Follow along with the video below to see how to install our site as a web app on your home screen.
Anmerkung: This feature may not be available in some browsers.
quelle :http://psref.lenovo.com/syspool/Sys...470/ThinkPad_T470_Platform_Specifications.pdfStorageSystem has one HDD slot or one M.2 2280 slot exclusively for storageSome: HDD / SATA 6.0Gb/s, 2.5" wide, 7mm high, Active Protection SystemSome: SSD / SATA 6.0Gb/s, 2.5" wide, 7mm high (e.g. xxxGB SSD)Some: M.2 SSD / PCIe NVMe, PCIe 3.0 x 2, 16Gb/sSome: 128GB M.2 SSD / SATA 6.0Gb/s, in WWAN slot as 2nd Storage, mutually exclusive with WWAN and WiGigNoneEthernet Non-vPro model: Intel Ethernet Connection I219-V (Jacksonville)vPro model: Intel Ethernet Connection I219-LM (Jacksonville)WLAN BluetoothWWANSIM card (optional) (opt)One of the following, configurable by model (WiGig can coexist with WWAN):• Realtek RTL8822BE, Wi-Fi 2x2 802.11ac + BT4.1, M.2 card• Intel Dual Band Wireless-AC 8260, Wi-Fi 2x2 802.11ac + BT4.1, M.2 card• Intel Dual Band Wireless-AC 8265, Wi-Fi 2x2 802.11ac + BT4.1, M.2 card• Intel Tri-Band Wireless-AC 18265, WiGig 802.11ad + Wi-Fi 2x2 802.11ac + BT4.1, M.2 cardBluetooth 4.1 wireless, integrated in Wi-Fi + Bluetooth combo adapter* Intel 8265ac / 18265ac card support BT4.2 but is limited to BT4.1 by Windows OSOne of the following, configurable by model (WWAN can coexist with WiGig):• Wireless WAN upgradable• Integrated Mobile Broadband 4G LTE-A, Qualcomm Snapdragon™ X7 LTE-A (Sierra Wireless EM7455), M.2 card• Integrated Mobile Broadband 4G LTE, Intel XMM 7160 (Fibocom L831-EAU), M.2 card (EMEA only)Micro-SIM card slot, opt Verizon LTE (US) or Lenovo Connect (EMEA) SIM card
Beim T460p gibt es gar keine 2280er Anschlüsse
was du willst geht nicht !Und was genau sagt mir das jetzt?
Wie heißt deine Teamgroup M2 SSD im Detail? (Z.B. TeamGroup M.2 SSD Lite TM8PS5 256GB, M.2 (TM8PS5256GMC101))
Deswegen wüsste ich gerne, ob man das Bios einfach downgraden kann.
Es gibt M.2 PCIe und M.2 Sata SSDs. Mechanisch identisch, elektrisch inkompatibel.
Du hast eine M.2 Sata, brauchst aber eine M.2 PCIe SSD würd' ich mal so tippen...
wie so bist du so beratungs resstistent .Wie kommst du darauf?
quelle : https://de.wikipedia.org/wiki/M.2Der M.2-Standard beschreibt Varianten mit bis zu vier PCI-Express-Lanes, einem SATA Revision 3.x (6 Gbit/s) und/oder einem USB 3.0 Port – alles über einen Anschluss. Damit kann man sowohl PCI-Express als auch SATA-Speicher per M.2 anschließen. An jedem Port können beide Bussysteme auch parallel genutzt werden.
