Ich habe auch "nur" die Version 1.15 und irgendwie das Gefühl, dass zumindest 2 Deiner PCMCIA Karten schonmal in MEINEM Thinkpad liefen. Also so konkret wird dieser Fehler nicht an der BIOS Version liegen.
Was würde mir das neueste Bios an verbesserungen bringen?
Version 1.16 - 1AET60WW
* (New) Compatibility enhancement with SMBIOS access programs.
* (Fix) Fails to switch to WinOS2 full-screen in OS/2 Warp3.
* (New) Enhancement of the password security feature.
* (Fix) BIOS sometimes displays an error message after wakeup from hibernation if a USB memory key is used in Windows 98.
Version 1.17 - 1AET61WW
* (Fix) Some multifunction CardBus cards do not work after resume from standby mode on Windows XP.
* (Fix) Boot priority for the network boot does not become to the default setting, if an F9 key is pressed twice in BIOS Setup Utility.
* (Fix) Windows NT, 2000 nor XP won't start if a USB BIOS is set to disabled in BIOS Setup Utility.
Version 1.18 - 1AET62WW
Note: This BIOS version will only work with the Embedded Controller Program Version 1.06a (or higher).
* (Fix) (Windows XP and Windows 2000) The system may resume normal operation from standby mode when the LCD panel is opened even though "Do nothing" for "When I close the lid of my portable computer" is selected in the Power Options.
* (Fix) (Windows XP and Windows 2000) The system may hang when the LCD is closed while the system is entering standby mode, and "Hibernation" for "When I close the lid of my portable computer" is selected in the Power Options.
* (New) Enhancement of the battery control.
Version 1AET64WW (1.20)
* (New) WakeOnLAN function updated.
Also helfen wird es wohl eher nicht, aber so richtig schaden kann es auch nicht. Obwohl ich nach der Devise verfahre, niemals ein laufendes System zu ändern.
