T42: Upgrade von Ubuntu 10.04 auf Ubuntu 10.10 = kein WLAN (Atheros AR5212)
raymond
New Member
11 Dez. 2007
Seit dem upgrade von 10.04 auf 10.10 läuft kein WLAN auf dem Thinkpad T42 (2374-6G5):
raymond@notebook-raymond:~$ lspci
00:00.0 Host bridge: Intel Corporation 82855PM Processor to I/O Controller (rev 03)
00:01.0 PCI bridge: Intel Corporation 82855PM Processor to AGP Controller (rev 03)
00:1d.0 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #1 (rev 01)
00:1d.1 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #2 (rev 01)
00:1d.2 USB Controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) USB UHCI Controller #3 (rev 01)
00:1d.7 USB Controller: Intel Corporation 82801DB/DBM (ICH4/ICH4-M) USB2 EHCI Controller (rev 01)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev 81)
00:1f.0 ISA bridge: Intel Corporation 82801DBM (ICH4-M) LPC Interface Bridge (rev 01)
00:1f.1 IDE interface: Intel Corporation 82801DBM (ICH4-M) IDE Controller (rev 01)
00:1f.3 SMBus: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) SMBus Controller (rev 01)
00:1f.5 Multimedia audio controller: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Audio Controller (rev 01)
00:1f.6 Modem: Intel Corporation 82801DB/DBL/DBM (ICH4/ICH4-L/ICH4-M) AC'97 Modem Controller (rev 01)
01:00.0 VGA compatible controller: ATI Technologies Inc RV350 [Mobility Radeon 9600 M10]
02:00.0 CardBus bridge: Texas Instruments PCI4520 PC card Cardbus Controller (rev 01)
02:00.1 CardBus bridge: Texas Instruments PCI4520 PC card Cardbus Controller (rev 01)
02:01.0 Ethernet controller: Intel Corporation 82540EP Gigabit Ethernet Controller (Mobile) (rev 03)
02:02.0 Ethernet controller: Atheros Communications Inc. AR5212 802.11abg NIC (rev 01)
raymond@notebook-raymond:/etc$ cat modules
# /etc/modules: kernel modules to load at boot time.
# This file contains the names of kernel modules that should be loaded
# at boot time, one per line. Lines beginning with "#" are ignored.
lp
ath5k
#ath_pci
raymond@notebook-raymond:/etc/modprobe.d$ cat blacklist-ath_pci.conf
# For some Atheros 5K RF MACs, the madwifi driver loads buts fails to
# correctly initialize the hardware, leaving it in a state from
# which ath5k cannot recover. To prevent this condition, stop
# madwifi from loading by default. Use Jockey to select one driver
# or the other. (Ubuntu: #315056, #323830)
blacklist ath5k
(auch auskommentiert bringt nix)
raymond@notebook-raymond:/etc/modprobe.d$ ifconfig wlan0
wlan0 Link encap:Ethernet  Hardware Adresse xx:xx:xx:xx:xx:xx
      UP BROADCAST MULTICAST  MTU:1500  Metrik:1
      RX packets:0 errors:0 dropped:0 overruns:0 frame:0
      TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
      Kollisionen:0 Sendewarteschlangenlänge:1000
      RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
raymond@notebook-raymond:/etc/modprobe.d$ lsmod |grep ath
ath5k             	130051  0
mac80211          	231541  1 ath5k
ath                 	8153  1 ath5k
cfg80211          	144470  3 ath5k,mac80211,ath
led_class           	2633  2 thinkpad_acpi,ath5k
Mit 10.04 lief es zwar, die Verbindung ist zwar ständig auch abgebrochen, aber es lief wenigstens so halb.
Das kompilieren wollte ich eigentlich vermeiden, aber es klappt trotzdem nicht.
Bei ifconfig gibts nun ath0 und wifi0, bei lshw -c network wird ath_pci als geladener Treiber angezeigt.
dhclient gibt aus:
wifi0: unknown hardware address type 801
und ath0 bekommt halt keine IP.
Was mich halt auch wundert ist, dass oben das Netzwerk-Management-Applet ein Ausrufezeichen anzeigt und beim darübergehen der Maus anzeigt: "Netzwerk deaktiviert", obwohl das Kupferinterface ja funktioniert (in /etc/network/interfaces sind eth0 und wlan0/ath0 nicht eingetragen).
PS: iwlist ath0 scanning listet jedoch bereits meinen WLAN-Router (WPA2 verschlüsselt) auf.
wenn Du mit der rechten Maustaste auf das Network Manager Applet klickst, ist dann der Haken bei "Enable Wireless" an?
Danke für die Antworten.
Ja natürlich habe ich wlan an. Ich verwende Ubuntu und das Notebook nicht erst seit heute.
Aber ich habe es anders gemacht: Ubuntu 10.10 frisch installiert und es funktioniert (bei der LiveCD war schon WLAN verfügbar) und zwar mit ath5k Treiber.
Zuerst hatte ich das Problem, dass nach der Frischinstallation und Verbinden mit dem WLAN + Starten des Firefox das Notebook gefreezed ist (Fehlermeldung: http://kb.mozillazine.org/Could_not_initialize_the_browser_security_component). Echt komischer bug. Auch mehrmaliges Neustarten führte zum freeze.
Ich habe dann das Firefox Profile im Homeverzeichnis gelöscht und nun klappt alles wunderbar. Die ständigen Updates von 7.04 (oder 7.10) auf 10.10 waren scheinbar doch irgendwann mal zuviel. Daheim läuft WLAN nun stabil, nun muss es nur noch auf der FH problemlos laufen. Vielleicht läuft die WLAN Verbindung dort auch nun längere Zeit stabil. Bin auch gleich auf ext4 umgestiegen.
Nachtrag: Ich wollte gerade VLC installieren (WLAN Verbindung bestand gerade nicht, VLC in synaptic gerade mal ausgewählt) und das Ubuntu 10.10 ist wieder abgeschmiert, sprich gefreezed. Das hatte ich mit 10.04 und früheren Versionen nie. Ist der Kernel 2.6.35 doch noch sehr instabil? Beim nächsten Neustart konnte ich es halb installieren (gefreezed bei vlc-plugin-pulse).
Nachtrag2: Ich habe nun Ubuntu 10.04.1 installiert und bisher keine Probleme. Es geht scheinbar bei Ubuntu wenig über LTS.
