(Hoffe es ist das richtige Unterforum)
Mein Lenovo System Update hat mir heute eine "Kritische Aktualisierung" angezeigt, die für viele ThinkPads von Bedeutung scheint (gekürzt wegen Zeichenbegrenzung; volle Länge: https://download.lenovo.com/pccbbs/mobiles/fwnva53.txt):
Revision : 01
Package Name NVMe Solid State Drive Firmware Update Utility
Support models ThinkPad T460s, T460, T460p, T560
ThinkPad T470s, T470, T470p, T570, T480, T490, T480s, T490s, T580, T590
ThinkPad T490, T490s, T590, T495, T495s
ThinkPad T14 gen1, T14s gen1, P14 gen1, P14s gen1, T15 gen1, P15s gen1
ThinkPad T14 gen2, T14s gen2, P14 gen2, P14s gen2, T15 gen2, P15s gen2
ThinkPad T14 gen3, T14s gen3, P14s gen3
ThinkPad T15p gen1, P15v gen1 , T15p gen2, P15v gen2, T15p gen3, P15v gen3
ThinkPad T16 gen1 , P16s gen1
ThinkPad Yoga 260, Yoga 460, Yoga 370, Yoga S1
ThinkPad X380 Yoga
ThinkPad X1 Carbon 4th, 5th, 6th, 7th
ThinkPad X1 Carbon gen8, gen9 , gen10
ThinkPad X1 Yoga, Yoga 2nd, 3rd, 4th
ThinkPad X1 Yoga gen5, gen6 , gen7
ThinkPad X1 Nano
ThinkPad X1 Fold
ThinkPad X1 Titanium
ThinkPad X13 gen1 , X13 gen2 , X13 gen3
ThinkPad X13 Yoga gen1 , X13 Yoga gen2
ThinkPad P50s, P51s, P52s, P53s, P43s
ThinkPad P50, P50 with RAID, P70, P70 with RAID
ThinkPad P51, P51 with RAID, P71, P71 with RAID
ThinkPad P52, P52 with RAID, P72, P72 with RAID
ThinkPad P53, P53 with RAID, P73, P73 with RAID
ThinkPad P1, P1 with RAID
ThinkPad X1 Extreme, X1 Extreme with RAID
ThinkPad P1 gen2, P1 gen2 with RAID, X1 Extreme gen2, X1 Extreme gen2 with RAID
ThinkPad P1 gen3, P1 gen3 with RAID, X1 Extreme gen3, X1 Extreme gen3 with RAID
ThinkPad P1 gen4, P1 gen4 with RAID, X1 Extreme gen4, X1 Extreme gen4 with RAID
ThinkPad P15, T15g, P17 ,P15with RAID, T15gwith RAID, P17with RAID
ThinkPad P15 gen2, T15g gen2, P17 gen2 ,P15 gen2with RAID, T15g gen2with RAID, P17 gen2with RAID
ThinkPad X260, X270, X280
ThinkPad X1 Tablet, X1 Tablet Gen 2, X1 Tablet Gen 3
ThinkPad E570p, E570, E580, E585, E480, E485, E490, E590
ThinkPad E490s, E495, E595
ThinkPad L570, L470, L480, L580, L380, L380 Yoga, L390, L490, L590
ThinkPad L13, L13 gen2 , L13 Gen3
ThinkPad L13 Yoga, L13 Yoga gen2, L13 Yoga gen3
ThinkPad L14 gen1, L14 gen2, L14 gen3
ThinkPad L15 gen1, L15 gen2, L15 gen3
ThinkPad S1, S1 2nd Gen, S1 3rd Gen, S1 4th Gen
ThinkPad S2, S2 3rd gen, 4th gen, 5th gen, gen6, gen7
ThinkPad S2 Yoga 3rd gen, 4th gen, 5th gen, gen6, gen7
ThinkPad 13, S15
ThinkPad S3-490
ThinkPad S5 2nd Generation
ThinkPad A275, A285, A475, A485
ThinkPad R480, R490, R590
ThinkPad E14, E14 gen2, E14 gen3, E15, E15 gen2, E15 gen3
ThinkPad X390, X390 Yoga, X395
ThinkPad 11e 5th
ThinkPad neo 14
Operating System Microsoft Windows 10 64-bit
Microsoft Windows 11
Release FWNVA53
Version 53
WHAT THIS PACKAGE DOES
This utility will examine your system configuration and detect all NVMe Solid
State Drives installed. It will then check the firmware revision of the drive
and judge whether your PC requires a firmware update or not. If required, it
will prompt you to run the appropriate firmware update program for your drive.
Note)
This Utility supports listed NVMe systems or their follow-on products having
NVMe interface.
(Other interface such as USB is not supported)
IMPORTANT INFORMATION
A) After completing a firmware update, the NVMe Solid State Drives will not properly
function until you shut down and reboot PC.
Before executing a drive firmware update, be sure of following;
- Close all the applications besides of the Firmware Update Utility.
- Verify that the AC power cord is connected to outlet and adapter cable is
connected to PC firmly.
- Make sure that a charged battery pack is installed in PC.
- Do not power off, remove a drive during an update.
Otherwise your drive may become damaged.
B) This utility contains several executable files.
DO NOT RUN THESE PROGRAMS except FWWINSD.EXE.
Running these programs other than FWWINSD.EXE could ruin your Solid State
Drive.(Extract only case)
C) Need to update IRST to 15.0 or newer when could not FW update on the P50,RAID and P70,RAID.
D) Need to update BIOS or Remove HDD Password when could not FW update on the P50,P51 and P70,P71 with HDP.
E) Need to Remove HDD Password when could not FW update on the A275,A475 with HDP.
F) FW update is not supported on WinPE
G) Need to update BIOS when could not FW update.
