X.Org X Server 1.13.0
Release Date: 2012-09-05
[ 3.299] X Protocol Version 11, Revision 0
[ 3.299] Build Operating System: Linux 2.6.42-37-generic x86_64 Ubuntu
[ 3.299] Current Operating System: Linux x220 3.5.0-27-generic #46~precise1-Ubuntu SMP Tue Mar 26 19:33:21 UTC 2013 x86_64
[ 3.299] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.5.0-27-generic root=UUID=bf08f9c5-06fa-4c27-b9e6-bc7202f33533 ro quiet splash vt.handoff=7
[ 3.299] Build Date: 11 April 2013 11:49:23PM
[ 3.299] xorg-server 2:1.13.0-0ubuntu6.1~precise3 (For technical support please see http://www.ubuntu.com/support)
[ 3.299] Current version of pixman: 0.24.4
[ 3.299] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 3.299] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 3.299] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 26 04:51:55 2013
[ 3.300] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3.300] (==) No Layout section. Using the first Screen section.
[ 3.300] (==) No screen section available. Using defaults.
[ 3.300] (**) |-->Screen "Default Screen Section" (0)
[ 3.300] (**) | |-->Monitor "<default monitor>"
[ 3.300] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 3.300] (==) Automatically adding devices
[ 3.300] (==) Automatically enabling devices
[ 3.300] (==) Automatically adding GPU devices
[ 3.300] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 3.300] Entry deleted from font path.
[ 3.300] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 3.300] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 3.300] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 3.300] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 3.300] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[ 3.300] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 3.300] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 3.300] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 3.300] (II) Loader magic: 0x7f0b997a0c20
[ 3.300] (II) Module ABI versions:
[ 3.300] X.Org ANSI C Emulation: 0.4
[ 3.300] X.Org Video Driver: 13.0
[ 3.300] X.Org XInput driver : 18.0
[ 3.300] X.Org Server Extension : 7.0
[ 3.301] (II) config/udev: Adding drm device (/dev/dri/card0)
[ 3.302] (--) PCI:*(0:0:2:0) 8086:0126:17aa:21da rev 9, Mem @ 0xf0000000/4194304, 0xe0000000/268435456, I/O @ 0x00005000/64
[ 3.303] (II) Open ACPI successful (/var/run/acpid.socket)
[ 3.303] Initializing built-in extension Generic Event Extension
[ 3.303] Initializing built-in extension SHAPE
[ 3.303] Initializing built-in extension MIT-SHM
[ 3.303] Initializing built-in extension XInputExtension
[ 3.303] Initializing built-in extension XTEST
[ 3.303] Initializing built-in extension BIG-REQUESTS
[ 3.303] Initializing built-in extension SYNC
[ 3.303] Initializing built-in extension XKEYBOARD
[ 3.303] Initializing built-in extension XC-MISC
[ 3.303] Initializing built-in extension SECURITY
[ 3.303] Initializing built-in extension XINERAMA
[ 3.303] Initializing built-in extension XFIXES
[ 3.303] Initializing built-in extension RENDER
[ 3.303] Initializing built-in extension RANDR
[ 3.303] Initializing built-in extension COMPOSITE
[ 3.303] Initializing built-in extension DAMAGE
[ 3.303] Initializing built-in extension MIT-SCREEN-SAVER
[ 3.303] Initializing built-in extension DOUBLE-BUFFER
[ 3.303] Initializing built-in extension RECORD
[ 3.303] Initializing built-in extension DPMS
[ 3.303] Initializing built-in extension X-Resource
[ 3.303] Initializing built-in extension XVideo
[ 3.303] Initializing built-in extension XVideo-MotionCompensation
[ 3.303] Initializing built-in extension XFree86-VidModeExtension
[ 3.303] Initializing built-in extension XFree86-DGA
[ 3.303] Initializing built-in extension XFree86-DRI
[ 3.303] Initializing built-in extension DRI2
[ 3.303] (II) LoadModule: "glx"
[ 3.304] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3.304] (II) Module glx: vendor="X.Org Foundation"
[ 3.304] compiled for 1.13.0, module version = 1.0.0
[ 3.304] ABI class: X.Org Server Extension, version 7.0
[ 3.304] (==) AIGLX enabled
[ 3.304] Loading extension GLX
[ 3.304] (==) Matched intel as autoconfigured driver 0
[ 3.304] (==) Matched intel as autoconfigured driver 1
[ 3.304] (==) Matched vesa as autoconfigured driver 2
[ 3.304] (==) Matched modesetting as autoconfigured driver 3
[ 3.304] (==) Matched fbdev as autoconfigured driver 4
[ 3.304] (==) Assigned the driver to the xf86ConfigLayout
[ 3.304] (II) LoadModule: "intel"
[ 3.304] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 3.306] (II) Module intel: vendor="X.Org Foundation"
[ 3.306] compiled for 1.13.0, module version = 2.20.9
[ 3.306] Module class: X.Org Video Driver
[ 3.306] ABI class: X.Org Video Driver, version 13.0
[ 3.306] (II) LoadModule: "vesa"
[ 3.306] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 3.306] (II) Module vesa: vendor="X.Org Foundation"
[ 3.306] compiled for 1.13.0, module version = 2.3.2
[ 3.306] (II) LoadModule: "modesetting"
[ 3.306] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 3.307] (II) Module modesetting: vendor="X.Org Foundation"
[ 3.307] compiled for 1.13.0, module version = 0.5.0
[ 3.307] Module class: X.Org Video Driver
[ 3.307] ABI class: X.Org Video Driver, version 13.0
[ 3.307] (II) LoadModule: "fbdev"
[ 3.307] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 3.307] (II) Module fbdev: vendor="X.Org Foundation"
[ 3.307] compiled for 1.13.0, module version = 0.4.3
[ 3.307] (II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM, Pineview G,
965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33, GM45,
4 Series, G45/G43, Q45/Q43, G41, B43, B43, Clarkdale, Arrandale,
Sandybridge Desktop (GT1), Sandybridge Desktop (GT2),
Sandybridge Desktop (GT2+), Sandybridge Mobile (GT1),
Sandybridge Mobile (GT2), Sandybridge Mobile (GT2+),
Sandybridge Server, Ivybridge Mobile (GT1), Ivybridge Mobile (GT2),
Ivybridge Desktop (GT1), Ivybridge Desktop (GT2), Ivybridge Server,
Ivybridge Server (GT2), Haswell Desktop (GT1), Haswell Desktop (GT2),
Haswell Desktop (GT2+), Haswell Mobile (GT1), Haswell Mobile (GT2),
Haswell Mobile (GT2+), Haswell Server (GT1), Haswell Server (GT2),
Haswell Server (GT2+), Haswell SDV Desktop (GT1),
Haswell SDV Desktop (GT2), Haswell SDV Desktop (GT2+),
Haswell SDV Mobile (GT1), Haswell SDV Mobile (GT2),
Haswell SDV Mobile (GT2+), Haswell SDV Server (GT1),
Haswell SDV Server (GT2), Haswell SDV Server (GT2+),
Haswell ULT Desktop (GT1), Haswell ULT Desktop (GT2),
Haswell ULT Desktop (GT2+), Haswell ULT Mobile (GT1),
Haswell ULT Mobile (GT2), Haswell ULT Mobile (GT2+),
Haswell ULT Server (GT1), Haswell ULT Server (GT2),
Haswell ULT Server (GT2+), Haswell CRW Desktop (GT1),
Haswell CRW Desktop (GT2), Haswell CRW Desktop (GT2+),
Haswell CRW Mobile (GT1), Haswell CRW Mobile (GT2),
Haswell CRW Mobile (GT2+), Haswell CRW Server (GT1),
Haswell CRW Server (GT2), Haswell CRW Server (GT2+),
ValleyView PO board
[ 3.308] (II) VESA: driver for VESA chipsets: vesa
[ 3.308] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3.308] (II) FBDEV: driver for framebuffer: fbdev
[ 3.308] (++) using VT number 7
[ 3.308] (II) intel(0): using device path '/dev/dri/card0'
[ 3.308] (WW) Falling back to old probe method for vesa
[ 3.308] (WW) Falling back to old probe method for modesetting
[ 3.308] (WW) Falling back to old probe method for fbdev
[ 3.308] (II) Loading sub module "fbdevhw"
[ 3.308] (II) LoadModule: "fbdevhw"
[ 3.308] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 3.308] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 3.308] compiled for 1.13.0, module version = 0.0.2
[ 3.308] ABI class: X.Org Video Driver, version 13.0
[ 3.308] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 3.308] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 3.308] (==) intel(0): RGB weight 888
[ 3.308] (==) intel(0): Default visual is TrueColor
[ 3.308] (--) intel(0): Integrated Graphics Chipset: Intel(R) Sandybridge Mobile (GT2+)
[ 3.308] (**) intel(0): Relaxed fencing enabled
[ 3.308] (**) intel(0): Wait on SwapBuffers? enabled
[ 3.308] (**) intel(0): Triple buffering? enabled
[ 3.308] (**) intel(0): Framebuffer tiled
[ 3.308] (**) intel(0): Pixmaps tiled
[ 3.308] (**) intel(0): 3D buffers tiled
[ 3.309] (**) intel(0): SwapBuffers wait enabled
[ 3.309] (==) intel(0): video overlay key set to 0x101fe
[ 3.309] (II) intel(0): Output LVDS1 has no monitor section
[ 3.309] (--) intel(0): found backlight control interface /sys/class/backlight/acpi_video0
[ 3.309] (II) intel(0): Output VGA1 has no monitor section
[ 3.340] (II) intel(0): Output HDMI1 has no monitor section
[ 3.388] (II) intel(0): Output DP1 has no monitor section
[ 3.404] (II) intel(0): Output HDMI2 has no monitor section
[ 3.420] (II) intel(0): Output HDMI3 has no monitor section
[ 3.468] (II) intel(0): Output DP2 has no monitor section
[ 3.516] (II) intel(0): Output DP3 has no monitor section
[ 3.516] (II) intel(0): EDID for output LVDS1
[ 3.516] (II) intel(0): Manufacturer: LGD Model: 2d3 Serial#: 0
[ 3.516] (II) intel(0): Year: 2011 Week: 0
[ 3.516] (II) intel(0): EDID Version: 1.3
[ 3.516] (II) intel(0): Digital Display Input
[ 3.516] (II) intel(0): Max Image Size [cm]: horiz.: 28 vert.: 16
[ 3.516] (II) intel(0): Gamma: 2.20
[ 3.516] (II) intel(0): DPMS capabilities: StandBy Suspend Off
[ 3.516] (II) intel(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 3.516] (II) intel(0): First detailed timing is preferred mode
[ 3.516] (II) intel(0): redX: 0.586 redY: 0.345 greenX: 0.340 greenY: 0.559
[ 3.516] (II) intel(0): blueX: 0.158 blueY: 0.127 whiteX: 0.313 whiteY: 0.329
[ 3.516] (II) intel(0): Manufacturer's mask: 0
[ 3.516] (II) intel(0): Supported detailed timing:
[ 3.516] (II) intel(0): clock: 74.8 MHz Image Size: 277 x 156 mm
[ 3.516] (II) intel(0): h_active: 1366 h_sync: 1414 h_sync_end 1446 h_blank_end 1578 h_border: 0
[ 3.516] (II) intel(0): v_active: 768 v_sync: 770 v_sync_end 775 v_blanking: 790 v_border: 0
[ 3.516] (II) intel(0): LG Display
[ 3.516] (II) intel(0): LP125WH2-TLB1
[ 3.516] (II) intel(0): EDID (in hex):
[ 3.516] (II) intel(0): 00ffffffffffff0030e4d30200000000
[ 3.516] (II) intel(0): 00150103801c1078ea10a59658578f28
[ 3.516] (II) intel(0): 20505400000001010101010101010101
[ 3.516] (II) intel(0): 010101010101381d56d4500016303020
[ 3.516] (II) intel(0): 2500159c1000001b0000000000000000
[ 3.516] (II) intel(0): 00000000000000000000000000fe004c
[ 3.516] (II) intel(0): 4720446973706c61790a2020000000fe
[ 3.516] (II) intel(0): 004c503132355748322d544c423100f7
[ 3.516] (II) intel(0): Not using default mode "320x240" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "400x300" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "512x384" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "640x480" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "640x512" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "800x600" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "896x672" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "928x696" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "960x720" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "576x432" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "680x384" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "700x525" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "720x450" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "800x512" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "840x525" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "960x540" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "960x600" (doublescan mode not supported)
[ 3.516] (II) intel(0): Not using default mode "1024x768" (doublescan mode not supported)
[ 3.516] (II) intel(0): Printing probed modes for output LVDS1
[ 3.516] (II) intel(0): Modeline "1366x768"x60.0 74.80 1366 1414 1446 1578 768 770 775 790 +hsync -vsync (47.4 kHz eP)
[ 3.516] (II) intel(0): Modeline "1360x768"x59.8 84.75 1360 1432 1568 1776 768 771 781 798 -hsync +vsync (47.7 kHz d)
[ 3.516] (II) intel(0): Modeline "1360x768"x60.0 72.00 1360 1408 1440 1520 768 771 781 790 +hsync -vsync (47.4 kHz d)
[ 3.516] (II) intel(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 3.516] (II) intel(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 3.516] (II) intel(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 3.516] (II) intel(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 3.516] (II) intel(0): EDID for output VGA1
[ 3.548] (II) intel(0): EDID for output HDMI1
[ 3.596] (II) intel(0): EDID for output DP1
[ 3.612] (II) intel(0): EDID for output HDMI2
[ 3.628] (II) intel(0): EDID for output HDMI3
[ 3.676] (II) intel(0): EDID for output DP2
[ 3.724] (II) intel(0): EDID for output DP3
[ 3.724] (II) intel(0): Output LVDS1 connected
[ 3.724] (II) intel(0): Output VGA1 disconnected
[ 3.724] (II) intel(0): Output HDMI1 disconnected
[ 3.724] (II) intel(0): Output DP1 disconnected
[ 3.724] (II) intel(0): Output HDMI2 disconnected
[ 3.724] (II) intel(0): Output HDMI3 disconnected
[ 3.724] (II) intel(0): Output DP2 disconnected
[ 3.724] (II) intel(0): Output DP3 disconnected
[ 3.724] (II) intel(0): Using exact sizes for initial modes
[ 3.724] (II) intel(0): Output LVDS1 using initial mode 1366x768
[ 3.724] (II) intel(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 3.724] (II) intel(0): Kernel page flipping support detected, enabling
[ 3.724] (==) intel(0): DPI set to (96, 96)
