Hallo
Meine Frage ist ob es jemand schon geschafft hat, Debian 8 Jessie erfolgreich zu installieren und dabei die Auflösung Display bei 1024x768 läuft.
Bei mir geht nur 800x600. Habe in der Xorg Logdatei einige probs gefunden weis nur nicht warum er nicht die Aufläsung macht.
) SAVAGE(0): I2C bus "I2C bus" initialized.
[ 25.306] (II) SAVAGE(0): I2C device "I2C bus:ddc2" registered at address 0xA0.
[ 25.309] (--) SAVAGE(0): Detected current MCLK value of 83.045 MHz
[ 25.309] (--) SAVAGE(0): 1024x768 TFT LCD panel detected and active
[ 25.309] (--) SAVAGE(0): - Limiting video mode to 1024x768
[ 25.345] (--) SAVAGE(0): Found 13 modes at this depth:
[ 25.345] [10e] 320 x 200, 70Hz
[ 25.345] [111] 640 x 480, 60Hz, 72Hz, 75Hz, 85Hz, 100Hz
[ 25.345] [114] 800 x 600, 60Hz, 72Hz, 75Hz, 85Hz, 100Hz
[ 25.345] [117] 1024 x 768, 60Hz, 70Hz, 75Hz, 85Hz, 43Hz, 100Hz
[ 25.346] [11a] 1280 x 1024, 60Hz, 75Hz, 85Hz, 43Hz
[ 25.346] [11d] 640 x 400, 70Hz
[ 25.346] [122] 1600 x 1200, 48Hz, 60Hz, 75Hz, 85Hz
[ 25.346] [133] 320 x 240, 72Hz
[ 25.346] [13c] 1400 x 1050, 60Hz, 75Hz
[ 25.346] [143] 400 x 300, 72Hz
[ 25.346] [153] 512 x 384, 70Hz
[ 25.346] [173] 720 x 480, 75Hz
[ 25.346] [178] 720 x 576, 75Hz
[ 25.346] (II) SAVAGE(0): <default monitor>: Using hsync range of 31.50-47.30 kHz
[ 25.346] (II) SAVAGE(0): <default monitor>: Using vrefresh range of 56.00-59.87 Hz
[ 25.346] (II) SAVAGE(0): <default monitor>: Using maximum pixel clock of 56.00 MHz
[ 25.346] (II) SAVAGE(0): Estimated virtual size for aspect ratio 1.3333 is 1024x768
[ 25.347] (II) SAVAGE(0): Clock range: 10.00 to 250.00 MHz
[ 25.347] (--) SAVAGE(0): No suitable BIOS mode found for 640x350 85Hz.
[ 25.347] (II) SAVAGE(0): Not using default mode "640x350" (no mode of this name)
[ 25.347] (--) SAVAGE(0): No suitable BIOS mode found for 320x175 85Hz.
[ 25.347] (II) SAVAGE(0): Not using default mode "320x175" (no mode of this name)
[ 25.347] (--) SAVAGE(0): Chose mode 11d at 70Hz.
[ 25.347] (II) SAVAGE(0): Not using default mode "640x400" (vrefresh out of range)
[ 25.347] (--) SAVAGE(0): Chose mode 10e at 70Hz.
[ 25.347] (II) SAVAGE(0): Not using default mode "320x200" (vrefresh out of range)
[ 25.347] (--) SAVAGE(0): No suitable BIOS mode found for 720x400 85Hz.
[ 25.347] (II) SAVAGE(0): Not using default mode "720x400" (no mode of this name)
[ 25.347] (--) SAVAGE(0): No suitable BIOS mode found for 360x200 85Hz.
[ 25.347] (II) SAVAGE(0): Not using default mode "360x200" (no mode of this name)
[ 25.347] (--) SAVAGE(0): Chose mode 111 at 60Hz.
[ 25.347] (--) SAVAGE(0): Chose mode 133 at 72Hz.
[ 25.347] (--) SAVAGE(0): Chose mode 111 at 72Hz.
[ 25.347] (II) SAVAGE(0): Not using default mode "640x480" (vrefresh out of range)
[ 25.347] (II) SAVAGE(0): Not using default mode "320x240" (vrefresh out of range)
[ 25.347] (--) SAVAGE(0): Chose mode 111 at 75Hz.
[ 25.348] (--) SAVAGE(0): Chose mode 133 at 72Hz.
[ 25.348] (II) SAVAGE(0): Not using default mode "320x240" (vrefresh out of range)
[ 25.348] (--) SAVAGE(0): Chose mode 111 at 85Hz.
[ 25.348] (II) SAVAGE(0): Not using default mode "640x480" (vrefresh out of range)
[ 25.348] (--) SAVAGE(0): Chose mode 114 at 60Hz.
[ 25.348] (--) SAVAGE(0): Chose mode 143 at 72Hz.
[ 25.348] (--) SAVAGE(0): Chose mode 114 at 72Hz.
[ 25.348] (II) SAVAGE(0): Not using default mode "800x600" (hsync out of range)
[ 25.348] (II) SAVAGE(0): Not using default mode "400x300" (hsync out of range)
[ 25.348] (--) SAVAGE(0): Chose mode 114 at 75Hz.
[ 25.348] (II) SAVAGE(0): Not using default mode "800x600" (vrefresh out of range)
[ 25.348] (II) SAVAGE(0): Not using default mode "400x300" (vrefresh out of range)
[ 25.348] (--) SAVAGE(0): Chose mode 114 at 85Hz.
[ 25.348] (--) SAVAGE(0): Chose mode 117 at 85Hz.
[ 25.348] (II) SAVAGE(0): Not using default mode "1024x768i" (vrefresh out of range)
[ 25.348] (--) SAVAGE(0): Chose mode 153 at 70Hz.
[ 25.348] (II) SAVAGE(0): Not using default mode "512x384i" (vrefresh out of range)
[ 25.349] (--) SAVAGE(0): Chose mode 117 at 60Hz.
[ 25.349] (II) SAVAGE(0): Not using default mode "1024x768" (hsync out of range)
[ 25.349] (--) SAVAGE(0): Chose mode 153 at 70Hz.
[ 25.349] (II) SAVAGE(0): Not using default mode "512x384" (hsync out of range)
[ 25.349] (--) SAVAGE(0): Chose mode 117 at 70Hz.
[ 25.349] (--) SAVAGE(0): Chose mode 117 at 75Hz.
[ 25.349] (--) SAVAGE(0): Chose mode 117 at 85Hz.
[ 25.349] (II) SAVAGE(0): Not using default mode "1152x864" (width too large for virtual size)
[ 25.349] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 75Hz.
[ 25.349] (II) SAVAGE(0): Not using default mode "576x432" (no mode of this name)
[ 25.349] (II) SAVAGE(0): Not using default mode "1280x960" (width too large for virtual size)
[ 25.349] (--) SAVAGE(0): Chose mode 111 at 60Hz.
[ 25.349] (II) SAVAGE(0): Not using default mode "640x480" (hsync out of range)
[ 25.349] (--) SAVAGE(0): Chose mode 111 at 85Hz.
[ 25.349] (II) SAVAGE(0): Not using default mode "1280x1024" (width too large for virtual size)
[ 25.349] (--) SAVAGE(0): No suitable BIOS mode found for 640x512 60Hz.
[ 25.349] (II) SAVAGE(0): Not using default mode "640x512" (no mode of this name)
[ 25.349] (--) SAVAGE(0): No suitable BIOS mode found for 640x512 75Hz.
[ 25.350] (II) SAVAGE(0): Not using default mode "640x512" (no mode of this name)
[ 25.350] (II) SAVAGE(0): Not using default mode "1280x1024" (width too large for virtual size)
[ 25.350] (--) SAVAGE(0): No suitable BIOS mode found for 640x512 85Hz.
[ 25.350] (II) SAVAGE(0): Not using default mode "1600x1200" (width too large for virtual size)
[ 25.350] (--) SAVAGE(0): Chose mode 114 at 60Hz.
[ 25.350] (II) SAVAGE(0): Not using default mode "800x600" (hsync out of range)
[ 25.350] (--) SAVAGE(0): Chose mode 114 at 72Hz.
[ 25.350] (--) SAVAGE(0): Chose mode 114 at 75Hz.
[ 25.350] (--) SAVAGE(0): Chose mode 114 at 85Hz.
[ 25.350] (II) SAVAGE(0): Not using default mode "1792x1344" (width too large for virtual size)
[ 25.350] (--) SAVAGE(0): No suitable BIOS mode found for 896x672 60Hz.
[ 25.350] (II) SAVAGE(0): Not using default mode "896x672" (no mode of this name)
[ 25.350] (--) SAVAGE(0): No suitable BIOS mode found for 896x672 75Hz.
[ 25.350] (II) SAVAGE(0): Not using default mode "1856x1392" (width too large for virtual size)
[ 25.350] (--) SAVAGE(0): No suitable BIOS mode found for 928x696 60Hz.
[ 25.350] (II) SAVAGE(0): Not using default mode "928x696" (no mode of this name)
[ 25.351] (--) SAVAGE(0): No suitable BIOS mode found for 928x696 75Hz.
[ 25.351] (II) SAVAGE(0): Not using default mode "928x696" (no mode of this name)
[ 25.351] (II) SAVAGE(0): Not using default mode "1920x1440" (width too large for virtual size)
[ 25.351] (--) SAVAGE(0): No suitable BIOS mode found for 960x720 60Hz.
[ 25.351] (II) SAVAGE(0): Not using default mode "960x720" (no mode of this name)
[ 25.351] (--) SAVAGE(0): No suitable BIOS mode found for 960x720 75Hz.
[ 25.351] (--) SAVAGE(0): No suitable BIOS mode found for 832x624 74Hz.
[ 25.351] (II) SAVAGE(0): Not using default mode "832x624" (no mode of this name)
[ 25.351] (--) SAVAGE(0): No suitable BIOS mode found for 416x312 74Hz.
[ 25.351] (II) SAVAGE(0): Not using default mode "416x312" (no mode of this name)
[ 25.351] (II) SAVAGE(0): Not using default mode "1152x864" (width too large for virtual size)
[ 25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 60Hz.
[ 25.351] (II) SAVAGE(0): Not using default mode "576x432" (no mode of this name)
[ 25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 70Hz.
[ 25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 74Hz.
[ 25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 85Hz.
[ 25.351] (--) SAVAGE(0): No suitable BIOS mode found for 576x432 100Hz.
[ 25.352] (II) SAVAGE(0): Not using default mode "1360x768" (width too large for virtual size)
[ 25.352] (--) SAVAGE(0): No suitable BIOS mode found for 680x384 59Hz.
[ 25.352] (II) SAVAGE(0): Not using default mode "680x384" (no mode of this name)
[ 25.352] (II) SAVAGE(0): Not using default mode "1400x1050" (width too large for virtual size)
[ 25.352] (--) SAVAGE(0): No suitable BIOS mode found for 700x525 59Hz.
[ 25.352] (II) SAVAGE(0): Not using default mode "700x525" (no mode of this name)
[ 25.352] (--) SAVAGE(0): No suitable BIOS mode found for 700x525 70Hz.
[ 25.352] (--) SAVAGE(0): No suitable BIOS mode found for 700x525 74Hz.
[ 25.352] (--) SAVAGE(0): No suitable BIOS mode found for 700x525 85Hz.
[ 25.352] (II) SAVAGE(0): Not using default mode "1440x900" (width too large for virtual size)
[ 25.352] (--) SAVAGE(0): No suitable BIOS mode found for 720x450 59Hz.
[ 25.352] (II) SAVAGE(0): Not using default mode "720x450" (no mode of this name)
[ 25.352] (II) SAVAGE(0): Not using default mode "1600x1024" (width too large for virtual size)
[ 25.352] (--) SAVAGE(0): No suitable BIOS mode found for 800x512 60Hz.
[ 25.352] (II) SAVAGE(0): Not using default mode "800x512" (no mode of this name)
[ 25.352] (II) SAVAGE(0): Not using default mode "1680x1050" (width too large for virtual size)
[ 25.352] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 59Hz.
[ 25.352] (II) SAVAGE(0): Not using default mode "840x525" (no mode of this name)
[ 25.353] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 60Hz.
[ 25.353] (II) SAVAGE(0): Not using default mode "840x525" (no mode of this name)
[ 25.353] (II) SAVAGE(0): Not using default mode "1680x1050" (width too large for virtual size)
[ 25.353] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 69Hz.
[ 25.353] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 74Hz.
[ 25.353] (--) SAVAGE(0): No suitable BIOS mode found for 840x525 85Hz.
[ 25.353] (II) SAVAGE(0): Not using default mode "1920x1080" (width too large for virtual size)
[ 25.353] (--) SAVAGE(0): No suitable BIOS mode found for 960x540 59Hz.
[ 25.353] (II) SAVAGE(0): Not using default mode "960x540" (no mode of this name)
[ 25.353] (II) SAVAGE(0): Not using default mode "1920x1200" (width too large for virtual size)
[ 25.353] (--) SAVAGE(0): No suitable BIOS mode found for 960x600 59Hz.
[ 25.353] (II) SAVAGE(0): Not using default mode "960x600" (no mode of this name)
[ 25.353] (II) SAVAGE(0): Not using default mode "1920x1440" (width too large for virtual size)
[ 25.353] (--) SAVAGE(0): No suitable BIOS mode found for 960x720 85Hz.
[ 25.353] (II) SAVAGE(0): Not using default mode "960x720" (no mode of this name)
[ 25.353] (II) SAVAGE(0): Not using default mode "2048x1536" (width too large for virtual size)
[ 25.353] (--) SAVAGE(0): Chose mode 117 at 60Hz.
[ 25.353] (II) SAVAGE(0): Not using default mode "1024x768" (hsync out of range)
[ 25.353] (--) SAVAGE(0): Chose mode 117 at 75Hz.
[ 25.353] (--) SAVAGE(0): Chose mode 117 at 85Hz.
[ 25.354] (--) SAVAGE(0): Chose mode 117 at 100Hz.
[ 25.354] (II) SAVAGE(0): Not using driver mode "1024x768" (hsync out of range)
[ 25.354] (--) SAVAGE(0): Chose mode 114 at 60Hz.
[ 25.354] (--) SAVAGE(0): Chose mode 111 at 60Hz.
[ 25.354] (--) SAVAGE(0): Chose mode 143 at 72Hz.
[ 25.354] (--) SAVAGE(0): Chose mode 133 at 72Hz.
[ 25.354] (WW) SAVAGE(0): Shrinking virtual size estimate from 1024x768 to 800x600
[ 25.354] (--) SAVAGE(0): Virtual size is 800x600 (pitch 800)
