IBM x40 soll mit PCMCIA Card und UMTS eine Internetverbindung aufbauen
hko
8 Nov. 2008
mein x40 soll mit einer PCMCIA Card (Option Qualcomm 3G CDMA) eine Internetverbindung aufbauen.
Mein Provider ist T-Mobile.
Setze Ubuntu 8.10 ein.
Nachdem ich den Karte eingesteckt habe, folgende Systemmeldung:
[4773.688064] pccard: CardBus card inserted into slot 0
[ 4773.688131] PCI: 0000:03:00.0 reg 10 32bit mmio: [0, fff]
[ 4773.688204] pci 0000:03:00.0: supports D1
[ 4773.688210] pci 0000:03:00.0: supports D2
[ 4773.688217] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot
[ 4773.688229] pci 0000:03:00.0: PME# disabled
[ 4773.869484] ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4773.871468] ohci_hcd 0000:03:00.0: enabling device (0000 -> 0002)
[ 4773.871488] ohci_hcd 0000:03:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 4773.871524] ohci_hcd 0000:03:00.0: setting latency timer to 64
[ 4773.871529] ohci_hcd 0000:03:00.0: OHCI Host Controller
[ 4773.876318] ohci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 5
[ 4773.877747] ohci_hcd 0000:03:00.0: irq 16, io mem 0xd4000000
[ 4773.934484] usb usb5: configuration #1 chosen from 1 choice
[ 4773.935073] hub 5-0:1.0: USB hub found
[ 4773.935523] hub 5-0:1.0: 1 port detected
[ 4776.912050] usb 5-1: new full speed USB device using ohci_hcd and address 2
[ 4777.127915] usb 5-1: configuration #1 chosen from 1 choice
[ 4777.354488] usbcore: registered new interface driver usbserial
[ 4777.356456] usbserial: USB Serial support registered for generic
[ 4777.357724] usbcore: registered new interface driver usbserial_generic
[ 4777.357734] usbserial: USB Serial Driver core
[ 4777.381107] usbserial: USB Serial support registered for GSM modem (1-port)
[ 4777.382528] option 5-1:1.0: GSM modem (1-port) converter detected
[ 4777.384058] usb 5-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 4777.385438] usbcore: registered new interface driver option
[ 4777.385446] option: USB Driver for GSM modems: v0.7.2
[ 4777.414846] usbcore: registered new interface driver libusual
[ 4777.468677] hso: /build/buildd/linux-2.6.27/drivers/net/usb/hso.c: 1.2 Option Wireless
[ 4777.470576] usbcore: registered new interface driver hso
Ich habe umtsmon installiert. Nach Aufruf bekomme die Meldung,
"umtsmon detected that you need to switch your device.
Click Yes if you agree.
Note: this does not work properly for all devices yet!"
Nachdem ich auf Yes geklickt habe, kommt diese Meldung:
"No divece could be foun, the application will close.
If you need more info, please re-run form the command line."
Starte ich das Programm im Terminal, kommt noch diese Info:
" *** umtsmon version 0.9 closed due to an unrecoverable program error.
*** Please e-mail all of the above output to umtsmon-develop@lists.sourceforge.net,
*** Or go to the umtsmon website and file a bug."
Hoffe mir kann jemand einen Tipp geben.
Vielen Dank.
Gruss
hko
