Follow along with the video below to see how to install our site as a web app on your home screen.
Anmerkung: This feature may not be available in some browsers.
Jap so mach Ichs auch gerade!Bei T4xx reicht die bootable CD ohne große Klimmzüge.
Jupp.... mal ne dumme Frage, läuft das Update über ne bootable CD direkt an, also bevor Windows gestartet wird?
Quellemanual update
- print these instructions or display on another computer.
- Firmly connect the ac adapter to the target computer.
- Make sure your thinkpad computer has an optical drive installed.
- Insert the bios update cd into the optical drive and turn on the computer.
- Select read this first from the menu and carefully read the information.
- Press the esc key to return to the menu.
- Select update system program and follow the instructions on the screen.
- After the information panel appears, remove the bios update cd from the optical drive then press the enter key to restart the computer.
Initializing uefi bios
note:
After initialization you may need to reapply some settings that you had changed previously.
Uefi bios initialization is suggested for some problems. To initialize the uefi bios settings:
- Turn off the computer.
- Turn on the computer.
- While the "to interrupt normal startup, press the blue thinkvantage button" message is displayed at the lower-left area of the screen, press the f1 key.
- The thinkpad setup menu will be displayed. If a password prompt appears, type the correct password.
- Press the f9 key to load default configuration.
- Select yes.
- Press the f10 key to save default configuration and exit.
- Select yes.
- Restart the computer.
