|==[22:11:14] <jumper@Jumper-W520> ~
|==$ sudo !!
sudo gpsd -n -N -D4 /dev/ttyACM2
gpsd: launching (Version 2.95)
gpsd: listening on port gpsd
gpsd: NTPD shmat(0,0,0) succeeded, segment 0
gpsd: NTPD shmat(32769,0,0) succeeded, segment 1
gpsd: NTPD shmat(65538,0,0) succeeded, segment 2
gpsd: NTPD shmat(98307,0,0) succeeded, segment 3
gpsd: successfully connected to the DBUS system bus
gpsd: running with effective group ID 0
gpsd: running with effective user ID 0
gpsd: opening read-only GPS data source type 0 and at '/dev/ttyACM2'
gpsd: speed 57600, 8N1
gpsd: => GPS: @F0.3=1*67\x0d\x0a FAILED
gpsd: => GPS: @F2.2=1*64\x0d\x0a FAILED
gpsd: Navcom: sent command 0x1c (Test Support Block)
gpsd: Navcom: sent command 0x20 (Data Request) - data block id = ae at rate 00
gpsd: Navcom: sent command 0x20 (Data Request) - data block id = 86 at rate 0a
gpsd: Probing TSIP
gpsd: speed 9600, 8O1
gpsd: no probe matched...
gpsd: gpsd_activate(): opened GPS (fd 6)
