so, hier der log....
mir fällt auf, nach dem update KB2882822 gesucht wird, dies verursacht bei mir Probleme, daher habe ich das ausgeblendet...bei allen TP mit win 7 64 ultimate...
00:00.000: ====================================================================
00:00.171: Started: 2013/11/30 (Y/M/D) 17:17:43.435 (local)
00:00.280: Time Format in this log: MM:ss.mmm (minutes:seconds.milliseconds)
00:00.343: Command line: "C:\Windows\SoftwareDistribution\Download\Install\IE11-Windows6.1-x64-en-us.exe" /WSUS
00:00.374: INFO: Setup installer for Internet Explorer: 11.0.9600.16428
00:00.514: INFO: Previous version of Internet Explorer: 10.0.9200.16736
00:00.561: INFO: Checking if iexplore.exe's current version is between 11.0.9600.0...
00:01.185: INFO: ...and 11.1.0.0...
00:01.248: INFO: Maximum version on which to run IEAK branding is: 11.1.0.0...
00:01.294: INFO: iexplore.exe version check success. Install can proceed.
00:01.326: INFO: Operating System: Windows Workstation: 6.1.7601 (Service Pack 1)
00:01.357: INFO: Trying to extract ID: SetupDownloadList.txt (0) as "SetupDownloadList.txt"
00:01.404: INFO: Trying to extract ID: HardwareBlockingList.xml (0) as "HardwareBlockingList.xml"
00:01.450: INFO: Trying to extract ID: 7006 (0) as "IE11-neutral.Extracted.cab"
00:03.868: ERROR: Failed to extract a language pack for a non-english OS.
00:04.539: INFO: This is an English only package, so installation will continue on this non-English OS.
00:04.711: INFO: Trying to extract ID: 5501 (1033) as "Spelling_en.msu"
00:04.758: INFO: Extracted Spelling dictionary for en to C:\Windows\TEMP\IE1A4B6.tmp\Spelling_en.msu.
00:04.820: INFO: Trying to extract ID: 5502 (1033) as "Hyphenation_en.msu"
00:04.898: INFO: Extracted Hyphenation dictionary for en to C:\Windows\TEMP\IE1A4B6.tmp\Hyphenation_en.msu.
00:04.960: INFO: Trying to extract ID: 7128 (1031) as "IE11-support.cab"
00:05.038: ERROR: === FindResource (7128,"IE11-support.cab") failed with 0x717
00:05.101: INFO: Trying to extract ID: 7128 (1033) as "IE11-support.cab"
00:09.048: INFO: Launched program to check hardware: "C:\Windows\TEMP\IE1A4B6.tmp\IE11-SUPPORT\IEXPLORE.EXE" /CheckHardware "C:\Windows\TEMP\IE1A4B6.tmp\HardwareBlockingList.xml"
00:09.906: INFO: Graphics Device Information: Mobile Intel(R) 965 Express Chipset Family
00:09.937: INFO: Hardware support check succeeded. Installation will continue.
00:09.968: INFO: Windows 7 operating system detected.
00:10.015: INFO: Service pack major: 1
00:10.046: INFO: Service pack minor: 0
00:10.093: INFO: Service pack name: Service Pack 1
00:10.171: INFO: Version Check for (KB2834140) of C:\Windows\System32\d3d11.dll: 6.2.9200.16570 >= 6.2.9200.16570 (True)
00:10.374: INFO: Version Check for (KB2670838) of C:\Windows\System32\api-ms-win-downlevel-user32-l1-1-0.dll: 6.2.9200.16492 >= 6.2.9200.16426 (True)
00:10.639: INFO: Version Check for (KB2639308) of C:\Windows\System32\Ntoskrnl.exe: 6.1.7601.18113 >= 6.1.7601.17727 (True)
00:10.779: INFO: Version Check for (KB2533623) of C:\Windows\System32\api-ms-win-security-base-l1-1-0.dll: 6.1.7601.18015 >= 6.1.7601.17617 (True)
00:10.857: INFO: Version Check for (KB2731771) of C:\Windows\System32\conhost.exe: 6.1.7601.18015 >= 6.1.7601.17888 (True)
00:10.904: INFO: Checking for correct version of C:\Windows\Fonts\segoeui.ttf.
00:10.951: INFO: Version Check for (KB2786081) of C:\Windows\System32\taskhost.exe: 6.1.7601.18010 >= 6.1.7601.18010 (True)
00:11.044: INFO: Version Check for (KB2888049) of C:\Windows\System32\drivers\tcpip.sys: 6.1.7601.18254 >= 6.1.7601.18254 (True)
00:11.169: INFO: Version Check for (KB2882822) of C:\Windows\System32\tdh.dll: 6.1.7600.16385 >= 6.1.7601.18247 (False)
00:51.293: ERROR: WMI query for Hotfixes timed out. Query string: 'Select HotFixID from Win32_QuickFixEngineering WHERE HotFixID="KB2729094"' Error: 0x00040004 (262148).
00:51.355: INFO: KB2729094 could not be download is not installed.
00:51.589: INFO: Setup exit code: 0x00009C47 (40007) - Required updates failed to download.
00:52.369: INFO: Scheduling upload to IE SQM server:
http://sqm.microsoft.com/sqm/ie/sqmserver.dll
00:56.722: INFO: SQM Upload returned 403
00:59.233: INFO: Cleaning up temporary files in: C:\Windows\TEMP\IE1A4B6.tmp
00:59.405: INFO: Unable to remove directory C:\Windows\TEMP\IE1A4B6.tmp, marking for deletion on reboot.
00:59.498: INFO: Released Internet Explorer Installer Mutex
00:00.093: Started: 2013/11/30 (Y/M/D) 18:16:02.423 (local)
00:00.156: Time Format in this log: MM:ss.mmm (minutes:seconds.milliseconds)
00:00.187: Command line: "C:\Windows\SoftwareDistribution\Download\Install\IE11-Windows6.1-x64-en-us.exe" /WSUS
00:00.234: INFO: Setup installer for Internet Explorer: 11.0.9600.16428
00:00.280: INFO: Previous version of Internet Explorer: 10.0.9200.16736
00:00.296: INFO: Checking if iexplore.exe's current version is between 11.0.9600.0...
00:00.327: INFO: ...and 11.1.0.0...
00:00.358: INFO: Maximum version on which to run IEAK branding is: 11.1.0.0...
00:00.390: INFO: iexplore.exe version check success. Install can proceed.
00:00.421: INFO: Operating System: Windows Workstation: 6.1.7601 (Service Pack 1)
00:00.468: INFO: Trying to extract ID: SetupDownloadList.txt (0) as "SetupDownloadList.txt"
00:00.514: INFO: Trying to extract ID: HardwareBlockingList.xml (0) as "HardwareBlockingList.xml"
00:00.561: INFO: Trying to extract ID: 7006 (0) as "IE11-neutral.Extracted.cab"
00:02.121: ERROR: Failed to extract a language pack for a non-english OS.
00:02.152: INFO: This is an English only package, so installation will continue on this non-English OS.
00:02.168: INFO: Trying to extract ID: 5501 (1033) as "Spelling_en.msu"
00:02.230: INFO: Extracted Spelling dictionary for en to C:\Windows\TEMP\IE13F9F.tmp\Spelling_en.msu.
00:02.262: INFO: Trying to extract ID: 5502 (1033) as "Hyphenation_en.msu"
00:02.308: INFO: Extracted Hyphenation dictionary for en to C:\Windows\TEMP\IE13F9F.tmp\Hyphenation_en.msu.
00:02.433: INFO: Trying to extract ID: 7128 (1031) as "IE11-support.cab"
00:02.496: ERROR: === FindResource (7128,"IE11-support.cab") failed with 0x717
00:02.558: INFO: Trying to extract ID: 7128 (1033) as "IE11-support.cab"
00:06.427: INFO: Launched program to check hardware: "C:\Windows\TEMP\IE13F9F.tmp\IE11-SUPPORT\IEXPLORE.EXE" /CheckHardware "C:\Windows\TEMP\IE13F9F.tmp\HardwareBlockingList.xml"
00:07.238: INFO: Hardware support check succeeded. Installation will continue.
00:07.285: INFO: Windows 7 operating system detected.
00:07.300: INFO: Service pack major: 1
00:07.316: INFO: Service pack minor: 0
00:07.347: INFO: Service pack name: Service Pack 1
00:07.472: INFO: Version Check for (KB2834140) of C:\Windows\System32\d3d11.dll: 6.2.9200.16570 >= 6.2.9200.16570 (True)
00:07.503: INFO: Version Check for (KB2670838) of C:\Windows\System32\api-ms-win-downlevel-user32-l1-1-0.dll: 6.2.9200.16492 >= 6.2.9200.16426 (True)
00:07.519: INFO: Version Check for (KB2639308) of C:\Windows\System32\Ntoskrnl.exe: 6.1.7601.18113 >= 6.1.7601.17727 (True)
00:07.566: INFO: Version Check for (KB2533623) of C:\Windows\System32\api-ms-win-security-base-l1-1-0.dll: 6.1.7601.18015 >= 6.1.7601.17617 (True)
00:07.597: INFO: Version Check for (KB2731771) of C:\Windows\System32\conhost.exe: 6.1.7601.18015 >= 6.1.7601.17888 (True)
00:07.612: INFO: Checking for correct version of C:\Windows\Fonts\segoeui.ttf.
00:07.644: INFO: Version Check for (KB2786081) of C:\Windows\System32\taskhost.exe: 6.1.7601.18010 >= 6.1.7601.18010 (True)
00:07.722: INFO: Version Check for (KB2888049) of C:\Windows\System32\drivers\tcpip.sys: 6.1.7601.18254 >= 6.1.7601.18254 (True)
00:07.831: INFO: Version Check for (KB2882822) of C:\Windows\System32\tdh.dll: 6.1.7600.16385 >= 6.1.7601.18247 (False)
00:47.985: ERROR: WMI query for Hotfixes timed out. Query string: 'Select HotFixID from Win32_QuickFixEngineering WHERE HotFixID="KB2729094"' Error: 0x00040004 (262148).
00:48.032: INFO: KB2729094 could not be download is not installed.
00:48.204: INFO: Setup exit code: 0x00009C47 (40007) - Required updates failed to download.
00:48.422: INFO: Scheduling upload to IE SQM server:
00:53.508: ERROR: SQM Upload failed while uploading "C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\SQM\iesqmdata_setup0.sqm" with error: 2147500036
00:53.586: INFO: Cleaning up temporary files in: C:\Windows\TEMP\IE13F9F.tmp
00:53.882: INFO: Unable to remove directory C:\Windows\TEMP\IE13F9F.tmp, marking for deletion on reboot.
00:54.038: INFO: Released Internet Explorer Installer Mutex
00:00.234: Started: 2013/12/01 (Y/M/D) 17:18:54.412 (local)
00:00.327: Time Format in this log: MM:ss.mmm (minutes:seconds.milliseconds)
00:00.920: Command line: "C:\Windows\SoftwareDistribution\Download\Install\IE11-Windows6.1-x64-en-us.exe" /WSUS
00:00.967: INFO: Setup installer for Internet Explorer: 11.0.9600.16428
00:00.998: INFO: Previous version of Internet Explorer: 10.0.9200.16736
00:01.045: INFO: Checking if iexplore.exe's current version is between 11.0.9600.0...
00:01.107: INFO: ...and 11.1.0.0...
00:01.139: INFO: Maximum version on which to run IEAK branding is: 11.1.0.0...
00:01.170: INFO: iexplore.exe version check success. Install can proceed.
00:01.185: INFO: Operating System: Windows Workstation: 6.1.7601 (Service Pack 1)
00:01.217: INFO: Trying to extract ID: SetupDownloadList.txt (0) as "SetupDownloadList.txt"
00:01.263: INFO: Trying to extract ID: HardwareBlockingList.xml (0) as "HardwareBlockingList.xml"
00:01.310: INFO: Trying to extract ID: 7006 (0) as "IE11-neutral.Extracted.cab"
00:03.260: ERROR: Failed to extract a language pack for a non-english OS.
00:03.307: INFO: This is an English only package, so installation will continue on this non-English OS.
00:03.338: INFO: Trying to extract ID: 5501 (1033) as "Spelling_en.msu"
00:03.385: INFO: Extracted Spelling dictionary for en to C:\Windows\TEMP\IE15D27.tmp\Spelling_en.msu.
00:03.432: INFO: Trying to extract ID: 5502 (1033) as "Hyphenation_en.msu"
00:03.479: INFO: Extracted Hyphenation dictionary for en to C:\Windows\TEMP\IE15D27.tmp\Hyphenation_en.msu.
00:04.149: INFO: Trying to extract ID: 7128 (1031) as "IE11-support.cab"
00:04.212: ERROR: === FindResource (7128,"IE11-support.cab") failed with 0x717
00:04.243: INFO: Trying to extract ID: 7128 (1033) as "IE11-support.cab"
00:07.316: INFO: Launched program to check hardware: "C:\Windows\TEMP\IE15D27.tmp\IE11-SUPPORT\IEXPLORE.EXE" /CheckHardware "C:\Windows\TEMP\IE15D27.tmp\HardwareBlockingList.xml"
00:08.190: INFO: Hardware support check succeeded. Installation will continue.
00:08.580: INFO: Windows 7 operating system detected.
00:08.673: INFO: Service pack major: 1
00:08.751: INFO: Service pack minor: 0
00:08.845: INFO: Service pack name: Service Pack 1
00:08.923: INFO: Version Check for (KB2834140) of C:\Windows\System32\d3d11.dll: 6.2.9200.16570 >= 6.2.9200.16570 (True)
00:09.017: INFO: Version Check for (KB2670838) of C:\Windows\System32\api-ms-win-downlevel-user32-l1-1-0.dll: 6.2.9200.16492 >= 6.2.9200.16426 (True)
00:09.079: INFO: Version Check for (KB2639308) of C:\Windows\System32\Ntoskrnl.exe: 6.1.7601.18113 >= 6.1.7601.17727 (True)
00:09.126: INFO: Version Check for (KB2533623) of C:\Windows\System32\api-ms-win-security-base-l1-1-0.dll: 6.1.7601.18015 >= 6.1.7601.17617 (True)
00:11.887: INFO: Version Check for (KB2731771) of C:\Windows\System32\conhost.exe: 6.1.7601.18015 >= 6.1.7601.17888 (True)
00:12.012: INFO: Checking for correct version of C:\Windows\Fonts\segoeui.ttf.
00:12.137: INFO: Version Check for (KB2786081) of C:\Windows\System32\taskhost.exe: 6.1.7601.18010 >= 6.1.7601.18010 (True)
00:12.230: INFO: Version Check for (KB2888049) of C:\Windows\System32\drivers\tcpip.sys: 6.1.7601.18254 >= 6.1.7601.18254 (True)
00:12.355: INFO: Version Check for (KB2882822) of C:\Windows\System32\tdh.dll: 6.1.7600.16385 >= 6.1.7601.18247 (False)
00:52.478: ERROR: WMI query for Hotfixes timed out. Query string: 'Select HotFixID from Win32_QuickFixEngineering WHERE HotFixID="KB2729094"' Error: 0x00040004 (262148).
00:52.650: INFO: KB2729094 could not be download is not installed.
00:52.744: INFO: Setup exit code: 0x00009C47 (40007) - Required updates failed to download.
00:52.837: INFO: Scheduling upload to IE SQM server:
01:06.363: ERROR: SQM Upload failed while uploading "C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\SQM\iesqmdata_setup0.sqm" with error: 2147500036
01:06.456: ERROR: SQM Upload failed while uploading "C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\SQM\iesqmdata_setup1.sqm" with error: 2147500036
01:06.519: INFO: Cleaning up temporary files in: C:\Windows\TEMP\IE15D27.tmp
01:06.675: INFO: Unable to remove directory C:\Windows\TEMP\IE15D27.tmp, marking for deletion on reboot.
01:06.753: INFO: Released Internet Explorer Installer Mutex
