Debian Jessie auf T22
exc64user
23 Okt. 2015
Hallo
Meine Frage ist ob es jemand schon geschafft hat, Debian 8 Jessie erfolgreich zu installieren und dabei die Auflösung Display bei 1024x768 läuft.
Bei mir geht nur 800x600. Habe in der Xorg Logdatei einige probs gefunden weis nur nicht warum er nicht die Aufläsung macht.
) SAVAGE(0): I2C bus "I2C bus" initialized.
[    25.306] (II) SAVAGE(0): I2C device "I2C bus:ddc2" registered at address 0xA0.
[    25.309] (--) SAVAGE(0): Detected current MCLK value of 83.045 MHz
[    25.309] (--) SAVAGE(0): 1024x768 TFT LCD panel detected and active
[    25.309] (--) SAVAGE(0): - Limiting video mode to 1024x768
[    25.345] (--) SAVAGE(0): Found 13 modes at this depth:
[    25.345]     [10e] 320 x 200, 70Hz
[    25.345]     [111] 640 x 480, 60Hz, 72Hz, 75Hz, 85Hz, 100Hz
[    25.345]     [114] 800 x 600, 60Hz, 72Hz, 75Hz, 85Hz, 100Hz
[    25.345]     [117] 1024 x 768, 60Hz, 70Hz, 75Hz, 85Hz, 43Hz, 100Hz
[    25.346]     [11a] 1280 x 1024, 60Hz, 75Hz, 85Hz, 43Hz
[    25.346]     [11d] 640 x 400, 70Hz
[    25.346]     [122] 1600 x 1200, 48Hz, 60Hz, 75Hz, 85Hz
[    25.346]     [133] 320 x 240, 72Hz
[    25.346]     [13c] 1400 x 1050, 60Hz, 75Hz
[    25.346]     [143] 400 x 300, 72Hz
[    25.346]     [153] 512 x 384, 70Hz
[    25.346]     [173] 720 x 480, 75Hz
[    25.346]     [178] 720 x 576, 75Hz
[    25.346] (II) SAVAGE(0): <default monitor>: Using hsync range of 31.50-47.30 kHz
[    25.346] (II) SAVAGE(0): <default monitor>: Using vrefresh range of 56.00-59.87 Hz
[    25.346] (II) SAVAGE(0): <default monitor>: Using maximum pixel clock of 56.00 MHz
[    25.346] (II) SAVAGE(0): Estimated virtual size for aspect ratio 1.3333 is 1024x768
[    25.347] (II) SAVAGE(0): Clock range:  10.00 to 250.00 MHz
[    25.347] (--) SAVAGE(0): No suitable BIOS mode found for 640x350 85Hz.
[    25.347] (II) SAVAGE(0): Not using default mode "640x350" (no mode of this name)
[    25.347] (--) SAVAGE(0): No suitable BIOS mode found for 320x175 85Hz.
[    25.347] (II) SAVAGE(0): Not using default mode "320x175" (no mode of this name)
[    25.347] (--) SAVAGE(0): Chose mode 11d at 70Hz.
[    25.347] (II) SAVAGE(0): Not using default mode "640x400" (vrefresh out of range)
[    25.347] (--) SAVAGE(0): Chose mode 10e at 70Hz.
[    25.347] (II) SAVAGE(0): Not using default mode "320x200" (vrefresh out of range)
[    25.347] (--) SAVAGE(0): No suitable BIOS mode found for 720x400 85Hz.
[    25.347] (II) SAVAGE(0): Not using default mode "720x400" (no mode of this name)
[    25.347] (--) SAVAGE(0): No suitable BIOS mode found for 360x200 85Hz.
[    25.347] (II) SAVAGE(0): Not using default mode "360x200" (no mode of this name)
[    25.347] (--) SAVAGE(0): Chose mode 111 at 60Hz.
[    25.347] (--) SAVAGE(0): Chose mode 133 at 72Hz.
[    25.347] (--) SAVAGE(0): Chose mode 111 at 72Hz.
[    25.347] (II) SAVAGE(0): Not using default mode "640x480" (vrefresh out of range)
[    25.347] (II) SAVAGE(0): Not using default mode "320x240" (vrefresh out of range)
[    25.347] (--) SAVAGE(0): Chose mode 111 at 75Hz.
[    25.348] (--) SAVAGE(0): Chose mode 133 at 72Hz.
[    25.348] (II) SAVAGE(0): Not using default mode "320x240" (vrefresh out of range)
[    25.348] (--) SAVAGE(0): Chose mode 111 at 85Hz.
[    25.348] (II) SAVAGE(0): Not using default mode "640x480" (vrefresh out of range)
[    25.348] (--) SAVAGE(0): Chose mode 114 at 60Hz.
[    25.348] (--) SAVAGE(0): Chose mode 143 at 72Hz.
[    25.348] (--) SAVAGE(0): Chose mode 114 at 72Hz.
[    25.348] (II) SAVAGE(0): Not using default mode "800x600" (hsync out of range)
[    25.348] (II) SAVAGE(0): Not using default mode "400x300" (hsync out of range)
[    25.348] (--) SAVAGE(0): Chose mode 114 at 75Hz.
[    25.348] (II) SAVAGE(0): Not using default mode "800x600" (vrefresh out of range)
[    25.348] (II) SAVAGE(0): Not using default mode "400x300" (vrefresh out of range)
[    25.348] (--) SAVAGE(0): Chose mode 114 at 85Hz.
[    25.348] (--) SAVAGE(0): Chose mode 117 at 85Hz.
[    25.348] (II) SAVAGE(0): Not using default mode "1024x768i" (vrefresh out of range)
[    25.348] (--) SAVAGE(0): Chose mode 153 at 70Hz.
[    25.348] (II) SAVAGE(0): Not using default mode "512x384i" (vrefresh out of range)
[    25.349] (--) SAVAGE(0): Chose mode 117 at 60Hz.
[    25.349] (II) SAVAGE(0): Not using default mode "1024x768" (hsync out of range)
[    25.349] (--) SAVAGE(0): Chose mode 153 at 70Hz.
[    25.349] (II) SAVAGE(0): Not using default mode "512x384" (hsync out of range)
[    25.349] (--) SAVAGE(0): Chose mode 117 at 70Hz.
[    25.349] (--) SAVAGE(0): Chose mode 117 at 75Hz.
[    25.349] (--) SAVAGE(0): Chose mode 117 at 85Hz.
[    25.349] (II) SAVAGE(0): Not using default mode "1152x864" (width too large for virtual size)
[    25.349] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 75Hz.
[    25.349] (II) SAVAGE(0): Not using default mode "576x432" (no mode of this name)
[    25.349] (II) SAVAGE(0): Not using default mode "1280x960" (width too large for virtual size)
[    25.349] (--) SAVAGE(0): Chose mode 111 at 60Hz.
[    25.349] (II) SAVAGE(0): Not using default mode "640x480" (hsync out of range)
[    25.349] (--) SAVAGE(0): Chose mode 111 at 85Hz.
[    25.349] (II) SAVAGE(0): Not using default mode "1280x1024" (width too large for virtual size)
[    25.349] (--) SAVAGE(0): No suitable BIOS mode found for 640x512 60Hz.
[    25.349] (II) SAVAGE(0): Not using default mode "640x512" (no mode of this name)
[    25.349] (--) SAVAGE(0): No suitable BIOS mode found for 640x512 75Hz.
[    25.350] (II) SAVAGE(0): Not using default mode "640x512" (no mode of this name)
[    25.350] (II) SAVAGE(0): Not using default mode "1280x1024" (width too large for virtual size)
[    25.350] (--) SAVAGE(0): No suitable BIOS mode found for 640x512 85Hz.
[    25.350] (II) SAVAGE(0): Not using default mode "1600x1200" (width too large for virtual size)
[    25.350] (--) SAVAGE(0): Chose mode 114 at 60Hz.
[    25.350] (II) SAVAGE(0): Not using default mode "800x600" (hsync out of range)
[    25.350] (--) SAVAGE(0): Chose mode 114 at 72Hz.
[    25.350] (--) SAVAGE(0): Chose mode 114 at 75Hz.
[    25.350] (--) SAVAGE(0): Chose mode 114 at 85Hz.
[    25.350] (II) SAVAGE(0): Not using default mode "1792x1344" (width too large for virtual size)
[    25.350] (--) SAVAGE(0): No suitable BIOS mode found for 896x672 60Hz.
[    25.350] (II) SAVAGE(0): Not using default mode "896x672" (no mode of this name)
[    25.350] (--) SAVAGE(0): No suitable BIOS mode found for 896x672 75Hz.
[    25.350] (II) SAVAGE(0): Not using default mode "1856x1392" (width too large for virtual size)
[    25.350] (--) SAVAGE(0): No suitable BIOS mode found for 928x696 60Hz.
[    25.350] (II) SAVAGE(0): Not using default mode "928x696" (no mode of this name)
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 928x696 75Hz.
[    25.351] (II) SAVAGE(0): Not using default mode "928x696" (no mode of this name)
[    25.351] (II) SAVAGE(0): Not using default mode "1920x1440" (width too large for virtual size)
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 960x720 60Hz.
[    25.351] (II) SAVAGE(0): Not using default mode "960x720" (no mode of this name)
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 960x720 75Hz.
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 832x624 74Hz.
[    25.351] (II) SAVAGE(0): Not using default mode "832x624" (no mode of this name)
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 416x312 74Hz.
[    25.351] (II) SAVAGE(0): Not using default mode "416x312" (no mode of this name)
[    25.351] (II) SAVAGE(0): Not using default mode "1152x864" (width too large for virtual size)
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 60Hz.
[    25.351] (II) SAVAGE(0): Not using default mode "576x432" (no mode of this name)
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 70Hz.
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 74Hz.
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 85Hz.
[    25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 100Hz.
[    25.352] (II) SAVAGE(0): Not using default mode "1360x768" (width too large for virtual size)
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 680x384 59Hz.
[    25.352] (II) SAVAGE(0): Not using default mode "680x384" (no mode of this name)
[    25.352] (II) SAVAGE(0): Not using default mode "1400x1050" (width too large for virtual size)
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 700x525 59Hz.
[    25.352] (II) SAVAGE(0): Not using default mode "700x525" (no mode of this name)
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 700x525 70Hz.
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 700x525 74Hz.
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 700x525 85Hz.
[    25.352] (II) SAVAGE(0): Not using default mode "1440x900" (width too large for virtual size)
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 720x450 59Hz.
[    25.352] (II) SAVAGE(0): Not using default mode "720x450" (no mode of this name)
[    25.352] (II) SAVAGE(0): Not using default mode "1600x1024" (width too large for virtual size)
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 800x512 60Hz.
[    25.352] (II) SAVAGE(0): Not using default mode "800x512" (no mode of this name)
[    25.352] (II) SAVAGE(0): Not using default mode "1680x1050" (width too large for virtual size)
[    25.352] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 59Hz.
[    25.352] (II) SAVAGE(0): Not using default mode "840x525" (no mode of this name)
[    25.353] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 60Hz.
[    25.353] (II) SAVAGE(0): Not using default mode "840x525" (no mode of this name)
[    25.353] (II) SAVAGE(0): Not using default mode "1680x1050" (width too large for virtual size)
[    25.353] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 69Hz.
[    25.353] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 74Hz.
[    25.353] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 85Hz.
[    25.353] (II) SAVAGE(0): Not using default mode "1920x1080" (width too large for virtual size)
[    25.353] (--) SAVAGE(0): No suitable BIOS mode found for 960x540 59Hz.
[    25.353] (II) SAVAGE(0): Not using default mode "960x540" (no mode of this name)
[    25.353] (II) SAVAGE(0): Not using default mode "1920x1200" (width too large for virtual size)
[    25.353] (--) SAVAGE(0): No suitable BIOS mode found for 960x600 59Hz.
[    25.353] (II) SAVAGE(0): Not using default mode "960x600" (no mode of this name)
[    25.353] (II) SAVAGE(0): Not using default mode "1920x1440" (width too large for virtual size)
[    25.353] (--) SAVAGE(0): No suitable BIOS mode found for 960x720 85Hz.
[    25.353] (II) SAVAGE(0): Not using default mode "960x720" (no mode of this name)
[    25.353] (II) SAVAGE(0): Not using default mode "2048x1536" (width too large for virtual size)
[    25.353] (--) SAVAGE(0): Chose mode 117 at 60Hz.
[    25.353] (II) SAVAGE(0): Not using default mode "1024x768" (hsync out of range)
[    25.353] (--) SAVAGE(0): Chose mode 117 at 75Hz.
[    25.353] (--) SAVAGE(0): Chose mode 117 at 85Hz.
[    25.354] (--) SAVAGE(0): Chose mode 117 at 100Hz.
[    25.354] (II) SAVAGE(0): Not using driver mode "1024x768" (hsync out of range)
[    25.354] (--) SAVAGE(0): Chose mode 114 at 60Hz.
[    25.354] (--) SAVAGE(0): Chose mode 111 at 60Hz.
[    25.354] (--) SAVAGE(0): Chose mode 143 at 72Hz.
[    25.354] (--) SAVAGE(0): Chose mode 133 at 72Hz.
[    25.354] (WW) SAVAGE(0): Shrinking virtual size estimate from 1024x768 to 800x600
[    25.354] (--) SAVAGE(0): Virtual size is 800x600 (pitch 800)
also wenn ich dies so mache, dann startet der xserver nicht mehr d.h grub bootet und kurz vor dem xerverstart kommen einige gelbe linien und ende.
Glücklicherweise stopt hier nur der xserver und nicht der Kernel. Somit konnte ich mit f1 noch in die Konsole und mit nano die conf wieder Bearbeiten.
DisableC0B "false" geht also nicht und hsync, vsync ModLines mit # geht auch nicht also alles wieder auf Anfang.
Dieses Problem erinnert mich daran als ich so um 2014 versucht habe opensuse 12.3 und etwas später opensuse 13.1 vergeblich auf dem T22 zu instalieren. Da hatte ich das gleiche wie jetzt mit Debian 8.3.
Hast du eh immer nur eine Änderung ausprobiert und nicht alle 4 auf einmal?
Alles ausser Direct Rendering (DRI) ist imho Schmuck am Nachthemd, da würde ich erstmal keine Zeit darauf verwenden. Offensichtlich benötigt dein Desktop (GNOME 3?) DRI für eine performante Ausgabe. Entweder Du schaffst es DRI zu aktivieren oder Du probierst mal einen anderen Desktop --> XFCE, LXDE, ...
ich habe xfce. Laut xorg.log will er ja dri aktivieren aber das klappt nicht. Verlangt nach der Option DisableCOB false aber diese ist nicht verwendbar weil dann sich der xserver aufhängt.
Compositemanager (xcompmgr oder compton) macht's schneller.
Aber was steht im Log, wenn der Server abschmiert?
das ist ja das komische. Als der xserver still stand bin ich per f1 in die Konsole und habe mir die xorg.log angeschaut.
Da war nichts anders als jetzt auch. Dann habe ich in der root Konsole ein X eingegeben und da kam die meldung das der xserver noch aktiv ist.
D.h der xserver ist gar nicht abgeschmiert er zeigte blos nichts mehr an und ich dachte er hätte sich aufgeängt.
Alles recht dubios oder aber der gute T22 ist einfach zu alt für solche Distries.
hier mal ein Nachtrag
dies ist nach umfangreichen Tests die einzige halbwegs brauchbare xorg.conf die ich herrausgefunden habe, wo ein Arbeiten möglich ist.
Wegen dem fehlen von dri etwas langsam aber erträglich.Eine Leichtgewichtige Installation ist aber Pflicht allein schon deswegen weil der T22 von sich aus kein Leistungswunder ist. DRI soll zwar möglich sein, aber nur wenn man den xserver mit den passenden Optionen und Einstellungen neu übersetzt.
Welche das sind muss ich noch in Erfahrung bringen es gibt aber infos darüber in einigen Foren.
Der Grund soll sein, das man den Orginal S3 Savage Treiber irgendwann gegen freie nicht properitäre Versionen ersetzt hat. Und diese sollen Probleme machen. Ich bleib dran und werde in den nächsten Wochen einige Versuche unternehmen.
# Xorg.conf Datei für einen IBM Thinkpad T22 auf Debian 8.3 Jessie
Section "Device"
     Identifier         "S3 Inc.86C270-294 Savage/IX-MV"
     Driver             "savage"
     BusID              "PCI:1:0:0"
     Option             "DmaType" "PCI"
     Option             "BusType" "PCI"
     Option             "NoDDC"
    #Option             "ModeValidation" "NoMaxPClkCheck"
    #Option             "NoAccel" "True"
    #Option             "ShadowFB" "True"
    #Option             "DisableCOB" "false"
    #Option             "NoPciBurst" "Enable"
    #Option             "FramebufferWC"
EndSection
Section "Monitor"
     Identifier       "Configured Monitor"
    #Option    "DPMS"
     HorizSync    31.0-69.0
     VertRefresh  50.0-70.0
     ModeLine "1024x768" 56.00  1024 1072 1176 1328  768 771 775 798
EndSection
Section "Screen"
     Identifier       "Default Screen"
     Monitor          "Configured Monitor"
     Device           "S3 Inc.86C270-294 Savage/IX-MV"
     DefaultDepth      16
     Subsection "Display"
     Depth             16
     Modes             "1024x768"
     EndSubsection
EndSection
DRI ist aus dem Savage-Treiber schon längst raus. Das unterstützt niemand mehr und reißt wohl eine ziemliche Sicherheitslücke in das System. Ich glaube nicht, dass man den DRI-Teil des Savage-Treibers heute noch übersetzen kann.
Es wäre schon schön, wenn jemand DRI auf S3 wieder zum Laufen bekommen könnte, aber ich gebe dem wenig Hoffnung. Die proprietären Treiber funktionieren mit den aktuellen Interfaces von X11 schon lange nicht mehr, und DRI gehört eigentlich auch in den Kernel und nicht in Xorg. Wie dem auch sei, wenn Du hier etwas zum Funktionieren bekommst, wäre es schön, sich hier zu melden.
Auf dem T21 meiner Eltern läuft DRI mit Savage.
Aber dort ist auch Slitaz drauf und nicht Debian. Soweit ich weiß, hab' ich da auch mal eine alte Mesa7-Version eingespielt - damit ließ sich sogar GLTron unter 16bit-Auflösung spielen.
Wenn ich dazu komme, schau ich mal wieder genauer drauf.
So, ich habe dri drinn kann es aber nicht nutzen wegen einiger Zugriffsrechte
(II) xfree86: Adding drm device (/dev/dri/card0)
[    28.799] (EE) /dev/dri/card0: failed to set DRM interface version 1.4: Permission denied
weis noch nicht wie ich das lösen soll.
Das dri war eigendlich recht einfach. Ich musste nur mir die savage_dri.so holen. Diese Datei ist schon seit langer Zeit nicht mehr im Treiber savage_drv.so dabei. Aber es gibt sie noch. Ich habe sie aus einer alten xfree86 Mesa version von 2006 aber egal. Dann nur noch die dri savage Datei in das Modul-Treiber-Verzeichniss von x11 reinkopieren wo auch schon die anderen Treiber liegen und fertig.
Laut xorg.0.log keine dri bezogene Fehler.Alles sauber initialisiert und ist komplett bis auf diese permission denied sache.
Ich bezweifle, dass 10 Jahre alter Binärcode noch kompatibel ist.
.so-Dateien kopieren ist der falsche Weg.
So wie es aussieht, benötigt man für DRI auf der Savage Mesa 7.11.2.
Bis vor einigen Jahren haben das verschiedene Distros noch als mesa-legacy ausgeliefert, scheint aber niemand mehr zu machen. Müsstest du dir also selbst aus dem Quellcode bauen oder eine ältere Distribution verwenden.
Ob das auf einem aktuellen X-Server noch läuft, wage ich jedoch zu bezweifeln. Es wird einen guten Grund haben, wieso es nirgendwo mehr ausgeliefert wird.
Nachtrag: Arch Linux hat es noch! :)
gut möglich aber ich werde es mal ausbrobieren. Unter opensuse 12.2 habe ich es auch so gemacht und da war der Code auch schon so 7 Jahre alt und es hat funktioniert. Aber Du hast recht sehr wahrscheinlich ist es nicht aber man kann nie wissen.
demzufolge ist also debian 8 auf dem T22 so ziemlich bescheiden. Habe mir mal Lubuntu angeschaut könnte eine Alternative sein denn da brauche ich nicht dri und es wäre drotzdem recht flott.
Ganz einfach weil ich xfce und auch LXDE als Manager drauf habe und beide sind sehr langsam. Hab sogar mal Blackbox ausbrobiert (minimalischtischer gehts nicht) aber auch da das gleiche Problem.Allerdings wäre Blackbox auch in Lubuntu.
Mir kommt es so vor, als ob der Savage-Treiber gar nicht aktiv ist sondern irgendein Vesa oder Framebuffer Sache da läuft.
Denn wenn man ein Programmfenster minimiert und dann mit dem Cursor über den Bildschirm zieht, sollte das der Savage Treiber auch ohne DRI schaffen das Fenster einigermassen flüssig zu bewegen so aussergewöhnlich wäre das nicht.
Wie kann ich feststellen welcher Treiber gerade aktiv ist? als Modul ist er geladen was aber nicht heißt das er auch läuft.
Hallo, ich bin ja auch so ein Altmetaller ...
Meiner Vermutung nach ist Deine Savage zu alt für die aktuellen X-Server. Warum?
Meine Problemkinder sind die guten, alten Matrox-Karten auf PCs (mga, G400, G550). Da darf ich, um gute Graphikbeschleunigung zu haben, keinen Xorg-Server nach der Version 1.12.4 verwenden (Gentoo: x11-base/xorg-server-1.12.4-r5). Das hängt mit dem Opengl-Mesa-Kram zusammen. Die letzte brauchbare Mesa-Version ist 7.11.2.
Siehe auch: http://www.mesa3d.org/relnotes/8.0.html
(...) Removed all DRI drivers that did not support DRI2. Specifically, i810, mach64, mga, r128, savage, sis, tdfx, and unichrome were removed. (...)
Von daher wird es wohl wahrscheinlich so sein, daß man mit einer älteren Distribution bessere Erfolge hat.
Nachtrag:
Eben nicht. Du willst DRI haben, unbedingt, ansonsten wird das Arbeiten unter X unerträglich zäh und langsam.
Welcher Windowmanager oder welche Desktopumgebung dabei werkelt, spielt überhaupt keine Rolle.
Das habe ich befürchtet das dies mit debian 8 wohl nicht mehr laufen wird. Eine alte Mesa 7.11.2 Version zu instalieren wird wohl nicht gehen. Das war so 2012 mal aktuell.
Wieso testest du nicht einfach mal Arch aus? Die haben die alten DRI1-Treiber alle in ihren Paketen mit drin, siehe der Link von mir.
Das letzte Update war Dezember 2015, also scheint das ja jemand noch getestet zu haben.
Bevor du mit Distributionen rumwerkelst bei denen du alles aus den Quellen bauen müsstest...würde ich nicht machen.
auch wieder war dann werde ich mir mal Arch ansehen schaden kanns nicht.
