Wine + Wimp
.Sun
29 Aug. 2010
Ich versuche jetzt seit 2 Stunden Wimp mittels Wine zu installieren. Die Installation stuckt aber immer nachdem ich "installieren" gedrückt habe.
AdobeAir läuft brav durch
[sun@t440s ~]$ env WINEPREFIX=$HOME/.wine/wimp wine Downloads/AdobeAIRInstaller.exe
wine: created the configuration directory '/home/sun/.wine/wimp'
fixme:ntdll:NtLockFile I/O completion on lock not implemented yet
err:mscoree:LoadLibraryShim error reading registry key for installroot
fixme:iphlpapi:NotifyAddrChange (Handle 0xeae338, overlapped 0xeae350): stub
fixme:iphlpapi:NotifyAddrChange (Handle 0xece880, overlapped 0xece88c): stub
wine: configuration in '/home/sun/.wine/wimp' has been updated.
fixme:console:AttachConsole stub ffffffff
fixme:sync:SetWaitableTimerEx (0xd8, 0x104e910, 0, (nil), (nil), (nil), 500) semi-stub
fixme:ole:RemUnknown_QueryInterface No interface for iid {00000019-0000-0000-c000-000000000046}
ALSA lib dlmisc.c:252:(snd1_dlobj_cache_get) Cannot open shared library /usr/lib32/alsa-lib/libasound_module_pcm_pulse.so
fixme:msi:ITERATE_DuplicateFiles We should track these duplicate files as well
fixme:imm:ImmReleaseContext (0x30050, 0x1fa1920): stub
[sun@t440s ~]$ fixme:sync:SetWaitableTimerEx (0xd8, 0x104e910, 0, (nil), (nil), (nil), 500) semi-stub
Dann kommt Wimp
[sun@t440s ~]$ env WINEPREFIX=$HOME/.wine/wimp wine Downloads/WiMP-3.2.0.1863-DE.exe
fixme:msi:MsiGetLastErrorRecord
fixme:advapi:LsaOpenPolicy ((null),0xa8e2d4,0x00000001,0xa8e2cc) stub
fixme:advapi:LsaClose (0xcafe) stub
fixme:shell:SHGetKnownFolderPath flags 0x00004400 not supported
fixme:advapi:LsaOpenPolicy ((null),0x4d9e2d4,0x00000001,0x4d9e2cc) stub
fixme:ntdll:server_ioctl_file Unsupported ioctl 110008 (device=11 access=0 func=2 method=0)
Mitlerweile bin ich ratlos. Kann ein Wineuser bitte mal testen, ob die Installation durchläuft?
[sun@t440s ~]$ wine --version
wine-1.7.26
What does not
The .exe installer does not work, workaround:
wine WiMP-3.1.0.1858-NO.exe /extract
wine msiexec /i 8840086/WiMP-3.1.0.1858-NO.msi
So lässt es sich installieren und starten.
Wen es interessiert: Nur mit Version 1.6.2 konnte ich mich bisher erfolgreich einloggen. Ein Soundtest steht noch aus.
