Produktankündigungen
Helios
Power User
23 Sep. 2009
Dieser Thread soll aktuelle Produktankündigungen darlegen.
Freecom announces three new solid state drives (SSDs) for those looking to take full advantage of the shock-resistance virtues that SSDs provide while benefiting from rugged data storage devices with high performance and sophisticated sleek design.
Freecom Launches Three New External SSDs
MSI Launches New mini-PC - Cubi
MSI proudly announces the latest and smallest mini-PC to date: the MSI Cubi. This tiny desktop is built on a concept of nifty technology and a brilliant design to suit the needs of both consumers and businesses.
Thanks to the implementation of a wide range of Intel processors, users can benefit from a powerful handheld-size PC, also capable of carrying multiple modular hard disks that provide a large base for data storage. MSI Cubi is mountable to a wall by VESA standards or can be combined with an HDTV, so the user can enjoy Ultra High-Definition and high quality media entertainment at home.
For commercial applications, Cubi also comes with Intel vPro technology, ensuring a safe and easily manageable working environment. With plenty of ports to connect to external devices, Cubi is the essence of small, smart computing. A black and a white version of the MSI Cubi are globally available by end of March 2015.
Small, Smaller, Smallest
Smaller than a lunchbox or an XL soda can, MSI Cubi is the smallest mini PC in its kind, with a 0.45 liter case that still provides all the elements of a desktop-worthy PC. With curved edges, a smooth surface, a subtle ventilation frame and conveniently positioned I/O ports, the MSI Cubi is not only the smallest, but also the smartest in its kind.
Latest Intel Broadwell Platform
MSI Cubi features Intel's latest Broadwell U 14nm processor family, with an overall power consumption of less than 15W, 30% less compared to the previous generation. The Intel integrated CPU with Intel HD Graphics provides for a great performance in multimedia applications.
High speed and big storage
Based on a modular design, the MSI Cubi offers the possibility to install an additional 2.5" HDD for a super high capacity data storage. Users can easily replace the bottom cover with an extended module, providing more space for those who desire bigger storage. With a built-in mSATA SSD hard drive and an extra 2.5" HDD, users can enjoy high-speed data processing and a big storage capacity at the same time.
Security and easy to management
With support for Intel vPro technology, Cubi provides plenty of security benefits. From remotely manageable features to starting and managing your system from a distance, Cubi is a reliable business partner.
UHD display & VESA mount support
MSI Cubi is not only a good business partner, but can also serve as an excellent HTPC with support for displaying Ultra High-Definition content, so the user can enjoy high quality media entertainment at home. With dual display support (via HDMI and mini Display Port) you can connect two monitors at the same time for an efficient day at the office. Last but not least, MSI Cubi is mountable to a wall or the rear side of a monitor by VESA standards to achieve the most efficient use of space.
Icy Dock Announces ExpressCage MB322SP-B
If you're seeking a compact rack with versatility and functionality, we have a convenient enclosure just for you. The ExpressCage MB322SP-B is a mobile rack that converts a 5.25" device bay to fit two 2.5" SATA/SAS HDD/SSD (7mm-9.5mm), and includes a 3.5" slot for either a hard drive or a 3.5" device. With the unique tool-less drive installation design, the ExpressTray Mini allows you to install your 2.5" SATA or SAS HDD/SSD simpler than ever, and the optional bottom tray screw holes are provided for added stability. The MB322SP-B has a detachable dust cover which keeps the front panel enclosed to block out dust particles when the 3.5" slot is left unused or when there's a 3.5" HDD installed. Soft blue LED indicator lights on each 2.5" drive bay notify you when drives are being used without being too distracting. For maximum durability we have implemented enhanced door latches and a solid metal housing.
Not your typical 5.25" mobile rack, the ExpressCage MB322SP-B *takes two 2.5" SATA/SAS HDD/SSD of 7mm to 9.5mm height and converts them into two hot-swap drive bays. It also includes 3.5" slot for a 3.5" device or 3.5" hard drive for various build options. With the extra slot, users can expand their storage by adding a 3.5" HDD or a ToughArmor MB992SK-B for two more 2.5" hot swap bays. The 3.5" slot is also compatible with an assortment of 3.5" form factor devices from USB 3.0 hubs to fan speed controllers. This versatility makes the MB322SP-B an essential tool for a wide range of power users and system builders looking to add variability to their computer build.
The magic of our ExpressTray Mini simplifies the drive installation process to provide a complete tool-less process to remove and install 2.5" SATA/SAS hard drives or SSDs. Attach a drive within seconds to the ExpressTray and remove it just as easily! Simply place the front end of the drive (the side without the connectors) down into the built in screws and ensure that end sits flush with the base of the tray. Now push the rear end (the side with the connectors) downwards onto the drive and ensure that there's no space between the drive and the tray. To remove the drive, you simply need to reverse the process. Pull on the rear tab of the tray to free up the drive and then remove the drive.
In addition, for applications that require extra stability we have provided the optional bottom tray screw holes so you can secure your drives.
The MB322SP-B's 3.5" slot for 3.5" HDDs or 3.5" devices comes with a detachable dust cover that not only protects your devices from dust and debris but also blends in with your system. So if you decide to leave the 3.5" slot empty or you have a 3.5" HDD for additional storage, the dust cover provides a visually flowing look while preventing dust from entering the system. The ExpressCage also comes with a metal cover finish for robustness and numerous ventilated slots for enhanced cooling. Each bay has its own indicator light to notify you of any hard drive activity. Soft-blue LED makes it easier to sense when drives are in use without straining your eyes.
Key Features:
  • Compatible with any standard 5.25" device bay
  • Fits 2x 2.5" SATA/SAS HDD/SSD and 1x 3.5" HDD/Device
  • Supports 2.5" SATA/SAS HDD/SSD of 7mm & 9.5mm height
  • Supports SATA 6Gbps or SAS single channel (requires SAS host)
  • Active Power Technology (APT) - only powers up if there is drive installed in the drive bay
  • Soft blue indicator LED provided for each 2.5" HDD/SSD bay
  • Detachable dust cover for 3.5" slot to keep debris from entering your system
  • Enhanced tray and metal housing with for maximum durability
  • ExpressTray Mini system for tool-less and easy 2.5" HDD/SSD installation
  • Numerous ventilated slots for enhanced cooling
  • Locking latch design for 7 pin SATA connectors
  • Compatible with our lineup of 3.5" mobile racks like the MB991SK-B and MB992SK-B
  • Designed for power users and system builder applications, mainly space saving and hot swap usage and for 2.5" HDD or SSD
HGST Helium-filled HDDs Achieve Field-tested 2.5 Million-hour MTBF
With more than one million helium-filled hard disk drives (HDDs) deployed, HGST, a Western Digital company today announced it has achieved a new milestone in reliability as the only manufacturer with drives field-proven and rated for two and a half (2.5) million hours mean time between failure (MTBF). Today's news demonstrates that HGST's helium HDDs are poised to become the mainstream choice for data center applications where storage density, reliability and power efficiency are paramount. Now shipping its second generation HelioSeal Platform drives, HGST is shifting its volume mix and ramping Helium production to meet strengthening customer demand across cloud and mainstream data center applications.
With strong market acceptance from the largest cloud service providers, Internet giants, OEMs and businesses around the world, including Netflix, Huawei, Inspur, HP, OVH, Starline, Buffalo, DataON, DDN and Racktop to name a few, the HGST HelioSeal Platform represents proven innovation in high-capacity HDD technology and reliability, while lowering true total cost of ownership (TCO). While there are a number of ways to increase hard drive capacity, HGST's HelioSeal platform is the only technology to provide unmatched reliability and a long-term path for delivering higher capacity storage on a standard 3.5-inch HDD form factor, while lowering power and drive temperature at the same time. All this equates to best storage density, TB-per-system weight, TB/Sq. foot and lowest watt/TB for enterprise and cloud data centers.
Since introducing the technology in 2013, HGST has been steadily increasing volume production to enable an expanding set of customers to enjoy the proven benefits of its Helium-filled technology. Now in its second generation, HGST's HelioSeal platform is gaining broader customer support and the company is increasing production of its Ultrastar He8, 8TB drives - the highest capacity available in the market that delivers full performance for all capacity-optimized applications. HGST's HelioSeal technology allows this to be accomplished at standard 7,200 RPM performance with low power while competitive air based products typically reduce RPM and performance to achieve lower power.
Both the Ultrastar He8 and the Ultrastar He6 families now feature an unprecedented reliability rating of 2.5M hours MTBF. Due to its patented manufacturing process and the inherent benefits of Helium, HGST's HelioSeal drives are field proven and have a more robust design margin than traditional air based drives. The HGST Helium drives are hermetically-sealed, which keep air, humidity and other contaminates out of the drive, allowing them to be used in harsh or ambient environments. The Helium inside the drives also reduces disk vibration and flutter, adding to even greater reliability.
HGST will continue to extend its capacity leadership by combining two complementary technologies: HelioSeal technology and Shingled Magnetic Recording (SMR) in its industry-leading 10TB helium-drives. The additive nature of these two technologies, combined with the economies of scale provided by increased Helium-drive manufacturing capacity, will further enhance HGST's TCO advantage. HGST expects that by 2017, 50 percent of its enterprise capacity drive shipments will be Helium.
"Based on the patented HelioSeal technology, HGST's Ultrastar Helium-filled drives are the only drives that improve data center TCO on virtually every level-from storage density, power and cooling costs, to reliability, capacity and more. We also believe it is the only way to get to higher densities therefore higher capacities while maintaining reliability. All of these factors contribute to defining the true TCO of the data center," said Brendan Collins, vice president of product marketing, HGST. "With more than one million drives deployed, the rapid industry adoption of this revolutionary technology affirms our commitment to Helium as the foundation for all future scaling technologies. With a valued-based pricing strategy in place and manufacturing investments to promote the increased volumes, HGST is on an accelerated path to delivering higher capacities and better TCO into existing and future form factor designs."
Driving Down Data Center TCO: The Value of HelioSeal Technology
With the amount of new data being created and replicated doubling every two years, data center architects have a lot to consider when planning for future growth. Capacity growth is only one piece of the equation. The additional power, cooling and floor space required to operate that extra storage is another, and can add up. Leveraging the inherent benefits of Helium, HGST's HelioSeal technology delivers today's lowest TCO for enterprise and cloud data centers through:
  • Greater power efficiency - Disks spin more easily in a helium-filled environment, resulting in 23% lower operating power. The 8TB helium drives consume just 5.1 watts during idle operation, a 44% reduction in watts-per-TB compared to conventional 6TB air-based HDDs, creating greener data centers with reduced energy costs and carbon footprint.
  • Leading storage density - Helium is essential to maintaining the required reliability for future generation drives beyond 8TB. Industry-leading 8TB capacity in a 3.5-inch HDD footprint, which are plug-and-play in virtually any data center environment, delivers 33% more storage capacity for mainstream applications than competitive 6TB offerings.
  • Lower cooling requirements - HGST Helium-filled drives typically run 4˚-5˚C cooler, which lowers power and cooling costs and leads to better field reliability, allowing HGST to increase its MTBF specification for the He6 and He8 drives.
  • Better weight-per-TB - Up to 38% lower weight-per-TB for improved environmental conditions in high-density deployments and allows for more storage capacity where building codes enforce floor loading limits.
  • Environmental robustness - Use them virtually anywhere, including ambient air, free cooling data centers. Many air-filled drives use a breather filter leading to reliability problems when used in environments with high levels of carbon or dust, or in high altitudes. This problem does not exist with HelioSeal drives as they're hermetically sealed.
  • Value $/TB - Higher volume production for its second-generation 8TB HelioSeal HDD leads to lower cost to the market.
HGST is shipping its 6TB Ultrastar He6 and 8TB Ultrastar He8 helium-filled drives in volume today. HGST's 10TB Helium HDDs with SMR are sampling with select customers.
OCZ Announces 2 TB (1920 GB) Variant of its Intrepid 3000 Enterprise SSD
OCZ Storage Solutions -- a Toshiba Group Company and leading provider of high-performance solid-state drives (SSDs) for computing devices and systems, today announced a new series of SATA III SSDs to add to its Intrepid 3000 enterprise portfolio. The new Intrepid 3700 SSD Series delivers superior performance and I/O latency responses that dramatically improve application performance and I/O efficiencies, and supports higher storage densities up to 2TB representing OCZ's largest capacity enterprise SATA SSDs to date.
"Datacenter customers have asked for larger solid state drives that do not make any sacrifices in performance or endurance to address the need to manage the ever growing amounts of data being generated by today's computing environments," said Daryl Lang, CTO at OCZ Storage Solutions. "Our new Intrepid 3700 Series is designed to meet these market requirements for an easy to deploy solid state solution that delivers the very best balance of features, endurance, and capacity."
The Intrepid 3700 Series is available in four models supporting 240GB, 480GB, 960GB and 1,920GB usable storage capacities and utilizes the latest Toshiba A19 nm NAND flash. Each model is driven by OCZ's Everest 2 controller platform which includes an optimized firmware architecture and advanced flash management that efficiently manages all housekeeping routines (such as garbage collection and wear-leveling) which enables the Intrepid 3700 Series SSDs to maintain performance over the long term.
In a steady state condition the Intrepid 3700 series delivers excellent performance for both large block sequential operations, as well as small block random operations. This includes up to 540 MB/s for sequential reads (128KB blocks), 470 MB/s for sequential writes (128KB blocks), 91,000 input/output operations per second (IOPS) for random reads (4KB blocks) and 13,000 IOPS for random writes (4KB blocks).
To round out its enterprise-class feature-set, the new Intrepid 3700 Series includes an advanced suite of endurance and reliability tools designed to extend NAND flash memory life and deliver those capabilities required by today's datacenter managers. This includes:
  • Error correction coding (ECC) that effectively corrects errors while significantly reducing the uncorrectable bit error rate (UBER);
  • End-to-end data path protection that performs data integrity checks at every juncture where data is transmitted, received, processed and stored;
  • Power Loss Protection (PLP) that prevents data loss in the event of a power failure guaranteeing that the in-progress write operations complete and data is properly stored;
  • Internal SSD RAID that duplicates all data stored so if there are flash errors a back-up exists providing additional data safeguards.
The Intrepid 3700 Series supports the industry standard 2.5-inch form factor, utilizes premium NAND flash, and guarantees up to one complete DWPD for 5 years. It is ideally suited for such read-intensive applications as online archiving, media streaming, video on demand (VOD), virtual desktop infrastructure (VDI) and web browsing applications, to name a few.
All Intrepid 3700 Series models will be available through OCZ's global channel of authorized enterprise solution resellers.
For more information, visit the product page.
MSI Announces IPC Motherboard with Embedded Broadwell Processor
As industrial applications increasingly require higher processing performance now than ever before, MSI released MS-98G5 industrial mainboard with superior processing and graphic capability in response. MS-98G5 is a Mini-ITX board based on Intel 4th Gen QM87/HM86 architecture that come support with BGA-type Haswell/Broadwell Mobile Core i7/i5/i3/Celeron Processor, multiple displays, 1 PCIe(x16), 8 USB 2.0 & 4 USB 3.0 ports, 5 COM ports, SATA 3.0 connector, and 2 mini-PCIe slots. The flexible and rich design along with the auto-switch DC 12/19V power inputs bring system integrators more possibilities of display deployment, I/O connection, and extra expansion.
MS-98G5 is also featured with its multiple displays with HDMI, DP, DVI-I, and LVDS outputs and the HD Graphics. The brilliant display capability and the high-performance Intel 4th Gen kernel make it an ideal solution for various industrial applications, such as HMI control, ATM, Kiosk, intelligent transportation system, medical, networking, and many more automation fields.
Key Features:
  • BGA-type Haswell/Broadwell Mobile Core i7/i5/i3/Celeron Processor
  • 3 independent displays with HDMI, DP, DVI-I, and LVDS
  • Dual GbE LAN with iAMT (EIA+QM87)
  • 2 x DDR3L 1333/1600 MHz memory up to 16GB
  • 1 x PCIe(x16) with riser card extends to x8+x8 or x8+x4+x4
  • 8 x USB2.0; 4 x USB3.0; 5 x COM; SATA 3.0; 2 x mini-PCIe slots
  • Auto-switch DC power 12/19V
Kingston Releases 4th Generation High-Speed Media Reader; 64GB 600X CF Card
Kingston Digital, Inc., the Flash memory affiliate of Kingston Technology Company, Inc., the independent world leader in memory products, today announced its 4th generation HS4 All-In-One Media Reader. The multi-function reader improves upon the previous model as it reads all major card format types including the latest SD card speeds (UHS-I, UHS-II) and CF Type I and II (UDMA 0-7).
Users can easily back up and transfer music, photos, videos and other digital data with USB 3.0 high-speed performance. This allows users to save time transferring files as USB 3.0 allows up to 5Gb/s data transfer speed - almost 10x faster than USB 2.0. The portable, small form factor reader has a brushed nickel case and is backwards compatible with USB 2.0.
Kingston also announces a new 64GB capacity addition to its CompactFlash Ultimate 600x family. The 32GB and 64GB CF Ultimate 600x cards offer premium results with speeds up to 90MB/s read and write to support burst mode photography or HD video. The addition of MediaRECOVER software lets users recover deleted files and restore corrupt files, if needed.
"HS4 All-In-One Media Reader is a great device to quickly move data between multiple devices whether at home or on the road," said Jean Wong, Flash memory business manager, Kingston. "The higher-capacity CF Ultimate 600x lets avid photographers and videographers capture more content and when used with the reader, data transfer is simple and fast."
HS4 All-In-One Media Reader carries a two-year warranty while the CF Ultimate 600x has a lifetime warranty. Both products are backed by legendary Kingston reliability and free technical support.
S4 All-In-One Media Reader Features and Specifications:
  • Ultra-portable: small size makes it an easy and convenient travel accessory
  • Versatile: supports the major types of memory cards and the latest speed standards (UHS-I and UHS-II)
  • Fast: USB 3.0 performance for an efficient and effortless data transfer
  • Compliant: with USB 3.0 specifications, backwards compatible with USB 2.0
  • Guaranteed: two-year warranty, free technical support
  • Dimensions: 93.17mm x 52.68mm x 16mm
  • Speed Rating1: up to 5Gb/s data transfer speed
  • Operating Temperature: 32º to 140ºF / 0º to 60ºC
  • Storage Temperature: -4º to 185ºF / -20º to 85ºC
  • Supported card formats:
  • - Compact Flash: CF Type I & II (UDMA 0-7)
  • - Secure Digital: SD/SDHC UHS I-II/SDXC UHS I-II
  • - microSD: microSD/microSDHC UHS-I/microSDXC UHS-I
  • - Memory Stick3: Memory Stick PRO/Duo/PRO Duo/ PRO-HG Duo
  • Requirements: system with USB 3.0
  • Built-In LED Indicator
  • USB 3.0 Cable Included
FanlessTech - Akasa announces Plato
Akasa's latest Broadwell NUC chassis is exploring a whole new shape and design. The Plato is a much wider case with lateral cooling fins. We're not entirely sure how this works but internal pictures should surface soon.
✓ Compatible with all i3 and i5 Broadwell NUC motherboards
✓ 1 x 2.5" bay (up to 9.5mm high)
✓ 2 x front USB 3.0
✓ Front Audio in/out
✓ Infrared receiver
✓ Kensington lock
✓ VESA mountable
✓ 247 x 200 x 38.5mm
Source: Akasa
ZOTAC Clocks in New Mini-PCs with Latest CPU Technology
ZOTAC International, a global innovator and manufacturer of graphics card and mini-PCs, today brings greater efficiency in the same small package with the new M-series. Integrating the new Intel Broadwell processors into the latest models, the new ZBOX MI522 nano and ZBOX MI542 nano are leading the way to small, more power efficient mini-PCs.
"We are always forward looking and pleased to introduce the latest technology into our mini-PCs so our users can enjoy all the innovations that come with the times. By integrating the new Intel Broadwell CPUs into our new M-series, we are enabling users to get the best of both worlds in terms of speed and power efficiency," reveals Jacky Huang, Director of Product Management, ZOTAC International.
The first of the two new designations, the ZBOX MI522 nano is the easy choice to get into the new Broadwell architecture. Shrinking the transistors to a mere 14nm, more transistors can fit on a single chip, boosting both calculation and graphical performance over its predecessors. Planted with an Intel Core i3 processor, the nano unit only measures at 127mm x 127mm x 45mm (5in x 5in x 2in).
The ZBOX MI542 nano is a step up that is packed with more computing power with the same advanced Intel Broadwell family. With a pulsing Intel Core i5 at its foundation, the ZBOX MI542 benefits from an even faster clock speed featuring up to 2.7GHz. This powerful nano unit is available on the same petite casing with all the functions of a desktop, and is topped with a vast array of connectivity options and dual-channel memory.
Like most other ZOTAC mini-PCs, these two M-series models come with their own plus versions, offering 4GB DDR3 memory and 500GB storage for a complete hardware solution. Packed with 5 USB ports, dual gigabit LAN and 802.11ac Wi-Fi connectivity in a miniscule enclosure, the ZBOX MI522 and MI542 series can function as a personal PC, office PC, home theater PC, and much more.
It's time to get more with your PC experience with the new ZOTAC M-series.
Source: TechPowerUp - ZOTAC Clocks in New Mini-PCs with Latest CPU Technology
HDMI Forum, Inc. Releases HDMI 2.0a Specification
HDMI Forum, Inc., a non-profit, mutual benefit corporation, today announced the completion and release of Version 2.0a of the HDMI Specification. It is available to current HDMI 2.0 Adopters via the HDMI Adopter Extranet.
The specification has been updated to enable transmission of HDR formats, which provide enhanced picture quality by simultaneously enabling greater detail for both the dark and bright parts of an image. The HDR-related updates include references to CEA-861.3, CEA's recently published update of HDR Static Metadata Extensions.
"We recognized that HDR would be a critical feature as the industry evolves. Our support for HDR enables our 800+ HDMI 2.0 Adopters to develop market-leading products that include HDR and will maintain interoperability across the entire HDMI ecosystem," said Robert Blanchard, President of the HDMI Forum, Inc. "Along with the publication of the CEA extensions, the HDMI Forum continues to update the HDMI Specification and remain closely aligned with leading CE standards organizations."
"By adding HDR, the HDMI Specification continues its history of supporting the latest formats and technologies planned for Hollywood content," said Arnold Brown, Chairman of the HDMI Forum, Inc. Board of Directors.
For more information about HDMI technology, please visit this page.
Source: TechPowerUp - HDMI Forum, Inc. Releases HDMI 2.0a Specification
New Turtle Beach PC Gaming Peripherals Now Available
Turtle Beach Corporation announced today that its new lineup of PC gaming accessories, including gaming keyboards, mice and mousepads, is available at select North American retail outlets. Turtle Beach, the 40-year strong staple of the gaming industry best known for its amazing range of console and PC headsets, including the first fully wireless headsets for Xbox One, opens a new chapter with its entrance into the PC gaming accessories market with its first round of gaming keyboards, gaming mice and gaming mousepads, each with their own unique features that cater to an audience ranging from casual players to hardcore professional gamers.
In true Turtle Beach form, the company has created a variety of accessories from which gamers can choose to suit their desires and budgets, and each one is crafted with high-quality, durable construction and features, including Cherry switches and steel reinforced chassis for the keyboards, Avago sensors and Omron switches for the mice, and an assortment of different textured and sized mousepads.
Below is a brief breakdown of all Turtle Beach's new PC gaming accessories, and be sure to see full details here.
Keyboards:
  • IMPACT 700 Premium Mechanical Gaming Keyboard - Cherry MX Brown switches, adjustable illuminated keys, two USB 2.0 ports w/audio pass-through, pink/green audio/mic jacks, six-key rollover with full anti-ghosting, steel-reinforced chassis w/gunmetal keycap plates, extra gaming keycaps plus metal keycap puller, full-sized 104-key layout, PC/MAC compatible, USB plug-and-play compatible. MSRP: $199.95.
  • IMPACT 500 Mechanical Gaming Keyboard - Compact 87-key tenkeyless layout, Cherry MX Blue switches, six-key rollover with full anti-ghosting, steel-reinforced chassis w/black rubberized coating, detachable braided USB cable, PC/MAC compatible, USB plug-and-play compatible. MSRP: $129.95.
  • IMPACT 100 Gaming Keyboard - Emulated mechanical feel, full-size 104-key layout, steel-reinforced chassis w/enhanced matte PBD keycaps, 30-key rollover with full anti-ghosting, PC/MAC compatible, USB plug-and-play compatible. MSRP: $59.95.
Mice:
  • GRIP 500 Premium Laser Gaming Mouse - Ergonomic 7-button scroll-wheel mouse, Avago 9800 laser sensors, Omron switches, independently adjustable DPI settings (up to 8200 DPI), designed for PC gaming w/customization software included, up to 50 macros w/up to 100 commands each, 16.8 million color options for scroll wheel and varied illumination effects, five color coded profiles, non-slip soft-touch coating, 6-foot snag-free soft rubber USB cable. MSRP: $69.95.
  • GRIP 300 Optical Gaming Mouse - Affordable 5-button scroll-wheel mouse, Avago 3050 optical sensors, Omron switches, adjustable mouse speed settings from 500, 1000 and 1750 DPI and polling rates from 125, 500 and 1000Hz, red-illuminated scroll-wheel and Turtle Beach logo, non-slip soft-touch coating, PC/MAC compatible, USB plug-and-play compatible, 6-foot braided USB cable. MSRP: $39.95.
Mousepads:
  • DRIFT Fast Microfiber Mousepad - High-quality microfiber surface for fast/smooth mouse control, large surface area, 100% natural rubber anti-slip base, anti-fray edges, multiple sizes (Medium 270x220mm, Large 350x250mm, X-Large 450x350mm and Wide 900x300mm). MSRP: $14.95 - $34.95.
  • TRACTION Textured Control Surface Mousepad - High-quality textured weave surface for perfect balance of friction and maximum mouse control, large surface area, 100% natural rubber anti-slip base, anti-fray edges, multiple sizes (Medium 270x220mm, Large 350x250mm, X-Large 450x350mm and Wide 900x300mm). MSRP: $14.95 - $34.95.
Source: TechPowerUp - New Turtle Beach PC Gaming Peripherals Now Available
Intel Rolls Out Energy-efficient Core i3-4170T Dual-Core Processor
Intel topped off its value dual-core processor lineup with a new energy-efficient part, the Core i3-4170T. One of the last chips to be based on the 22 nm "Haswell" silicon, this chip offers two cores with HyperThreading enabling four logical CPUs, 3.20 GHz clock speeds, 3 MB, and a TDP of just 35W (standard i3-41xx series feature 54W TDP). The i3-4170T is priced roughly on par with the current series-leading chip, the i3-4160. A little later this month, Intel will unveil the i3-4170, which will be the fastest part in the series, featuring 3.70 GHz clock speeds.
Source: TechPowerUp - Intel Rolls Out Energy-efficient Core i3-4170T Dual-Core Processor
Samsung Now Producing Industry's First M.2 NVMe PCIe SSD for the PC Market
Samsung Electronics Co., Ltd., the world leader in advanced memory technology, announced today that it has started mass production of the industry's first NVMe PCIe solid state drive (SSD) which has an M.2 form factor for use in PCs and workstations. Samsung is also the first in the industry to announce that it has begun shipping NVMe SSDs to OEMs for the PC market. The new SM951-NVMe features the industry's most advanced performance figures, exceptionally low power use in standby mode and the most compact size of any NVMe SSD.
"Our new NVMe SSD will allow for faster, ultra-slim notebook PCs with extended battery use, while accelerating the adoption of NVMe SSDs within the consumer marketplace," said Jeeho Baek, Senior Vice President of Memory Marketing at Samsung Electronics. "Samsung will continue to stay a critical step ahead of others in the industry in introducing a diversity of next-generation SSDs, that contribute to an enhanced user experience through rapid popularization of ultra-fast, highly energy-efficient, compact SSDs."
Samsung has been offering an AHCI-based PCIe 3.0 version of its SM951 SSD since early January. Now, it has added an NVMe version to form an even stronger SSD portfolio. This follows a previous industry-first introduction of 2.5" NVMe SSDs for the server market in 2013.
The new NVMe-based SM951 SSD achieves sequential data read and write performance up to 2,260 megabytes per second (MB/s) and 1,600 MB/s, respectively, while using Samsung's leading-edge controller technology. These performance figures are the industry's most advanced, with speeds four and three times faster than those of a typical SATA-based M.2 SSD which usually moves data at up to 540 MB/s and 500 MB/s, respectively.
The drive attains its high-speeds by using four 8 gigabit-per-second (Gbps) lanes (PCIe Gen 3.0 x4) of simultaneous data flow. This allows for a data transfer rate of 32 Gbps and a maximum throughput of 4 GB/s, giving the new drive a huge advantage over SATA-based M.2 SSDs, which can only transfer data up to 600 MB/s.
When it comes to random read operations, the SM951-NVMe can process 300,000 IOPS (Input Output Per Second), which is more than twice as fast as the 130,000 IOPS rate of its AHCI-based equivalent and more than three times faster than the 97,000 IOPS of a SATA-based SSD.
Meeting all M.2 form factor requirements, the drive's thickness does not exceed 4 millimeters, (3.73 millimeters maximum, when equipping chips on both sides of the board). This is less than the thickness of two stacked nickels. The drive also weighs less than 7 grams, which is lighter than two nickels and only a tenth the weight of a 2.5" SSD. Capacities are 512 gigabyte (GB), 256 GB and 128 GB.
In addition, the SM951-NVMe has adopted the L1.2 low-power standby mode (which allows all high-speed circuits to be turned off when a PC is on sleeping mode or in hibernation), as defined by PCI-SIG, the PCIe standards body. By embracing the L1.2 level of standby operation, the SM951's power consumption is drastically reduced - to under 2mW, representing about a 97 percent decrease from the 50mW consumed using an L1 state, which is the most widely used low-power mode today.
In the future, Samsung plans to incorporate its next-generation 3D V-NAND technology into its NVMe SSD line-ups, which will enable even higher densities and performance. Samsung also will maintain a fast-to-market supply of advanced SSDs to meet increasing customer demand, as the company continues to lead the premium SSD market and aggressively innovates to expand the mainstream SSD segment.
Source: TechPowerUp - Samsung Now Producing Industry's First M.2 NVMe PCIe SSD for the PC Market
Patriot Announces Ignite Series M2 SATA Solid-State Drive
Patriot, a leading manufacturer of computer memory, USB/flash, SSDs and mobile accessories, today announced the launch of its new M.2 Ignite solid-state drive (SSD). Its compact form factor is optimal for use in portable devices such as ultrabooks, notebooks and ultra-compact PC's providing impeccable start up times, instant access to data and installed programs.
The Patriot Ignite M2's Next-Generation-Form-Factor (NGFF) case free design and small structure of 22 mm wide by 80 mm long (2280) packs a punch, testing in with sequential read and write speeds of up to 560/320 MB/s and 4KB random read and write speeds of up to 90/70K IOPs. It provides the ultimate upgrade solution for those with mobile computing devices looking to increase storage capacities.
"We are happy to announce the Ignite M2 addition to our family of SSD products," said Les Henry, VP of Engineering at Patriot. "With the Ignite M2, Patriot now offers a full range of SSDs, from 2.5" SATA 3, to mSATA and now M.2. The Ignite M2 drives are the perfect storage solution for those looking to build/upgrade their small form factor PCs."
Powered by the new Phison S10 controller the M2 Ignite connects via M.2 SATA 6Gb/s interface to deliver rock solid performance and supports Windows 7, 8, 8.1, Vista, and Linux. The Ignite M2 is backed by Patriot's award winning customer service and a three year warranty. To ensure the consistency and performance of the drive over its life time, it comes with advanced features such as end-to-end data protection (ETEP), advanced wear-leveling, advanced Garbage collection, smartECC and Smart Refresh. The Ignite M2 is compatible with most notebooks.
Specifications
  • 240 GB & 480 GB capacities
  • Phison S10 Controller
  • M.2 2280 Form Factor
  • SATA III 6Gb/s Interface
  • MLC NAND
  • Up to 560 MB/s Sequential Read Speed
  • Up to 320 MB/s Sequential Write Speed
Availability
The Ignite M2 SSD will be available at the beginning of May at select online and in-store retailers such as Fry's Electronics, Amazon and Newegg for a starting MSRP of $109.99 240 GB and $209.99 480 GB.
Source: TechPowerUp - Patriot Announces Ignite Series M2 SATA Solid-State Drive
DeepCool Launches GamerStorm TriStellar ITX Chassis
A week after its debut as part of CyberPowerPC's Trinity gaming desktop, DeepCool launched the GamerStorm TriStellar mini-ITX chassis, so PC enthusiasts can cram in whatever hardware they want. It may be designed for mini-ITX motherboards only, but this is not a lunchbox sized case you can tuck away behind your flatscreen. It measures 435 mm x 395 mm x 388 mm (WxDxH), and takes up the same volume inside a carton as a cubical ATX case of comparable dimensions would.
Its design involves three temperature-isolated chambers with a triangular projection, which converge at a central hub for cabling to route between them. The bottom-right chamber houses a standard-height mini-ITX motherboard tray with just enough clearance for a stock CPU cooler (up to 80 mm height), or an AIO liquid cooling block with a 120 mm radiator. The bottom-left chamber houses the standard ATX PSU bay, a slimline optical drive bay, and two 3.5-inch drive bays. The top chamber has three expansion slot covers, although there's just one PCI-Express gen 3.0 x16 riser. There's enough volume for a GeForce GTX TITAN-Z dual-GPU graphics card. This chamber offers another three 3.5-inch tray-type drive bays with hot-plugging back-planes and 2.5-inch support. DeepCool didn't disclose pricing.
Source: TechPowerUp - DeepCool Launches GamerStorm TriStellar ITX Chassis
Intel "Skylake" to be 6th Generation Core Series, First i7-6700K Benchmarks
Intel's next major CPU architecture, codenamed "Skylake," could be classified as the company's 6th generation Core processor family. It will succeed the brief stint Core "Broadwell" will have at the market, with no major chips for PC enthusiasts to look forward to. The Core i7-6700K appears to be the flagship product based on the Skylake-D silicon, succeeding the i7-4770K and i7-4790K. The Core i5-6600K will succeed the i5-4670K and i5-4690K.
The i7-6700K is a quad-core chip, with HyperThreading enabling 8 logical CPUs. Its nominal clock will be 4.00 GHz, with a rather shallow 4.20 GHz Turbo Boost frequency. It will feature an 8 MB L3 cache, and an integrated memory controller that supports both DDR4 and DDR3 memory types. This makes Skylake a transition point for the mainstream PC market to gradually upgrade to DDR4. You'll have some motherboards with DDR3 memory slots, some with DDR4 slots, and some with both kinds of slots. The resulting large uncore component, and perhaps a bigger integrated GPU, will result in quad-core Skylake parts having TDP rated as high as 95W, higher than current Haswell quad-core parts, with their 88W TDP.
Turkish tech publication PC FRM claims to have access to performance numbers of the i7-6700K and i5-6600K, which it probably sourced from engineering samples being circulated within the motherboard industry; compared to some popular current-generation chips from the segment. The i7-6700K, which features the same clocks as an i7-4790K, is 15 percent faster in most tests. Its performance is slotted somewhere between the i7-4970K and the six-core i7-5820K, in multi-threaded tests. In tests such as PC Mark, it outclasses every other chip in comparison, including the i7-5820K.
Source: TechPowerUp - Intel "Skylake" to be 6th Generation Core Series, First i7-6700K Benchmarks
Desktop OEMs Begin Listing "Broadwell" Chips, "Skylake" Arrives in Q3
Major pre-built desktop manufacturers began listing products driven by 5th generation Core "Broadwell" processors, which are having a brief stint at the markets before being replaced by 6th generation Core "Skylake" processors in Q3-2015. The 5th Generation Core family is led by two parts, the Core i5-5675C, and the Core i7-5775C, both of which come with unlocked base-clock multipliers, are based on Intel's new 14 nanometer silicon fab process, and built in the LGA1150 package, compatible with existing Intel 9-series chipset based motherboards, with BIOS updates.
The Core i5-5675C and i7-5775C aren't exactly successors of the i5-4690K and i7-4790K. The i7-5775C is placed in a product tier Intel calls "P1+," while the i5-5675C is placed in one called "MS2+." The two aren't exactly in the same plane as P1K (eg: i7-4790K) or MS2K (eg: i5-4690K), respectively, and don't qualify as P1 (eg: i7-4790 non-K) or MS2 (eg: i5-4690 non-K). The two still feature unlocked multipliers. This places them somewhere between P1K/MS2K and P1/MS2. Both the i5-5675C and i7-5775C are quad-core chips, and physically feature just 6 MB of L3 cache. The i7-5775C has access to all 6 MB of it, while the i5-5675K features just 4 MB.
Since "Broadwell" is an optical shrink of "Haswell" to 14 nm (à la "Ivy Bridge" being a 22 nm shrink of the 32 nm "Sandy Bridge"), it pays heavy dividends with energy efficiency. The two chips offer rated TDP of just 65W. Perhaps the biggest change between Broadwell and Haswell is the presence of a 128 MB eDRAM L4 cache for the Iris Pro 6200 series integrated graphics to use as a really quick scratchpad. The iGPU uses both this 128 MB cache, and the system memory for graphics, juggling hot data into the cache, and keeping less frequently accessed data into the system memory. The Iris Pro 6200 features 48 execution units, and supports DirectX 11.2.
Intel's big graphics push is driven not by its ambitions to eat into big-ticket PC gaming, but by two market forces
  • The influx of high-resolution displays such as 4K (3840 x 2160 px) and 5K (5120 x 2880 px), which are being shrunk down in panel size and used to present high-DPI display-heads;
  • MOBA games such as "League of Legends," which is a rare combination of low system requirements and high popularity that can be monetized in gaming tournaments and streaming
The i7-5775C and i5-5675C will have only a brief stint at the markets, because the two will be succeeded by the 6th generation Core processor family, as early as Q3-2015 (July-September). Based on the 14 nm "Skylake" silicon, these chips will be built in the new LGA1151 package, and buying them will warrant a motherboard change to the new 10-series chipset. PC enthusiasts should look out for the Z170 Express chipset. Warranting the socket change this time around is a different pin-layout, because the integrated memory controller in "Skylake" will support both DDR3 and DDR4 memory types. You will be able to buy motherboards with DDR3 slots, those with DDR4 slots, and some handy odd-balls featuring both DDR3 and DDR4 memory slots (with the ability to use any one kind of slots at a time).
In addition to the Z170 Express chipset, PC enthusiasts should look out for two processors in particular - the Core i7-6700K and the Core i5-6600K. The two are the true successors to the i7-4790K and i5-4690K, occupying Intel's P1K and MS2K product tiers, respectively. The i7-6700K offers 4.00 GHz core clocks, with 4.20 GHz Turbo Boost, 8 MB of L3 cache, and HyperThreading. The i5-6600K, on the other hand, feature 3.60 GHz clocks, with 3.90 GHz Turbo Boost, 6 MB of L3 cache, but lacks HyperThreading. Both these chips feature TDP ratings of 95W.
Source: TechPowerUp - Desktop OEMs Begin Listing "Broadwell" Chips, "Skylake" Arrives in Q3
95W TDP of "Skylake" Chips Explained by Intel's Big Graphics Push
Intel's Core "Skylake" processor lineup, built on the company's swanky new 14 nanometer fab process, drew heads to its rather high 95W TDP for quad-core parts such as the Core i7-6700K and Core i5-6600K, even though their 22 nm predecessors, such as the i7-4770K and the i5-4670K run cooler, at 84W TDP. A new leaked slide explains the higher TDP. Apparently, Intel is going all-out with its integrated graphics implementation on Core "Skylake" chips, including onboard graphics that leverage eDRAM caches. The company is promising as much as 50% higher integrated graphics performance over "Haswell."
Although the chips have high rated TDP, the overall energy efficiency presents a different story. SoCs based on "Skylake" will draw as much as 60% lower power than "Haswell" based ones, translating into 35% longer HD video playback on portable devices running these chips. Intel's graphics performance push is driven by an almost sudden surge in display resolutions, with standards such as 4K (3840 x 2160) entering mainstream, and 5K (5120 x 2880) entering the enthusiast segment. Intel's design goal is to supply the market with a graphics solution that makes the two resolutions functional on desktop and video, if not gaming.
Source: TechPowerUp - 95W TDP of "Skylake" Chips Explained by Intel's Big Graphics Push
