fwupd: Error System-Firmware (0.1.29 → 0.1.32) - T14s (AMD)
TPmicha
26 März 2016
mein System-Update schlägt fehl:
$ fwupdmgr refresh
Updating lvfs-testing
Herunterladen …          [***************************************]
Updating lvfs
Successfully downloaded new metadata: 3 local devices supported
$ fwupdmgr get-updates
Devices with no available firmware updates:
 • Integrated Camera
 • Samsung SSD 970 EVO Plus 2TB
 • UEFI Device Firmware
Devices with the latest available firmware version:
 • Prometheus
 • UEFI dbx
20UH001QGE
└─System Firmware:
  │   Device ID:          b4718caaf1dc79bb34f276c98081532f468822aa
  │   Current version:    0.1.29
  │   Vendor:             LENOVO (DMI:LENOVO)
  │   GUIDs:              428ba8ba-40c8-4446-8d7a-394d6c28b26a
  │                       230c8b18-8d9b-53ec-838b-6cfc0383493a
  │                       660e54f1-43fd-5b2b-a7b5-36422f9c8f2f
  │   Device Flags:       • Internal device
  │                       • Updatable
  │                       • System requires external power source
  │                       • Supported on remote server
  │                       • Needs a reboot after installation
  │                       • Cryptographic hash verification is available
  │                       • Device is usable for the duration of the update
  ├─ThinkPad X13/T14s Gen 1 AMD System Update:
  │     New version:      0.1.32
  │     Remote ID:        lvfs
  │     Zusammenfassung:  Lenovo ThinkPad X13/T14s Gen 1 AMD System Firmware
  │     License:          Proprietary
  │     Size:             17,9 MB
  │     Created:          2021-05-14
  │     Urgency:          High
  │     Vendor:           Lenovo Ltd.
  │     Flags:            is-upgrade
  │     Beschreibung:
  │     This stable release fixes the following issues:
  │     • Fixed an issue that Fixed TSC synchronization  failed under linux.
  │     • Fixed an issue that Optimize for Linux S5 power consumption problem.
  │     • Fixed an issue that display not light up and system hang up when connect monitor with CS18 dock.
  │     • Fixed an issue that ACPI Error: Region EmbeddedControl (ID=3) has no handler under Linux.
  │     Some new functionality has also been added:
  │     • Enable DMAR support.
  │     • Sync system base board version to SMBIOS type2.
  │     • Add Odometer SSD Read Write Counts Metric.
  │     • Add enhance Tamper Protection control for T14s AMD
  │     Notes:In case user update the UEFI BIOS v1.32 (R1CET63W) , need to load default configuration in BIOS setup.(For enable DMAr function support).
  │     1).Please press F1 key to BIOS setup.2).Press the F9 key to load default configuration.3).Select Yes.4).Press F10 key to save default configuration and exit.5).Select Yes. The computer will be restarted automatically.
  └─ThinkPad X13/T14s Gen 1 AMD System Update:
        New version:      0.1.30
        Remote ID:        lvfs
        Created:          2021-01-04
        Urgency:          High
        Vendor:           Lenovo Ltd.
        Flags:            is-upgrade
        Beschreibung:
        • Unit report abnormal beep code after plug out LCD cable then power on unit.
        • One dock LED is always on after system enter S3/S4/S5 and attach two same dock to system.
$ fwupdmgr update
 • Integrated Camera
 • Prometheus
Upgrade available for System Firmware from 0.1.29 to 0.1.32
20UH001QGE must remain plugged into a power source for the duration of the update to avoid damage. Continue with update? [Y|n]: Y
Herunterladen …          [***************************************] Weniger als eine Minute verbleiben…
Entpacken …              [***************************************]
Authentifizierung …      [***************************************]
System Firmware wird aktualisiert …******************************]
Einplanen …              [***************************************]
Successfully installed firmware
 • UEFI dbx
Ein Neustart ist erforderlich, um eine Aktualisierung abzuschließen.
Den Neustart habe ich nach mehr als fünf Minuten schwarzem Bildschirm (Lüfter EIN auf hoher Stufe) abgebrochen, System AUS > EIN. Dann:
fwupdmgr get-devices
Nicht korrekt aktualisierte Geräte:
 • System Firmware (0.1.29 → 0.1.32)
Was nun? Danke, Michael
mit der iso hat man im Zweifel auch seinen Spaß -> ich hatte leztens einen schwarzen Bildschirm am t490s (gefühlte 20 min).
Ich habe das iso mit dd auf den Stick geschrieben /dev/sdX -
Im Zweifel erstmal nicht updaten ?!? Schaue mal auf reddit Linuxonthinkpad und /r/thinkpad und im Lenovoforum - da waren ein paar Berichte von gebrickten T14 ... :facepalm:
Oder nochmal per fwupdmgr und dann länger warten ?
PS: https://thinkpad-forum.de/threads/228369-Firmwareupdate-Schiefgegangen
PPS: https://old.reddit.com/r/thinkpad/comments/nu0dnh/recent_firmware_upgrade_bricked_my_t14s/
Mehr finde ich natürlich nicht wieder ...
Danke!
Ich werde das Update jetzt zurückstellen, bis es eine neue, fehlerfreie Version gibt. Zum Glück startet mein System. Ich habe das Problem hier veröffentlicht, für das LENOVO-Forum fehlt mir die ID.
Unschön ist, dass seit dem fwupd-Fehler der rote LENOVO-Balken zweimal kommt und besonders beim zweiten Auftauchen lang anhaltend den Start ausbremst. Kann ich etwas bereinigen?
OK, dann bis in 5 Jahren...
Ja, alternative Installationsmethode durchführen.
Ist auf der Kiste noch Garantie?
Ja sorry das war ein Schuß ins Blaue - gefühlt funktioniert da gar nichts mehr mit den Firmwareupdates zur Zeit.
'the secure boot issue is separate and you'll need Secure Boot disabled until that is fixed upstream in shim. ... .'
Heute Update BIOS 1.29 -> 1.34 mit fwupd erfolgreich durchgeführt.
