ich hab bei meinem Z61m langsam Speicherplatzenge und würd gern ne grössere Festplatte einbauen...
Auf der IBM Seite steht aber was von 100GB bei 7200 u/min Festplatten Begrenzung, ist das wahr?
ich würde gern eine "Seagate Momentus 7200.2 160GB SATA II it G-Force Protection" einbauen, hat da schon jemand Erfahrung ob die darin einwandfrei laufen würde? Die hat nämlich 7200 u/min...
* Standard 40GB, 60GB, 80GB, 100GB, or 120GB 5400 rpm hard drives
* 100GB 7200rpm hard drives on selected systems
* Supports one additional hard drive which can be used concurrently to offer expanded storage in the Ultrabay Slim
* Although you can upgrade the hard drive, it is not designed to be removed and reinserted on a regular basis. Repeated and frequent removal, for purposes other than to upgrade for greater capacity, can cause damage to the system. The Ultrabay Slim hard drive adapter is designed to provide this flexibility with a second hard drive in the Ultrabay Slim.
* The Hard Drive Active Protection system protects your hard drive when the shock sensor inside your ThinkPad computer detects a situation that could potentially damage the hard drive.
