E540 Trackpoint scrolling
Trojan4
16 Dez. 2013
Moin moin,
ich habe ein Problem mit dem Einrichten der Trackpointscrollfunktion unter Linux. Wie unter Windows würde ich gerne mittels des mittleren Buttons des 5-point-clickpads (Keine dedizierten Tasten) mit dem Trackpoint scrollen können.
Zur aktuellen Konfiguration:
so soll das Touchpad unter Windows funktionieren:
|LLLLL  MMMM RRRRR |
|LLLLLL           RRRRR |
so ist das touchpad momentan unter Linux eingerichtet:
|LLLLL  MMMM RRRRR |
|LLLLL  MMMM RRRRR |
|LLLLL  MMMM RRRRR |
|LLLLL  MMMM RRRRR |
cat 51-synaptics-udef.conf
Section "InputClass"
        Identifier "touchpad catchall"
        Driver "synaptics"
        MatchIsTouchpad "on"
# This option is recommend on all Linux systems using evdev, but cannot be
# enabled by default. See the following link for details:
# http://who-t.blogspot.com/2010/11/how-to-ignore-configuration-errors.html
      MatchDevicePath "/dev/input/event*"
EndSection
        Identifier "touchpad ignore duplicates"
        MatchOS "Linux"
        MatchDevicePath "/dev/input/mouse*"
        Option "Ignore" "on"
EndSection
# This option enables the bottom right corner to be a right button on
# non-synaptics clickpads.
# This option is only interpreted by clickpads.
        Identifier "Default clickpad buttons"
        MatchDriver "synaptics"
        Option "SoftButtonAreas" "66% 0 0 0 40% 65% 0 0"
#Natural Scolling:
    Option      "VertScrollDelta"          "-111"
        Option      "HorizScrollDelta"         "-111"
#Noise cancelling
    Option "HorizHysteresis" "20"
    Option "VertHysteresis" "20"
    Option "AreaTopEdge" "50%"
#       To disable the bottom edge area so the buttons only work as buttons,
#       not for movement, set the AreaBottomEdge
#       Option "AreaBottomEdge" "20%"
EndSection
# This option disables software buttons on Apple touchpads.
        Identifier "Disable clickpad buttons on Apple touchpads"
        MatchProduct "Apple|bcm5974"
        Option "SoftButtonAreas" "0 0 0 0 0 0 0 0"
EndSection
cat 11-evdev-trackpoint.conf
# trackpoint users want wheel emulation
    Identifier    "trackpoint catchall"
    MatchIsPointer    "true"
    MatchProduct    "TrackPoint|DualPoint Stick"
    Option    "EmulateWheel"    "true"
    Option  "EmulateWheelTimeout"   "200"
    Option    "EmulateWheelButton"    "2"
    Option    "XAxisMapping"    "6 7"
    Option    "YAxisMapping"    "4 5"
EndSection
