Hattest Du auch die Schutzfolie entfernt, die "glossy" ist entfernt?ein mattes Display bestellt und geliefert wurde Glossy.
edid-decode /sys/class/drm/card0-eDP-1/edid
edid-decode (hex):
00 ff ff ff ff ff ff 00 06 af 8d 40 00 00 00 00
26 1d 01 04 a5 1f 11 78 03 9b 85 92 56 59 90 29
20 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 14 37 80 b8 70 38 24 40 10 10
3e 00 35 ae 10 00 00 18 00 00 00 0f 00 00 00 00
00 00 00 00 00 00 00 00 00 20 00 00 00 fe 00 41
55 4f 0a 20 20 20 20 20 20 20 20 20 00 00 00 fe
00 42 31 34 30 48 41 4e 30 34 2e 45 20 0a 00 1d
Block 0, Base EDID:
EDID Structure Version & Revision: 1.4
Vendor & Product Identification:
Manufacturer: AUO
Model: 16525
Made in: week 38 of 2019
Basic Display Parameters & Features:
Digital display
Bits per primary color channel: 8
DisplayPort interface
Maximum image size: 31 cm x 17 cm
Gamma: 2.20
Supported color formats: RGB 4:4:4
First detailed timing includes the native pixel format and preferred refresh rate
Display is continuous frequency
Color Characteristics:
Red : 0.5722, 0.3369
Green: 0.3496, 0.5654
Blue : 0.1621, 0.1250
White: 0.3134, 0.3291
Established Timings I & II: none
Standard Timings: none
Detailed Timing Descriptors:
DTD 1: 1920x1080 60.049 Hz 16:9 67.015 kHz 141.000 MHz (309 mm x 174 mm)
Hfront 16 Hsync 16 Hback 152 Hpol N
Vfront 3 Vsync 14 Vback 19 Vpol N
Manufacturer-Specified Display Descriptor (0x0f): 00 0f 00 00 00 00 00 00 00 00 00 00 00 00 00 20 '............... '
Alphanumeric Data String: 'AUO'
Alphanumeric Data String: 'B140HAN04.E '
Checksum: 0x1d
T440p | 14 | 1920 | 1080 | 157 PPI | |
Na, damit lass ich mein Feierabendbier schmecken, so schöne Informationen.Hattest Du auch die Schutzfolie entfernt, die "glossy" ist entfernt?
Jetzt verbautes €69,99 EUR Panel:
Code:edid-decode /sys/class/drm/card0-eDP-1/edid edid-decode (hex): 00 ff ff ff ff ff ff 00 06 af 8d 40 00 00 00 00 26 1d 01 04 a5 1f 11 78 03 9b 85 92 56 59 90 29 20 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 01 14 37 80 b8 70 38 24 40 10 10 3e 00 35 ae 10 00 00 18 00 00 00 0f 00 00 00 00 00 00 00 00 00 00 00 00 00 20 00 00 00 fe 00 41 55 4f 0a 20 20 20 20 20 20 20 20 20 00 00 00 fe 00 42 31 34 30 48 41 4e 30 34 2e 45 20 0a 00 1d ---------------- Block 0, Base EDID: EDID Structure Version & Revision: 1.4 Vendor & Product Identification: Manufacturer: AUO Model: 16525 Made in: week 38 of 2019 Basic Display Parameters & Features: Digital display Bits per primary color channel: 8 DisplayPort interface Maximum image size: 31 cm x 17 cm Gamma: 2.20 Supported color formats: RGB 4:4:4 First detailed timing includes the native pixel format and preferred refresh rate Display is continuous frequency Color Characteristics: Red : 0.5722, 0.3369 Green: 0.3496, 0.5654 Blue : 0.1621, 0.1250 White: 0.3134, 0.3291 Established Timings I & II: none Standard Timings: none Detailed Timing Descriptors: DTD 1: 1920x1080 60.049 Hz 16:9 67.015 kHz 141.000 MHz (309 mm x 174 mm) Hfront 16 Hsync 16 Hback 152 Hpol N Vfront 3 Vsync 14 Vback 19 Vpol N Manufacturer-Specified Display Descriptor (0x0f): 00 0f 00 00 00 00 00 00 00 00 00 00 00 00 00 20 '............... ' Alphanumeric Data String: 'AUO' Alphanumeric Data String: 'B140HAN04.E ' Checksum: 0x1d
logo!Hattest Du auch die Schutzfolie entfernt, die "glossy" ist entfernt?
