CS 18 Dock Unterschiede
Philipp_B
Rather active member
24 Mai 2015
Ab den 2018 Modellen verwendet Lenovo für ThinkPads für das ThinkPad X1, X280, T und L Serie eine neue Dock, welche an die Seite geflanscht wird. Da 3x verschiedene Modelle zur Verfügung stehen, hier 1:1 Detailvergleich.
ThinkPad Basic Docking StationThinkPad Pro Docking StationThinkPad Ultra Docking Station
EU Teilenummer40AG0090EU40AH0135EU40AJ0135EU
Overview and Service PartsLink zu LenovoLink zu LenovoLink zu Lenovo
Video PortsVideo 1 : DisplayPort 1.4
Video 1 : VGA
Video 2 : DisplayPort 1.4
Video 2 : HDMI 2.0
Video 3 : DisplayPort 1.4
Video 3 : VGA
Maximum Video Output1 x 4K @ 60 Hz2 x 4K @ 60 Hz
DisplayPort 1: 4096 x 2160 @ 60 Hz
DisplayPort 2: 4096 x 2160 @ 60 Hz
Maximum resolution"" refers to what can be supported by the dock. Actual resolution will vary by laptop.
3 x 4K @ 60 Hz
DisplayPort: 4096 x 2160 @ 60 Hz
DisplayPort or HDMI: 4096 x 2160 @ 60 Hz
VGA: 2048 x 1536 @ 85 Hz
Maximum resolution refers to what can be supported by the dock. Actual resolution will vary by laptop.
Maximum Number of Displays123
USB Ports2 x USB 3.1 Gen 1
(5 Gbps, 1 x always power-on)
2 x USB 2.0
3 x USB 3.1 Gen 1
2 x USB 2.0
1 x USB-C (5 Gbps data,5V/3A bus power)
4 x USB 3.1 Gen 2
(10 Gbps, 1 x always power-on)
2 x USB-C (10 Gbps data,
5V/3A bus power)
Ethernet (RJ45)GigabitGigabitGigabit
AudioStereo/Microphone comboStereo/Microphone combo
Power Adapter Inside the Box90W135W135W
Maximum Power for Laptop Charging65W85W65W
Power Button to Control
System Power
Selected ThinkPad laptopsSelected ThinkPad laptopsSelected ThinkPad laptops
PXE BootSelected ThinkPad laptopsSelected ThinkPad laptopsSelected ThinkPad laptops
MAC Address Pass-throughSelected ThinkPad laptopsSelected ThinkPad laptopsSelected ThinkPad laptops
Wake-on-LANSleep, Hibernation and Power-off mode on Selected ThinkPad laptopsSleep, Hibernation and Power-off mode on Selected ThinkPad laptopsSleep, Hibernation and Power-off mode on Selected ThinkPad laptops
Warranty3 years3 years3 years
Support SystemsThinkPad 2018 A, T Series, L Series, X1 Carbon, X280, P52sThinkPad 2018 A, T Series, L Series, X1 Carbon, X280, P52sThinkPad 2018 A, T Series, L Series, X1 Carbon, X280, P52s
Nachtrag 3.10. 2018
Tabelle eingetragen, nun sichtbar für nicht Forenuser.
Nachtrag 21.8. 2020
Noch ein zu Displayport 1.2 und 1.4. : Die Docks unterstützen laut meiner Info bereits die DP 1.4 Spezifikation, aber die Intel basierten ThinkPads der 2018 Serie nur DP 1.2.
AMD basierte ThinkPads ab 2019 unterstützen bereits DisplayPort 1.4.
Ist im Power-Button der Dock eine LED verbaut oder nicht? Im Betrieb oder Standby leuchtet bei mir jedenfalls nichts am Power-Button der Dock, weshalb ich mir Frage, ob hier ein Defekt vorliegt oder nicht...?
Bei meiner CS18 ThinkPad Ultra Docking Station leuchtet auch nichts am Dock-Power-Button, nur das kleine Computer-Symbol wie oben beschrieben.
Jetzt hab ich mal ne doofe Frage.
An den CS18 Docks muss ! man ein Netzteil mit Eckingen Anschluss verwenden, die dem Notebook beiliegendem Netzteil mit USB-C Anschluss kann man nicht an der Dock verwenden korrekt ?
Ja, zumindest bei der CS18 Ultra Dock und bei der Thunderbolt Dock ist das so.
hab im ersten Post einen Hinweis zu den AMD ThinkPads hinterlassen.
