smartctl 5.41 2011-06-09 r3365 [i686-linux-3.2.0-24-generic] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Model Family: Hitachi Travelstar 5K100
Device Model: HTS541060G9AT00
Serial Number: MPB3LAX5HPMSWM
Firmware Version: MB3IA60A
User Capacity: 60,011,642,880 bytes [60.0 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 6
ATA Standard is: ATA/ATAPI-6 T13 1410D revision 3a
Local Time is: Sat Jun 2 15:40:43 2012 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 645) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
No General Purpose Logging support.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 42) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 062 Pre-fail Always - 65536
2 Throughput_Performance 0x0005 105 105 040 Pre-fail Offline - 4571
3 Spin_Up_Time 0x0007 202 202 033 Pre-fail Always - 1
4 Start_Stop_Count 0x0012 098 098 000 Old_age Always - 3698
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 128 128 040 Pre-fail Offline - 36
9 Power_On_Hours 0x0012 083 083 000 Old_age Always - 7777
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 2721
191 G-Sense_Error_Rate 0x000a 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 3506045032
193 Load_Cycle_Count 0x0012 075 075 000 Old_age Always - 250303
194 Temperature_Celsius 0x0002 117 117 000 Old_age Always - 47 (Min/Max 9/56)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 23
SMART Error Log Version: 1
ATA Error Count: 5
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 5 occurred at disk power-on lifetime: 7775 hours (323 days + 23 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
84 51 00 0f 80 b9 e0 Error: ICRC, ABRT at LBA = 0x00b9800f = 12156943
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
c8 00 10 00 80 b9 e0 00 02:02:21.700 READ DMA
c8 00 00 b8 78 b9 e0 00 02:02:21.700 READ DMA
c8 00 80 38 78 b9 e0 00 02:02:21.700 READ DMA
c8 00 08 f8 77 b9 e0 00 02:02:21.700 READ DMA
c8 00 28 10 78 b9 e0 00 02:02:21.700 READ DMA
Error 4 occurred at disk power-on lifetime: 7775 hours (323 days + 23 hours)
84 51 00 ef 55 b9 e0 Error: ICRC, ABRT at LBA = 0x00b955ef = 12146159
c8 00 40 b0 55 b9 e0 00 02:02:21.400 READ DMA
c8 00 18 30 5a b9 e0 00 02:02:21.400 READ DMA
c8 00 00 b0 53 b9 e0 00 02:02:21.400 READ DMA
c8 00 18 f0 59 b9 e0 00 02:02:21.400 READ DMA
c8 00 00 b0 52 b9 e0 00 02:02:21.400 READ DMA
Error 3 occurred at disk power-on lifetime: 7664 hours (319 days + 8 hours)
When the command that caused the error occurred, the device was in standby mode.
10 51 00 ff 7c fc e6 Error: IDNF at LBA = 0x06fc7cff = 117210367
ca 00 80 80 7c fc e6 00 00:06:52.300 WRITE DMA
ca 00 80 00 7c fc e6 00 00:06:52.300 WRITE DMA
ca 00 80 80 7b fc e6 00 00:06:52.300 WRITE DMA
ca 00 80 00 7b fc e6 00 00:06:52.300 WRITE DMA
ca 00 80 80 7a fc e6 00 00:06:52.300 WRITE DMA
Error 2 occurred at disk power-on lifetime: 2898 hours (120 days + 18 hours)
ca d8 80 80 7c fc e6 00 03:40:57.200 WRITE DMA
ca d8 80 00 7c fc e6 00 03:40:57.200 WRITE DMA
ca d8 80 80 7b fc e6 00 03:40:57.200 WRITE DMA
ca d8 80 00 7b fc e6 00 03:40:57.200 WRITE DMA
ca d8 80 80 7a fc e6 00 03:40:57.200 WRITE DMA
Error 1 occurred at disk power-on lifetime: 130 hours (5 days + 10 hours)
ca 00 80 80 7c fc e6 00 00:12:49.100 WRITE DMA
ca 00 80 00 7c fc e6 00 00:12:49.100 WRITE DMA
ca 00 80 80 7b fc e6 00 00:12:49.100 WRITE DMA
ca 00 80 00 7b fc e6 00 00:12:49.100 WRITE DMA
ca 00 80 80 7a fc e6 00 00:12:49.100 WRITE DMA
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 7777 -
# 2 Extended offline Interrupted (host reset) 50% 7776 -
# 3 Short offline Completed without error 00% 7776 -
# 4 Extended offline Completed without error 00% 7603 -
# 5 Short offline Completed without error 00% 7 -
Warning! SMART Selective Self-Test Log Structure error: invalid SMART checksum.
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
