sudo tlp-stat
--- TLP 0.3.7.1 --------------------------------------------
+++ Configured Settings: /etc/default/tlp
TLP_ENABLE=1
DISK_IDLE_SECS_ON_AC=0
DISK_IDLE_SECS_ON_BAT=2
MAX_LOST_WORK_SECS_ON_AC=15
MAX_LOST_WORK_SECS_ON_BAT=60
SCHED_POWERSAVE_ON_AC=0
SCHED_POWERSAVE_ON_BAT=1
NMI_WATCHDOG=0
DISK_DEVICES="sda sdb"
DISK_APM_LEVEL_ON_AC="254 254"
DISK_APM_LEVEL_ON_BAT="128 128"
SATA_LINKPWR_ON_AC=max_performance
SATA_LINKPWR_ON_BAT=min_power
PCIE_ASPM_ON_AC=performance
PCIE_ASPM_ON_BAT=powersave
RADEON_POWER_PROFILE_ON_AC=high
RADEON_POWER_PROFILE_ON_BAT=low
WIFI_PWR_ON_AC=1
WIFI_PWR_ON_BAT=5
WOL_DISABLE=Y
SOUND_POWER_SAVE=1
SOUND_POWER_SAVE_CONTROLLER=Y
BAY_POWEROFF_ON_BAT=0
BAY_DEVICE="sr0"
RUNTIME_PM_ON_AC=on
RUNTIME_PM_ON_BAT=auto
USB_AUTOSUSPEND=1
RESTORE_DEVICE_STATE_ON_STARTUP=0
+++ System Info
System = LENOVO ThinkPad S430 3364CTO
BIOS = GAET70WW (2.06 )
Release = Linux Mint 13 Maya
Kernel = 3.2.0-23-generic x86_64
/proc/cmdline = BOOT_IMAGE=/boot/vmlinuz-3.2.0-23-generic root=UUID=50893d11-9e85-41fe-9596-8fdadee63f13 ro quiet splash vt.handoff=7
+++ System Status
TLP power save = enabled
power source = ac
+++ Processor
/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor = ondemand
/sys/devices/system/cpu/cpu0/cpufreq/scaling_min_freq = 1200000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_max_freq = 2501000 [kHz]
/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies = 2501000 2500000 2400000 2300000 2200000 2100000 2000000 1900000 1800000 1700000 1600000 1500000 1400000 1300000 1200000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor = ondemand
/sys/devices/system/cpu/cpu1/cpufreq/scaling_min_freq = 1200000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_max_freq = 2501000 [kHz]
/sys/devices/system/cpu/cpu1/cpufreq/scaling_available_frequencies = 2501000 2500000 2400000 2300000 2200000 2100000 2000000 1900000 1800000 1700000 1600000 1500000 1400000 1300000 1200000 [kHz]
/sys/devices/system/cpu/cpu2/cpufreq/scaling_governor = ondemand
/sys/devices/system/cpu/cpu2/cpufreq/scaling_min_freq = 1200000 [kHz]
/sys/devices/system/cpu/cpu2/cpufreq/scaling_max_freq = 2501000 [kHz]
/sys/devices/system/cpu/cpu2/cpufreq/scaling_available_frequencies = 2501000 2500000 2400000 2300000 2200000 2100000 2000000 1900000 1800000 1700000 1600000 1500000 1400000 1300000 1200000 [kHz]
/sys/devices/system/cpu/cpu3/cpufreq/scaling_governor = ondemand
/sys/devices/system/cpu/cpu3/cpufreq/scaling_min_freq = 1200000 [kHz]
/sys/devices/system/cpu/cpu3/cpufreq/scaling_max_freq = 2501000 [kHz]
/sys/devices/system/cpu/cpu3/cpufreq/scaling_available_frequencies = 2501000 2500000 2400000 2300000 2200000 2100000 2000000 1900000 1800000 1700000 1600000 1500000 1400000 1300000 1200000 [kHz]
/sys/devices/system/cpu/sched_mc_power_savings = 0
/sys/devices/system/cpu/sched_smt_power_savings = 0
/proc/sys/kernel/nmi_watchdog = 0
+++ Undervolting
PHC kernel not available.
+++ Temperatures
CPU temp = 55 [°C]
/proc/acpi/ibm/fan = 0 [/min]
+++ File System
/proc/sys/vm/laptop_mode = 0
/proc/sys/vm/dirty_writeback_centisecs = 1500
/proc/sys/vm/dirty_expire_centisecs = 1500
/proc/sys/vm/dirty_ratio = 60
/proc/sys/vm/dirty_background_ratio = 1
/proc/sys/fs/xfs/age_buffer_centisecs = (not available)
/proc/sys/fs/xfs/xfssyncd_centisecs = (not available)
/proc/sys/fs/xfs/xfsbufd_centisecs = (not available)
+++ Storage Devices
/dev/sda:
Model = HITACHI HTS725050A7E630
Firmware = GH2ZB390
APM Level = 254
scheduler = cfq
SMART info:
4 Start_Stop_Count = 222
5 Reallocated_Sector_Ct = 0
9 Power_On_Hours = 87 [h]
193 Load_Cycle_Count = 1216
194 Temperature_Celsius = 25 (Min/Max 16/49) [°C]
/dev/sdb:
Model = M4-CT128M4SSD3
Firmware = 01MG
APM Level = 254
TRIM = supported
scheduler = cfq
SMART info:
9 Power_On_Hours = 62 [h]
194 Temperature_Celsius = 0 [°C]
+++ SATA Aggressive Link Power Management
/sys/class/scsi_host/host0/link_power_management_policy = max_performance
/sys/class/scsi_host/host1/link_power_management_policy = max_performance
/sys/class/scsi_host/host2/link_power_management_policy = max_performance
/sys/class/scsi_host/host3/link_power_management_policy = max_performance
/sys/class/scsi_host/host4/link_power_management_policy = max_performance
/sys/class/scsi_host/host5/link_power_management_policy = max_performance
+++ PCIe Active State Power Management
/sys/module/pcie_aspm/parameters/policy = default (disabled by kernel)
+++ Intel Graphics
/sys/module/i915/parameters/powersave = 1
/sys/module/i915/parameters/i915_enable_rc6 = -1
/sys/module/i915/parameters/i915_enable_fbc = -1
/sys/module/i915/parameters/lvds_downclock = 0
/sys/module/i915/parameters/semaphores = -1
+++ Wireless
bluetooth = off (software)
wifi = on
wwan = none (no device)
wlan0(iwlwifi): power management = off
+++ Audio
/sys/module/snd_hda_intel/parameters/power_save = 1
/sys/module/snd_hda_intel/parameters/power_save_controller = Y
+++ Battery
Hint: ThinkPad extended battery info not available (tp-smapi kernel module not loaded).
/sys/class/power_supply/BAT0/manufacturer = SANYO
/sys/class/power_supply/BAT0/model_name = 45N1085
/sys/class/power_supply/BAT0/cycle_count = 0
/sys/class/power_supply/BAT0/energy_full_design = 48400 [mWh]
/sys/class/power_supply/BAT0/energy_full = 42890 [mWh]
/sys/class/power_supply/BAT0/energy_now = 12660 [mWh]
/sys/class/power_supply/BAT0/power_now = 34393 [mW]
/sys/class/power_supply/BAT0/status = Charging
+++ Runtime Power Management
/sys/bus/pci/devices/0000:00:00.0/power/control = on [Host]
/sys/bus/pci/devices/0000:00:1b.0/power/control = on [Audio]
/sys/bus/pci/devices/0000:03:00.0/power/control = on [Wireless]
/sys/bus/pci/devices/0000:04:00.0/power/control = on [Ethernet]
+++ USB
tlp usb autosuspend = enabled
tlp usb blacklist = (not configured)
Bus 001 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 2.0 root hub (hub)
Bus 002 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 2.0 root hub (hub)
Bus 003 Device 001 ID 1d6b:0002 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 2.0 root hub (hub)
Bus 004 Device 001 ID 1d6b:0003 control = auto, autosuspend_delay_ms = 2000 -- Linux Foundation 3.0 root hub (hub)
Bus 001 Device 002 ID 8087:0024 control = auto, autosuspend_delay_ms = 2000 -- Intel Corp. Integrated Rate Matching Hub (hub)
Bus 002 Device 002 ID 8087:0024 control = auto, autosuspend_delay_ms = 2000 -- Intel Corp. Integrated Rate Matching Hub (hub)
Bus 001 Device 004 ID 147e:1002 control = auto, autosuspend_delay_ms = 2000 -- Upek (no driver)
Bus 002 Device 003 ID 04f2:b2ea control = auto, autosuspend_delay_ms = 2000 -- Chicony Electronics Co., Ltd (uvcvideo)
