt. Dann sollte man also SEHR genau gucken, welche Pakete man im System installiert (hat) und ob diese noch supportet werden. Falls nicht: Runter damit - oder eben gleich auf Jessie gehen, in diesem Fall aber mit dem eingeschränkten Grafik-Support.
AFAIK gibt es Mesa 7.11 noch in Ubuntu 12.04. Das könnte man noch installieren. Der Support läuft aber auch in gut 1 Jahr aus (April 2017). Ob man Mesa 7.11 in Ubuntu 14.04 noch zum Laufen bekommt, weiß ich nicht.
mit BSD kenne ich mich nicht aus da kann ich nichts dazu sagen ob da noch DRI 1 unterstützt wird. Aber alle moderneren Distries haben neuere Versionen von Mesa und die unterstützen DRI 2 sind aber leider nicht abwertskompatibel zu DRI 1 und nur diese würde mit den Savage-Treiber arbeiten.
Da hat man die Qual der Wahl - entweder eine alte Distri mit dri aber ohne Support oder eine modernere aber ohne oder wenig Grafik .
Letztendlich wird das jeder für sich entscheiden müssen.
