Edge E-Serie Which is better Thinkpad E560 or E570
samber86
8 Aug. 2017
Hello to all,
Can you please tell me which think pad is better to buy as per the performance either E560 or E70 Is better with both 1TB RAM
i am really confused which one to buy , if someone can explain me which one is better and why, it would be highly appreciable.
Thanks
Saurabh
I highly doubt you can buy any of these with 1TB of RAM :pinch:
Anyway, the E570 is simply the successor to the E560. It has the newer Kaby-lake processors and can be equipped with a much beefier GTX 950m GPU.
If you are buying new, there is hardly any reason to consider the older E560 unless you find a really cheap offer.
