W520 ESata Problem
Laberkopf
Very Active Member
12 Aug. 2011
Hallo allerseits,
neuerdings habe ich ja eine ESATA Festplatte am ESATA port des Docks hängen. Beim Neustart findet das System nur leider die Platte nicht wirklich.
Ich nutze Kernel 3.7.2
Hier der dmesg auszug:
[   81.945443] ata5: exception Emask 0x10 SAct 0x0 SErr 0x4000000 action 0xe frozen[   81.945448] ata5: irq_stat 0x00000040, connection status changed
[   81.945450] ata5: SError: { DevExch }
[   81.945456] ata5: hard resetting link
[   82.665411] ata5: SATA link down (SStatus 0 SControl 300)
[   82.681351] ata5: EH complete
[   83.098031] ata5: exception Emask 0x10 SAct 0x0 SErr 0x4000000 action 0xe frozen
[   83.098035] ata5: irq_stat 0x00000040, connection status changed
[   83.098037] ata5: SError: { DevExch }
[   83.098043] ata5: hard resetting link
[   84.107162] ata5: SATA link down (SStatus 0 SControl 300)
[   84.123090] ata5: EH complete
[   87.692347] ata5: exception Emask 0x10 SAct 0x0 SErr 0x4000000 action 0xe frozen
[   87.692352] ata5: irq_stat 0x00000040, connection status changed
[   87.692355] ata5: SError: { DevExch }
[   87.692363] ata5: limiting SATA link speed to 1.5 Gbps
[   87.692366] ata5: hard resetting link
[  245.453344] ata5: SATA link down (SStatus 1 SControl 310)
[  245.469375] ata5: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen t4
[  245.469395] ata5: irq_stat 0x00000040, connection status changed
[  245.469397] ata5: SError: { CommWake DevExch }
[  245.469403] ata5: limiting SATA link speed to 1.5 Gbps
[  245.469406] ata5: hard resetting link
[  247.693850] ata5: SATA link down (SStatus 1 SControl 310)
[  247.709795] ata5: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen t3
[  247.709800] ata5: irq_stat 0x00000040, connection status changed
[  247.709802] ata5: SError: { CommWake DevExch }
[  247.709808] ata5: limiting SATA link speed to 1.5 Gbps
[  247.709811] ata5: hard resetting link
[  249.934295] ata5: SATA link down (SStatus 1 SControl 310)
[  249.950270] ata5: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen t2
[  249.950275] ata5: irq_stat 0x00000040, connection status changed
[  249.950277] ata5: SError: { CommWake DevExch }
[  249.950283] ata5: limiting SATA link speed to 1.5 Gbps
[  249.950285] ata5: hard resetting link
[  252.174831] ata5: SATA link down (SStatus 1 SControl 310)
[  252.190772] ata5: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen t1
[  252.190783] ata5: irq_stat 0x00000040, connection status changed
[  252.190789] ata5: SError: { CommWake DevExch }
[  252.190802] ata5: limiting SATA link speed to 1.5 Gbps
[  252.190815] ata5: hard resetting link
[  254.798672] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  254.848355] ata5.00: failed to IDENTIFY (I/O error, err_mask=0x100)
[  259.790801] ata5: hard resetting link
[  260.110322] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  260.113772] ata5.00: failed to IDENTIFY (I/O error, err_mask=0x100)
[  265.102491] ata5: hard resetting link
[  265.422010] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  265.425724] ata5.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[  265.425744] ata5.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[  265.429429] ata5.00: ATA-8: WDC WD20EARS-00J2GB0, 80.00A80, max UDMA/133
[  265.429433] ata5.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[  265.429542] ata5.00: failed to get Identify Device Data, Emask 0x1
[  265.433252] ata5.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[  265.433263] ata5.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[  265.437060] ata5.00: failed to get Identify Device Data, Emask 0x1
[  265.437077] ata5.00: configured for UDMA/133
[  265.449946] ata5: EH pending after 5 tries, giving up
[  265.449970] ata5: EH complete
[  265.450060] scsi 4:0:0:0: Direct-Access     ATA      WDC WD20EARS-00J 80.0 PQ: 0 ANSI: 5
[  265.450292] sd 4:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[  265.450319] sd 4:0:0:0: Attached scsi generic sg2 type 0
[  265.450387] sd 4:0:0:0: [sdb] Write Protect is off
[  265.450391] sd 4:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[  265.450449] sd 4:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[  267.676285] ata5.00: exception Emask 0x10 SAct 0x1 SErr 0x40d0002 action 0xe frozen
[  267.676290] ata5.00: irq_stat 0x00400040, connection status changed
[  267.676292] ata5: SError: { RecovComm PHYRdyChg CommWake 10B8B DevExch }
[  267.676295] ata5.00: failed command: READ FPDMA QUEUED
[  267.676299] ata5.00: cmd 60/08:00:00:00:00/00:00:00:00:00/40 tag 0 ncq 4096 in
[  267.676299]          res 40/00:04:00:00:00/00:00:00:00:00/40 Emask 0x10 (ATA bus error)
[  267.676301] ata5.00: status: { DRDY }
[  267.676305] ata5: hard resetting link
[  273.429384] ata5: link is slow to respond, please be patient (ready=0)
[  274.659434] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[  274.665355] ata5.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[  274.665359] ata5.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[  274.671252] ata5.00: failed to get Identify Device Data, Emask 0x1
[  274.677009] ata5.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[  274.677019] ata5.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[  274.683365] ata5.00: failed to get Identify Device Data, Emask 0x1
[  274.683371] ata5.00: configured for UDMA/133
[  274.699418] sd 4:0:0:0: [sdb]
[  274.699422] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[  274.699423] sd 4:0:0:0: [sdb]
[  265.450466] ACPI: Invalid Power Resource to register!
[  274.699425] Sense Key : Aborted Command [current] [descriptor]
[  274.699427] Descriptor sense data with sense descriptors (in hex):
[  274.699429]         72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
[  274.699434]         00 00 00 00
[  274.699437] sd 4:0:0:0: [sdb]
[  274.699438] Add. Sense: No additional sense information
[  274.699440] sd 4:0:0:0: [sdb] CDB:
[  274.699441] Read(10): 28 00 00 00 00 00 00 00 08 00
[  274.699446] end_request: I/O error, dev sdb, sector 0
[  274.699450] Buffer I/O error on device sdb, logical block 0
[  274.699462] ata5: EH complete
[  274.705469] ldm_validate_partition_table(): Disk read failed.
[  274.705477]  sdb: unable to read partition table
[  274.705861] sd 4:0:0:0: [sdb] Attached SCSI disk
[ 2613.007645] ata1: hard resetting link
[ 2613.334940] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2613.335798] ata1.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 2613.335813] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2613.335816] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 2613.336307] ata1.00: failed to get Identify Device Data, Emask 0x1
[ 2613.336825] ata1.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 2613.336829] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2613.336831] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 2613.337308] ata1.00: failed to get Identify Device Data, Emask 0x1
[ 2613.337322] ata1.00: configured for UDMA/133
[ 2613.350955] ata1: EH complete
[ 2613.351037] ata2: hard resetting link
[ 2613.670267] ata2: SATA link down (SStatus 0 SControl 300)
[ 2613.686214] ata2: EH complete
[ 2613.686454] ata4: hard resetting link
[ 2614.005575] ata4: SATA link down (SStatus 0 SControl 300)
[ 2614.021519] ata4: EH complete
[ 2614.021608] ata5: hard resetting link
[ 2614.340873] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 2614.673525] ata5.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 2614.673537] ata5.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2614.677511] ata5.00: failed to get Identify Device Data, Emask 0x1
[ 2614.681380] ata5.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 2614.681392] ata5.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2614.685538] ata5.00: failed to get Identify Device Data, Emask 0x1
[ 2614.685555] ata5.00: configured for UDMA/133
[ 2614.700140] ata5: EH complete
[ 2708.752238] ata5: exception Emask 0x50 SAct 0x0 SErr 0x40d0802 action 0xe frozen
[ 2708.752243] ata5: irq_stat 0x00400040, connection status changed
[ 2708.752245] ata5: SError: { RecovComm HostInt PHYRdyChg CommWake 10B8B DevExch }
[ 2708.752250] ata5: hard resetting link
[ 2709.471587] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 2709.476029] ata5.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 2709.476041] ata5.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2709.480212] ata5.00: failed to get Identify Device Data, Emask 0x1
[ 2709.484007] ata5.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 2709.484019] ata5.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2709.487760] ata5.00: failed to get Identify Device Data, Emask 0x1
[ 2709.487776] ata5.00: configured for UDMA/133
[ 2709.503511] ata5: EH complete
[ 2723.051424] ata1: hard resetting link
[ 2723.378737] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2723.379571] ata1.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 2723.379583] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2723.379589] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 2723.380129] ata1.00: failed to get Identify Device Data, Emask 0x1
[ 2723.380793] ata1.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 2723.380804] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2723.380810] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 2723.381200] ata1.00: failed to get Identify Device Data, Emask 0x1
[ 2723.381211] ata1.00: configured for UDMA/133
[ 2723.394699] ata1: EH complete
[ 2723.394796] ata2: hard resetting link
[ 2723.722023] ata2: SATA link down (SStatus 0 SControl 300)
[ 2723.737973] ata2: EH complete
[ 2723.738163] ata4: hard resetting link
[ 2724.057336] ata4: SATA link down (SStatus 0 SControl 300)
[ 2724.073302] ata4: EH complete
[ 2724.073424] ata5: hard resetting link
[ 2724.392683] ata5: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 2724.397026] ata5.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 2724.397030] ata5.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2724.401901] ata5.00: failed to get Identify Device Data, Emask 0x1
[ 2724.406077] ata5.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 2724.406088] ata5.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2724.409891] ata5.00: failed to get Identify Device Data, Emask 0x1
[ 2724.409908] ata5.00: configured for UDMA/133
[ 2724.424517] ata5: EH complete
[ 2733.095763] ata5: exception Emask 0x50 SAct 0x0 SErr 0x4090800 action 0xe frozen
[ 2733.095768] ata5: irq_stat 0x00400040, connection status changed
[ 2733.095770] ata5: SError: { HostInt PHYRdyChg 10B8B DevExch }
[ 2733.095775] ata5: hard resetting link
[ 2733.206369] ata1: hard resetting link
[ 2733.533678] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2733.534536] ata1.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 2733.534540] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2733.534542] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 2733.535108] ata1.00: failed to get Identify Device Data, Emask 0x1
[ 2733.535687] ata1.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 2733.535697] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2733.535711] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
[ 2733.536144] ata1.00: failed to get Identify Device Data, Emask 0x1
[ 2733.536155] ata1.00: configured for UDMA/133
[ 2733.549652] ata1: EH complete
[ 2733.549727] ata2: hard resetting link
[ 2733.817025] ata5: SATA link down (SStatus 0 SControl 310)
[ 2738.806665] ata5: hard resetting link
[ 2738.806697] ata2: SATA link down (SStatus 0 SControl 300)
[ 2738.822693] ata2: EH complete
[ 2738.822920] ata4: hard resetting link
[ 2739.126016] ata5: SATA link down (SStatus 0 SControl 310)
[ 2744.115685] ata5: hard resetting link
[ 2744.115745] ata4: SATA link down (SStatus 0 SControl 300)
[ 2744.131632] ata4: EH complete
[ 2744.435005] ata5: SATA link down (SStatus 0 SControl 310)
[ 2744.435015] ata5.00: disabled
[ 2744.451045] ata5: EH complete
[ 2744.451185] ata5.00: detaching (SCSI 4:0:0:0)
[ 2744.451685] sd 4:0:0:0: [sdb] Synchronizing SCSI cache
[ 2744.451710] sd 4:0:0:0: [sdb]
[ 2744.451713] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 2744.451714] sd 4:0:0:0: [sdb] Stopping disk
[ 2744.451719] sd 4:0:0:0: [sdb] START_STOP FAILED
[ 2744.451721] sd 4:0:0:0: [sdb]
[ 2744.451722] Result: hostbyte=DID_BAD_TARGET driverbyte=DRIVER_OK
[ 2756.779969] ata5: exception Emask 0x10 SAct 0x0 SErr 0x4000000 action 0xe frozen
[ 2756.779974] ata5: irq_stat 0x00000040, connection status changed
[ 2756.779976] ata5: SError: { DevExch }
[ 2756.779982] ata5: hard resetting link
[ 2757.499950] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2757.503683] ata5.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 2757.503703] ata5.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2757.507783] ata5.00: ATA-8: WDC WD20EARS-00J2GB0, 80.00A80, max UDMA/133
[ 2757.507793] ata5.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 2757.507954] ata5.00: failed to get Identify Device Data, Emask 0x1
[ 2757.511799] ata5.00: ACPI cmd ef/02:00:00:00:00:a0 (SET FEATURES) succeeded
[ 2757.511811] ata5.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
[ 2757.515550] ata5.00: failed to get Identify Device Data, Emask 0x1
[ 2757.515567] ata5.00: configured for UDMA/133
[ 2757.527925] ata5: EH complete
[ 2757.528019] scsi 4:0:0:0: Direct-Access     ATA      WDC WD20EARS-00J 80.0 PQ: 0 ANSI: 5
[ 2757.528281] sd 4:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 2757.528283] sd 4:0:0:0: Attached scsi generic sg2 type 0
[ 2757.528368] sd 4:0:0:0: [sdb] Write Protect is off
[ 2757.528371] sd 4:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2757.528405] sd 4:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2757.941795]  sdb: sdb1
[ 2757.942496] sd 4:0:0:0: [sdb] Attached SCSI disk
[ 2771.815641] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null)
Der Log wurde gekürzt. War aber eh nur immer das gleiche resetting link.
(Zwischendurch habe ich versucht das system zum rescan der Sata Ports zu zwingen. Am ende half aber nur esata abziehen und esata wieder einstecken. :( )
Bekannte Problematik?
Laberkopf
Edit: Auch das aufwecken der Platte nachdem das W520 längere Zeit aus war dauert einige minuten. Kann darin leider kein Muster erkennen. Dmesg ist dann nur wieder mit resetting link vollgespammt.
