- 8 Dez. 2021
Umgebung: Windows 10 Pro 64-Bit, T440p, i7-4712MQ, Crucial MX500 2TB, komplette Festplattenverschlüsselung / Full Disk Encryption mit VeraCrypt 1.25.9
Manchmal lohnt es sich Release Notes zu lesen: Seit Version 1.25.7 kann durch bestimmte Registry-Keys bei VeraCrypt die Performance verbessert werden.
Ohne die Anpassung:
Mit der Anpassung:
100 MB/s mehr beim Lesen finde ich schon beachtlich. Leider habe ich keinen Vergleich zu einem unverschlüsselten Laufwerk.
Zu den Registry-Änderungen:
Ohne die Anpassung:
Mit der Anpassung:
Advanced users: Add registry settings to control driver internal encryption queue to allow tuning performance for SSD disks and having better stability under heavy load.
- Under registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\veracrypt:
- VeraCryptEncryptionFragmentSize (REG_DWORD): size of encryption data fragment in KiB. Default is 256. Maximum is 2048.
- VeraCryptEncryptionIoRequestCount (REG_DWORD): maximum number of parallel I/O requests. Default is 16. Maximum is 8192.
- VeraCryptEncryptionItemCount (REG_DWORD): maximum number of encryption queue items processed in parallel. Default as well as maximum is half of VeraCryptEncryptionIoRequestCount.
- The triplet (FragmentSize=512, IoRequestCount=128, ItemCount=64) is an example of parameters that enhance sequential read speed on some SSD NVMe systems.
VeraCrypt - Free Open source disk encryption with strong security for the Paranoid
VeraCrypt is free open-source disk encryption software for Windows, Mac OS X and Linux. In case an attacker forces you to reveal the password, VeraCrypt provides plausible deniability. In contrast to file encryption, data encryption performed by VeraCrypt is real-time (on-the-fly), automatic...
www.veracrypt.fr
