Neue Version von Lenovo Vantage: Commercial Vantage
ibmthink
Rather active member
30 Dez. 2010
Lenovo hat ja vor einiger Zeit die Support-Software Vantage neu gebaut, dabei aber den Ableger für große Firmenkunden (Lenovo Vantage for Enterprise) beim alten Design belassen.
Diese Version (Lenovo Vantage for Enterprise) wurde nun auf die End of Life Schiene geschoben und ist nicht mehr verfügbar. Als Ersatz gibt es Commercial Vantage, abrufbar auf Windows 10 per Sideloading oder über den Microsoft Store: https://www.microsoft.com/en-us/p/commercial-vantage/9nr5b8gvvm13?activetab=pivot:overviewtab
Vom Aufbau und der Nutzerführung her entspricht Commercial Vantage dem aktuellen regulären Vantage, aber ohne die ganzen unnötigen Aspekte mit reinem Fokus auf Updates, Einstellungen und Support. :thumbup:
Wie bekommt man die Software
ohne den MS Store?
Ist ein Microsoftkonto zwingend erforderlich?
Dazu folgendes: https://forums.lenovo.com/t5/Enterp...cial-Vantage-Battery-Gauge/m-p/5050952?page=2
Here is the deal with the Battery Gauge in Commercial Vantage. Officially, it is not supported and it's not supposed to be there. Battery Gauge is a feature of the normal Lenovo Vantage, not Commercial Vantage.
In a factory preload with Commercial Vantage, or if you used the enterprise package from the support website, there is the following registry entry:
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Lenovo\ImController]
"RequireAppAssociation"="1"
When this registry entry exists, and you have Commercial Vantage installed, the Battery Gauge will not be present.
However, if you installed Commercial Vantage from the store (e.g. not from a factory preload and not from the enterprise package on support website), then you won't have this registry entry, and the Battery Gauge will be available. However, in this case, the Battery Gauge will refer to "Lenovo Settings", and some things won't work, such as "Go to Lenovo Settings for Enterprise".
I understand that this is confusing and the current implementation is somewhat a mess.
the marketing rep in charge of Commercial Vantage says there is no demand for it. If we can get enough comments here I will definitely pass along the forum link. I'm especially interested in hearing from IT admins that want to deploy Commercial Vantage with a Battery Gauge on an entire fleet of ThinkPads...
@xsid,
um es aus dem Microsoft Store runterzuladen, ist kein Microsoft-Konto notwendig. Wenn man den Store aus Prinzip nicht will, kann man es per Sideloading von Lenovo direkt runterladen.
ohne den MS Store?
Be Lenovo der link ist auf der ersten Seite.
Oder aus dem MS Store (geht auch ohne Konto) - man muß das X drücken am Anmeldefenster ...
Ich weiß, habe aber einfach die Konfig-Datei mit einem Schreibschutz für den User SYSTEM versehen.
Nur die Endlos-Installationsschleife für die Ansicht der Akku-Informationen ko...t mich an. :cusing:
ohne den MS Store?
Das Wiki ist Dir immer noch nicht bekannt? :facepalm:
Wie kommen den eigentlich alle immer auf das schmale Brett mit dem Microsoft-Konto? - Kennt den keiner mehr das "X" in der linken oberen Ecke von Dialogen?
Im Wiki steht
(bis Okt. 2020 "Lenovo Vantage for Enterprise")
Wir haben Dezember, mit den vielen Versionen und Bezeichnungen und Wechselnamen bin ich überfordert.
Die Thread heißt:
Thema: Neue Version von Lenovo Vantage: Commercial Vantage
Commercial Vantage
Ok, scheint ja nicht zu funktionieren, ich beobachte weiter.
Jetzt vrstanden, es hat mich "(bis Okt. 2020 "Lenovo Vantage for Enterprise")" irritiert.
Im Lenovo-Forum (siehe Link oben) hat someotherguy eben darauf hingewiesen, dass End-User weiterhin Lenovo Vantage nutzen sollten.
Beide Versionen sind nicht für End-User gedacht - aber es hält dich natürlich niemand auf, sie zu nutzen.
https://www.microsoft.com/en-us/search/shop/apps?q=Lenovo
https://www.microsoft.com/en-us/search/shop/Apps?q=Lenovo+vantage
Wo, wie finde ich die Blau: Vantage Enterprise ?
In unserem Wiki finde ich dazu nichts.
Bei Lenovo:
https://pcsupport.lenovo.com/de/de/solutions/HF003321
Lenovo Vantage for Enterprise Version 20.1908.3.0, die zuvor auf dieser Seite verfügbar war, wurde zurückgezogen. Commercial Vantage Version 10.2010.11.0 ist der Ersatz ab dem 26. Oktober 2020.
Für mich ist das verwirrend und das trotz Wiki.
Die Kenner nehmen als die zurückgezogene "Lenovo Vantage for Enterprise", die soll blau sein?
Könnt Ihr bitte die kompletten Namen mit Release angeben.
MfG
xsid
So eine richtig klare Antwort war das nicht.
Was meinst Du da konkret?
Ich werde die Antwort dann hier mit Link zitieren.
