T5xx (T500-550 ohne "p") T520 - kein Wlan
paul_1234
Rather New Member
17 Feb. 2015
ich habe seit einigen Tagen ein T520 NW95HMB mit Debian Jessie. Jetzt stoße ich auf das Problem, das ich kein Wlan einrichten kann. Per network-manager kann ich zwar das LAN einrichten, aber die Wlaneinrichtung bleibt deaktiviert.
$ lspci
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200/2nd Generation Core Processor Family PCI Express Root Port (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:16.0 Communication controller: Intel Corporation 6 Series/C200 Series Chipset Family MEI Controller #1 (rev 04)
00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (rev 04)
00:1a.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 6 Series/C200 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 1 (rev b4)
00:1c.1 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 2 (rev b4)
00:1c.3 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 4 (rev b4)
00:1c.4 PCI bridge: Intel Corporation 6 Series/C200 Series Chipset Family PCI Express Root Port 5 (rev b4)
00:1d.0 USB controller: Intel Corporation 6 Series/C200 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation QM67 Express Chipset Family LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 6 Series/C200 Series Chipset Family 6 port SATA AHCI Controller (rev 04)
00:1f.3 SMBus: Intel Corporation 6 Series/C200 Series Chipset Family SMBus Controller (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation GF119M [Quadro NVS 4200M] (rev a1)
03:00.0 Network controller: Intel Corporation Centrino Ultimate-N 6300 (rev 3e)
0d:00.0 System peripheral: Ricoh Co Ltd PCIe SDXC/MMC Host Controller (rev 08)
0d:00.3 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 PCIe IEEE 1394 Controller (rev 04)
hat jemand ne Idee außer aufschrauben u. nachsehen?
Ist WLAN im UEFI unter Security - I/O Port Access "enabled?
Im UEFI gibt es vielleicht auch noch einen Punkt "Config", bei dem ebenfalls enabled stehen muss.
Ansonsten bliebe nur noch der Schiebeschalter am Notebookgehäuse, würde auch mal ein anderes Linux (Knoppix) ausprobieren. Wenns dann nicht geht, ist vielleicht die Karte defekt...
EDIT: Firmware könnte auch sein, habe bisher meist Ubuntu und kein "reines" Debian benutzt...
mfg
Hi!
Firmware iwlwifi installiert?
Besser den Thread mal nach Linux verschieben.
Gruß roeles
Wird vermutlich die Firmware sein .. im lspci wird die Karte ja erkannt:
Da die Firmware closed-source ist ist sie bei einigen Distritubionen nicht von Haus aus dabei.
Zusätzlich könntest du mal ein:
ifconfig -a
iwconfig
zeigen fals die Firmware nicht reicht.
# ifconfig -a
lo Link encap:Lokale Schleife
inet Adresse:127.0.0.1 Maske:255.0.0.0
inet6-Adresse: ::1/128 Gültigkeitsbereich:Maschine
UP LOOPBACK RUNNING MTU:65536 Metrik:1
RX packets:35 errors:0 dropped:0 overruns:0 frame:0
TX packets:35 errors:0 dropped:0 overruns:0 carrier:0
Kollisionen:0 Sendewarteschlangenlänge:0
RX bytes:6332 (6.1 KiB) TX bytes:6332 (6.1 KiB)
wlan0 Link encap:Ethernet Hardware Adresse 24:77:03:7f:d0:5c
UP BROADCAST MULTICAST MTU:1500 Metrik:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
Kollisionen:0 Sendewarteschlangenlänge:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wwan0 Link encap:Ethernet Hardware Adresse 02:80:37:ec:02:00
# iwconfig
eth0 no wireless extensions.
wlan0 IEEE 802.11abgn ESSID: off/any
Mode:Managed Access Point: Not-Associated Tx-Power=off
Retry short limit:7 RTS thr: off Fragment thr: off
Encryption key: off
Power Management: off
wwan0 no wireless extensions.
lo no wireless extensions.
Hast du mal ein anderes Linux (ubuntu oder so) als Live-System getestet?
Nur um einen Defekt an der Karte oder am Hardwareschalter auszuschließen.
so, jetzt läuft die Sache: Einstellg mittels wicd (NWM ist Mist, habe ich deinstalliert): WPA 1/2 mit Passphrase u. es klappt
