So, hier mal die Errorlog von Nero:
09:31:40 File burn_dvdfiles.cpp, Line 1244
Compile DVD: begin copy 1
09:31:40 File NeroRecorderBase.cpp, Line 517
Writing to disc: D
09:31:40 File NeroRecorderBase.cpp, Line 531
Free capacity on disc: 2286460 sectors (2298496)
09:31:41 File burn_dvdfiles.cpp, Line 772
Compile DVD: begin deep analysis
09:46:43 File burn_dvdfiles.cpp, Line 548
Compile DVD: burning 2286460 sectors (2283092 required)
09:46:43 File burn_dvdfiles.cpp, Line 744
Compile DVD: adjust target size to 4465.74MB (4465.74MB obtained)
09:46:43 File burn_dvdfiles.cpp, Line 594
Compiling DVD Volume started
09:47:24 File vob_record.cpp, Line 647
DirectBurn offset: VTS_01_1.VOB 112
09:47:49 File NeroRecorder.cpp, Line 677
Burn failed (3)
----- Begin NeroAPI error log -----
5C80-50KA-09K3-0000-8055-C3KA-****
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 17.07.2002 09:20:56
ahead WinASPI: File 'C:\Programme\Copy\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=169792 bytes, created 14.03.2007 12:43:16
NT-SPTI used
Nero API version: 7.10.1.0
Using interface version: 7.5.0.2
Installed in: C:\Programme\Copy\Nero 7\Core\
Application: Ahead\Nero Recode
Internal Version: 7, 10, 1, 0
Recorder: <PIONEER DVD-RW DVR-K17LF>Version: 2.52 - HA 1 TA 0 - 7.10.1.0
Adapter driver: <USB 2.0> HA 1
Drive buffer : 2000kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ?
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
=== Scsi-Device-Map ===
DiskPeripheral : HITACHI_DK13FA-40B atapi Port 0 ID 0 DMA: On
=== CDRom-Device-Map ===
PIONEER DVD-RW DVR-K17LF D: CdRom0
AutoRun : 0
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1014MB (1038768kB)
Free physical memory: 576MB (590004kB)
Memory in use : 43
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.6.2008
NeroAPI
09:31:40 #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
09:31:41 #2 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: -1 ( 0:00.-1, 0MB)
09:31:41 #3 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO
09:31:41 #4 Text 0 File DlgWaitCD.cpp, Line 2972
Recorder: PIONEER DVD-RW DVR-K17LF, Media type: DVD-R
Disc Manufacturer: CMC MA - G. AM3
Disc Application Code: 64, Disc Physical Code: 193
09:31:41 #5 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
09:31:41 #6 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
09:31:41 #7 SPTI -1066 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1066)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAC 00 00 00 00 00 00 00 00 64 00 00
Sense Area: 0x70 00 05 00 00 00 00 0E 00 00 00 00 24
Buffer x08eb94c0: Len x648
09:31:41 #8 Text 0 File BurnAtOnceRecorder.cpp, Line 1028
Estimated filesystem size: 544
09:31:41 #9 Phase 36 File APIProgress.cpp, Line 285
Burn process started at 2x (2.770 KB/s)
09:47:22 #10 SPTI -1066 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x24
Sense Qual: 0x00
Buffer x08e738c0: Len x648
09:47:22 #11 Text 0 File DVDR.cpp, Line 3225
Recording mode: Sequential Recording Mode for Multisession
09:47:23 #12 Text 0 File DVDR.cpp, Line 3381
Start write address at LBA 0
DVD high compatibility mode: No
09:47:23 #13 SPTI -1066 File SCSIPassThrough.cpp, Line 179
Sense Code: 0x24
Sense Qual: 0x00
09:47:23 #14 Text 0 File Cdrdrv.cpp, Line 9869
---- Disc Structure: Physical Format Information (00h) ----
Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Revision number of maximum recording speed: 6.0
Revision number of minimum recording speed: -
Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
Class: 0
Start sector number of the current Border-Out: 0 h
Start sector number of the next Border-In: 0 h
Media Specific [16..63]:
00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
09:47:23 #15 Text 0 File BurnAtOnceRecorder.cpp, Line 689
Reserved fragment at 0. Length: 592
09:47:23 #16 Text 0 File BurnAtOnceRecorder.cpp, Line 1910
Reserved start fragment at 0
09:47:24 #17 Text 0 File BurnAtOnceRecorder.cpp, Line 689
Reserved fragment at 592. Length: 64
09:47:24 #18 Text 0 File BurnAtOnceRecorder.cpp, Line 1427
Writing VTS_01_1.VOB at sector 656
09:47:49 #19 SPTI -1061 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1061)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x44
Sense Qual: 0xD9
CDB Data: 0x2A 00 00 00 05 90 00 00 20 00 00 00
Sense Area: 0x71 00 04 00 25 FC 5E 0E 00 00 00 00 44 D9
Buffer x08eca040: Len x10000
0x00 00 01 BA 44 00 57 22 4C 57 01 89 C3 F8 00 00
0x01 E0 07 EC 81 00 00 B0 17 D1 45 68 31 C9 00 FC
0x89 77 45 16 96 65 11 2C FC C4 0C 47 5C 59 E0 64
09:47:49 #20 Text 0 File BurnAtOnceRecorder.cpp, Line 2236
Failed to write 112 sectors at 1392
09:47:49 #21 Phase 179 File APIProgress.cpp, Line 285
Writing file to disc failed
09:47:49 #22 Text 0 File BurnAtOnceRecorder.cpp, Line 3710
Disc info:
Partitions: 2
#0: Start: 0, Size: 576
#1: Start: 592, Size: 48
09:47:49 #23 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
09:47:49 #24 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
09:47:49 #25 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
09:47:52 #26 Phase 38 File APIProgress.cpp, Line 285
Burn process failed at 2x (2.770 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002), size=16877 bytes, created 17.07.2002 08:53:02
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Grüsse: Steed
