gamermaster
- 28 Sep. 2017
Irgendwie kann ich es jetzt auch runterladen
Follow along with the video below to see how to install our site as a web app on your home screen.
Anmerkung: This feature may not be available in some browsers.
@RanHoeck: Ich konnte damit den Akku meines X301 durch gezieltes „bearbeiten“ von 19Ah auf 40.5Ah bringen.
Mag sein, es erklärt aber nicht, wie man aus alten Akkus, die ohnehin keinen echten Mehrwert mehr darstellen, das Maximale herausholt.Zum Rekalibrieren braucht man den Battereanimator nicht.
So the battery told you, that it is more healthy than it really was.Before i tried the reconditioning i had 13.5wh life but after 4-5 tries of trying to "condition" it, my battery reports 5.4wh
This may be caused by damaged bettery cells.Battery from %100 to %0 goes in 5 minutes
Left column starting at "01315" to "01742" the voltage (3rd column) raised and fell down. What happened there? Did the computer shut down in that time range or did ot "work" only? [/ QUOTE]
It continued to work and shut itself at 02440 000 9486 17406. Should i enter 9600 in the app? I already emptied the battery 3 times and fully charged it, it continues to degrade capacity. I am not really sure if i am doing this right but, i do it like this if i understood correctly.
Fully empty batttery until computer can not start.
Wait for battery to cool down.
Fully charge it like 6-7 hours.
Empty again and wait to cool down.
Fully charge.
Is this the right way?
It is the right way, if the computer powers off by drained battery but not by ThinkPad Battery Maximizer. It is recommended to let the battery charge over night (approx. 10 hrs) but 6-7 hrs should be enough. - It is strongly recommended to leave the computer turned off while charging.Fully empty batttery until computer can not start.
Fully charge.
Yes, that is my recommendation. Do not forget to mark "hibernate". You should test the setting, whether entering the hibernation state does not become interrupted by power-off, because of empty batteriy.Should i enter 9600 in the app?
