- 1 Apr. 2010
ich sitze anscheinand grade vor einer Polydrive Schraube, wo muss ich da messen um die Größe zu ermitteln?
Instructables sagt dazu folgendes:
Wobei ich ein kleines Problemchen mit der Übersetzung habe:
Die Größe wird ermittelt am XYZ Durchmesser an den Sternenpunkten.
Sind die Sternenpunkte jetzt das was näher zur Mitte liegt oder das was weiter weg davon liegt? Und was ist "OD"?
Die entsprechende Grafik gibt es auch hier: http://www.instructables.com/id/Whe...hillips-Plus-So-Much-Mor/step90/Polydrivereg/
Quelle: http://www.instructables.com/id/Whe...hillips-Plus-So-Much-Mor/step90/Polydrivereg/Polydrive®, also known as Ribe CV", Ribe CS" or simply Ribe", is a fastener specification used primarily in the automotive industry, for example the VW engine head bolts. Ribe CV" for spline socket head screws are a registered TM of Richard Bergen GmbH Co.
A Polydrive® bit has 6 teeth at equal spacing and with flat tips to the teeth. Size is determined by OD diameter at the star points. Functionally, it is similar to Torx® and Bristol Spline drive, all of which are systems using internal bit-socket drivers along with specially-designed bolts, screws, and other fasteners. Its primary advantage over older fastener driver standards, such as the common Phillips® head (and its sibling Pozidriv®), is that it resists camout, and is thus used in higher torque applications such as brakes and drive-shafts.
