B
Boxster
Guest
Version 7BETC4WW (2.06) (Really says 2.05 but still 7BETC4WW )
(New) Maximum Graphics Memory size increases to 224MB. (BIOS)
(Fix) If the computer is forcibly shut down by special conditions (such like the power button being pressed for seconds or the battery down in suspend mode), the computer may not work after power on. (BIOS)
(Fix) The computer may be shutdown by a certain 3G GPRS card in the PC card slot. (EC)
(Fix) Once Active Protection System is disabled, it cannot be enabled again until the system is restarted. (EC)
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-63144
vielleicht für den ein oder andern intressant!
